Smithy Posted May 20, 2010 Report Posted May 20, 2010 In the Drum Engine, if you have SQC = * (Internal Sequencer Active), and its playing back, if you then go to the Random Generator Menu, and Press All, i notice that the Sequencer gets deactivated after a random patch is generated and playback stops. Would it be possible to allow it to keep active when random patches are generated? Or maybe its mandatory to reset the oscillators or something. Quote
Razmo Kefrens Posted October 31, 2010 Report Posted October 31, 2010 Hi... Can anyone confirm, that the Sammich SID is correctly responding to Bank change messages (using CC#00)? I'm on SONAR and I REALLY have tried EVERYTHING to make SONAR switch banks on the SammichSID using the "Controller 0" method... everything is set up correctly, but the only thing that happens is that it switch patches within the currently selected bank on the SammichSID... No bank change is happening at all. I'm just wondering if this might be a bug, or it's SONAR that screws up... SONAR has behaved weirdly before not wanting to switch banks on other machines I've got as well, but these usualy could be fixed by making a new .ins file, but not this time. Regards, Razmo. Quote
TK. Posted October 31, 2010 Author Report Posted October 31, 2010 Works fine at my side. Note that only values 0..7 lead to a bank change, all other values are silently ignored. You could try the bank change with MIDI-Ox - does it work with this program? You could also check if Sonar really sends CC#0 by using a MIDI-Loopback, monitored with MIDI-Ox Best Regards, Thorsten. Quote
Razmo Kefrens Posted October 31, 2010 Report Posted October 31, 2010 (edited) Works fine at my side. Note that only values 0..7 lead to a bank change, all other values are silently ignored. You could try the bank change with MIDI-Ox - does it work with this program? You could also check if Sonar really sends CC#0 by using a MIDI-Loopback, monitored with MIDI-Ox Best Regards, Thorsten. Well... I feared that it worked with others... are the SammichSID handling patch+bank change as two separate events, or will it wait after recieving a bank change for a Patch Change right after the Bank controller 0 has been sent? ... I have a feeling it's something about how SONAR is sending out the change... I have other gear connected to SONAR that also use controller 0 for bank changing, and they change banks as they should. I guess I'll have to take a closer look at what is going on in SONAR's MIDI sending... You say numbers 0-7 ? The SammichSID only have 4 banks and 1 ensemble bank... I've been using numbers 0-3 for banks A-D with controller 0 Edited October 31, 2010 by Razmo Kefrens Quote
TK. Posted October 31, 2010 Author Report Posted October 31, 2010 It doesn't matter in which order Program Change and Bank Change are received - both events will change the patch immediately. Best Regards, Thorsten. Quote
Razmo Kefrens Posted October 31, 2010 Report Posted October 31, 2010 It doesn't matter in which order Program Change and Bank Change are received - both events will change the patch immediately. Best Regards, Thorsten. I localized the problem now... it's SONAR that screw up. In SONAR you can choose 4 types of bank change schemes: Standard (using both controllers 0 and 32) Controller 0 (using controller 0 only) Controller 32 (using controller 32 only) Patch 100-127 (using patch changes to bank switch) no matter WHAT method you choose, SONAR always spit out the standard way, using both controller 0 and 32... I do not know if this is an unknown bug or if they intentionally dropped the 3 other methods, but it means that I cannot make bank changes on the SammichSID unless I multiply the bank number by 128 which is easy enough, but as it also send out a controller 32, one of the CC parameters in the SammichSID will change every time I do a bank change. This is really bad... Quote
TK. Posted October 31, 2010 Author Report Posted October 31, 2010 Yes, this isn't nice... :-/ You could disable the assignment to CC#32 in src/sid_cc_table.inc replace: db 0x2c, 0x2d, 0x2e, 0x2f, 0x48, 0x4c, 0x00, 0x00 ; offset 0x20 [/code] by: [code] db 0x00, 0x2d, 0x2e, 0x2f, 0x48, 0x4c, 0x00, 0x00 ; offset 0x20 Best Regards, Thorsten. P.S.: please check your email inbox ;) Quote
Razmo Kefrens Posted November 1, 2010 Report Posted November 1, 2010 (edited) Yes, this isn't nice... :-/ You could disable the assignment to CC#32 in src/sid_cc_table.inc replace: db 0x2c, 0x2d, 0x2e, 0x2f, 0x48, 0x4c, 0x00, 0x00 ; offset 0x20 by: db 0x00, 0x2d, 0x2e, 0x2f, 0x48, 0x4c, 0x00, 0x00 ; offset 0x20 Best Regards, Thorsten. P.S.: please check your email inbox ;) Problem is that I'm not really skilled with assembling stuff TK... I've been away from coding and stuff for too long :) ... Many other synths have a feature to disable reception of Continous Controllers... maybe this would be an idear if you make any new changes to the software? I'm just amazed that SONAR has been working this way all these years... now that I look at the MIDI implementation of all my other gear that use either CC00 or CC32 for bank change, none of them has anything assigned to the other controller (MSB/LSB) so this is why it "works" with these machines... I have ONE machine that use controller 32 for something else, the Waldorf Pulse, but as it has only 100 patches, there is no need for a bank change which is why it works (SONAR gets this right though, only sending the patch change then). I wonder if Cubase or Logic does it the same way... My Email in box!?... I've changed email since last we spoke TK... try razmo666@gmail.com :twitch: Edited November 1, 2010 by Razmo Kefrens Quote
henrikgo Posted November 10, 2010 Report Posted November 10, 2010 (edited) Both me and my friend have a sammichSID and have both tried to run external sound sources through it. It all runs fine for a couple of seconds, the sound goes through the filter, then the sound disappears and you have to turn "ext in" in the filter section off and on again for it to work for another couple of seconds, then the sound disappears again. I'm sure it's not supposed to work like that? Edited November 10, 2010 by henrikgo Quote
Hawkeye Posted January 28, 2011 Report Posted January 28, 2011 (edited) Is it possible to improve the resolution of the mod matrix meter mode? (The feature itself as it is now is already ultra-cool, btw.) Currently it uses only 3 LEDs vertically to display the OSC values... maybe it´s a hardware or performance restriction, but wouldn´t it be nice to use 7 LEDs instead to visualize those nice sinus and other movements even better? Thanks and bye, Peter Edited January 28, 2011 by Hawkeye Quote
TK. Posted February 7, 2011 Author Report Posted February 7, 2011 It will use the full range once (for example) the LFO depth *and* the modulation path depth is set to maximum value. I could add a special parameter for adjusting the scaling, but I fear that nobody will really use it (and/or most will be confused about the parameter as some are already confused about the mysterious meter features at all ;) Best Regards, Thorsten. Quote
TK. Posted June 15, 2011 Author Report Posted June 15, 2011 RC38 is available now: RC38: o optimized MBNet Handler for fast external access to SID registers o added DEFAULT_CC32_FILTER switch to setup_*.asm - it filters CC#32 for programs which send this CC always together with CC#0 on bank changes o support for "extended SysEx dump" - see also mbsidv2_sysex_implementation.txt o filter mode/channel and waveform flags can now be optionally passed to J5 (configuration has to be done in setup_*.asm file) o (only for Multi Engine): "W+16" flag - waveform can be changed from offset +16 of the wavetable, in combination with another parameter (such as #249), it's possible to control pitch and waveform from a single WT track [/code] Note: due to the new MBNet Handler it's strongly recommended to update the firmware on all cores! Just use the cloning function: press&hold menu while power-on the MBSID and wait until firmware cloning is started. Best Regards, Thorsten. Quote
MPN Posted July 31, 2011 Report Posted July 31, 2011 Hi. I have some trouble with Super Poly Voice mode and AOut_NG. When SPV is selected it seems like the CV data is not forwarded to voice 2-4. The SID voices play but the SSM2044s and SSM2164s connected to core 2-4 via 3 AOut_NG are not updated? When playing on the keyboard the first voice (AOut_NG connected to Core 1, then to a SSM2044 and a SSM2164) plays normal, then there is 3 "holes", then first voice plays again. Best regards Magnus Quote
TK. Posted July 31, 2011 Author Report Posted July 31, 2011 Did you load the same patch into all 4 cores? Best Regards, Thorsten. Quote
MPN Posted August 1, 2011 Report Posted August 1, 2011 Hi. I don't have any controll surface and is using the Midibox SID editor. But there was some problem with my midi setup when I was usnig Miditrix. When I conected the midi directly to the GM5 Midi-module it was working. :-) Magnus Quote
TK. Posted August 1, 2011 Author Report Posted August 1, 2011 Great! :) Best Regards, Thorsten. Quote
TK. Posted April 1, 2012 Author Report Posted April 1, 2012 No, this is no april fool: MIDIbox SID V2 has left beta state after 5 years!!! ;-) (I removed the RC (release candidate) prefix) With V0.039 the LFO MIDI Clock synchronization has been improved, and the SysEx handling has been optimized for bidirectional communication with the upcoming Ctrlr based Editor. From the ChangeLog: V2.039: o LFO MIDI Clock Sync has been overworked, it now supports 32 different rates from 16 bars to 1/32 notes including triple and dotted delays! If the CSn flag enabled the available rates are: 0=LFO disabled, 8=16 bars, 16=14 bars, 24=12 bars, 32=10 bars, 40=9 bars, 48=8 bars, 56=7 bars, 64=6 bars, 72=5 bars, 80=4 bars, 88=3.5 bars, 96=3 bars, 104=2.5 bars, 112=2 bars, 120=1.5 bars, 128=1 bar, 136=1/2., 144=1/1T, 152=1/2, 160=1/4., 168=1/2T, 176=1/4, 184=1/8., 192=1/4T, 200=1/8, 208=1/16., 216=1/8T, 224=1/16, 232=1/32., 240=1/16T, 248=1/32 Note that in MIDI Sync mode, the LFO Delay won't work because the appr. resource is used as MIDI clock counter. o current bank and patch number won't be changed anymore on direct RAM access via SysEx [/code] And here a preview of the new editor: Currently all Lead Engine + Ensemble parameters (more than 1000!!!) can be accessed. The remaining engines will be implemented tomorrow, thereafter the panel should be ready for release. :) Best Regards, Thorsten. Quote
Altitude Posted April 1, 2012 Report Posted April 1, 2012 woot! Looks like I picked a good time to add some updates to mine.. Quote
matoz Posted April 2, 2012 Report Posted April 2, 2012 problem to recompile V2.039, it's me? see screen printrecompile problem.bmp Quote
jojjelito Posted April 2, 2012 Report Posted April 2, 2012 OMG! Bliss! If I hadn't already eaten the chocolate easter bunny at work I'd send some Quote
Hawkeye Posted April 2, 2012 Report Posted April 2, 2012 (edited) Great job! The MBSID Ctrlr UI looks mighty fine! Greets, Peter Edited April 2, 2012 by Hawkeye Quote
TK. Posted April 2, 2012 Author Report Posted April 2, 2012 problem to recompile V2.039, it's me? see screen print It's related to an assembler bug in an older gpasm version. Which version number is displayed with "gpasm --version"? I'm using: mbp:midibox_sid_v2_039 TK$ gpasm --version gpasm-0.13.7 beta mbp:midibox_sid_v2_039 TK$ make rm -rf *.cod *.lst *.err rm -rf *.hex gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_6581.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_8580.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_sammich_sid.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_tk.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_tk2.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout setup_mb6582.asm gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_io -I ./modules/aout sid_filter_table.asm [/code] Best Regards, Thorsten. Quote
matoz Posted April 2, 2012 Report Posted April 2, 2012 i uploaded the last release and it works. Thanks Quote
gslug Posted April 2, 2012 Report Posted April 2, 2012 (edited) Thanks TK Updated my MB-6582. All seems well. I can't wait to have a play with the new editor!:ike: Edited April 2, 2012 by gslug Quote
