This is my latest creation. You all know what I modified. :) Not completely finished as I need to wait Saturday to buy DIN connectors.
Mechanical counter will be put back in place and power LED needs to be connected.
Leaver of mechanical buttons are used to activate micro switches mounted at the same button holder plate that is cut out of the rest of the mechanics. Doors are swapped with piece of "smoked" transparent acrylic that is masked at the back and rest is sprayed with black paint. Only masked center for display is left clear. Writings are engraved and filled with acrylic paint. I add 4 hex screws more for aesthetically reasons than even they are holding the door against the rest of the casing. I need to think of some name for it to add it between door and buttons, so if you have some cool name for it in your mind you are welcome to propose it. Or I`ll call it just Data SID...
Here are few pix...
"Press Play" don`t sounds much like name to me, but it would be really cool as a sticker on it. I thought of adding it on LCD bootscreen. About the 1530... well, I already have 6581 on door, so it will be too much of noumbers. Thank you for your proposition.
I was referring to the C64 term PRESS PLAY ON TAPE
adding that to the bootscreen would be quite cool ;)
I have enough problems thinking up names for my own projects, let alone thinking of names for others. Why don't you just let it as is, 6581 is nice enough?
Thank you guys, I`m trying...
About the name.. well, I usually have no problem to think of name, but I see some super-cool names or nicks other think of all the time, so thought maybe other would name it better one. :)
Thanks Sepp. Der Brat is yours... one of the olders SIDs around. :) I was looking for drive like yours at flea market after I saw how it can looks good, but I had no luck finding one. I found one from Atari, made whole out of plastic but I dont like it so much.
Oh man, no... I`m modest. It would be too much... I just made nice case mod, nothing more... what is under the hood is what counts.
If you look with recycling eyes, inspiration comes easily. But, often recycling makes something looks trashy, like my Woody synth which is made that way deliberately, but personally I prefer something much finer.
Dammit!! That's exactly what I had planned to do, now you've beaten me to it! Actually, I couldn't find a cheap enough Datasetted, so i've been putting it off, you know how it goes ;)
Really nice job!
Sorry for being first. I thought of that long time ago, and it was strange to me nobody did it. So, I thought, It is final time to do it... ;D
you are AMAZING!!  :o
You should take a picture of your whole MB equipment
Xirod, right?  omg I love that font  :)
Excellent work, yet again.
I challenge you to make the mechanical counter show the patch number!
Thank you all, very much. I didn`t expected you will like it that much.
...Lord of Recycle I`m honored Mike!
I wanted to use bourns hollow encoder and connect it with belt to the counter, just for fun, but I gave up because I didnt like the quality of that encoder very much.
If you could interface one of those vintage LED watches (made by commodore) that come up on ebay, and get that to show patch numbers, or menu values as you turn the encoder, you would be the king of everything in my view ;)
Thank you guys. I love non-stop marker myself, and whenever I look at this synth I hear Kraftwerk in my head. Nice association. :)
I think for name I will go something like DATA SID, or LOAD!
@Jaicen
Integrating commodore watch instead of mechanical counter would be really cool, but even if I could do it, those watches are pretty expensive and would be really bad to kill just for that. C64 cannot do much useful things today, but watch is always useful, especially if it`s geeky commodore watch.
@Jaicen
I've still got a few LED calculator displays in 4 digit modules, if you want to try one of them. You could cheat an use one of the self scan 4 character LED displays that HP or Siemens did.
Might look fairly cool
