zid Posted August 22, 2007 Report Posted August 22, 2007 Hi there,think this might be interesting for the community...As I missed the LCD bulk order for Wilba's project, I was doing a little 'research' on the web where to get the Crystalfontz LCD for a reasonable price. Think I was successfull... :)Crystalfontz CFAH2004A-TMI-JP (the blue one) for just US$ 9.99 (plus shipping) at www.divineo.com (direct link http://www.divineo.com/cgi-bin/div-us/zz-xb-lcd-b.html). There is no minimum quantity (well, strangely the price per unit goes up the more you order ??? ).Unfortunately they only offer the blue and 'green' LCDs. But I'm just fine with the blue one.So maybe this is an alternative for other 'bulk-order-missers'... ;DI already ordered some. Will give you feedback once they arrive at my place!
zid Posted August 24, 2007 Author Report Posted August 24, 2007 ahh.. the LCDs arrived today.. just 2 days from US to Germany.. not bad!DSCN0173.JPG
nebula Posted August 29, 2007 Report Posted August 29, 2007 That's not the same display as the bulk order, but still - good find!
opkod Posted September 5, 2007 Report Posted September 5, 2007 I ordered 2 for 24€ including shipping costs.... ;)
levon Posted September 6, 2007 Report Posted September 6, 2007 sorry, Newb question.. but will these work with any MIOS midibox? or only Wilbas SID?thanks, Levon
Wilba Posted September 6, 2007 Report Posted September 6, 2007 It's a standard character LCD using the HD44780 industrial standard, the default LCD type for MIOS.The only thing worth noting is that white backlight LCDs are edge lit (not a LED array underneath)... they will therefore use less current (maybe only 60mA?) and the brightness control of the Core PCB might not work as expected - you can use a 100ohm resistor in series with +5v/ground to pins 15 and 16 as an alternative, if you are paranoid and worried about burning out the LEDs.
levon Posted September 8, 2007 Report Posted September 8, 2007 well i have ordered 2 of the blue ones, should take 3-4 weeks to get to australia... :(
opkod Posted September 10, 2007 Report Posted September 10, 2007 arrived this morning: 8) I only waited 5 days ;D
levon Posted September 15, 2007 Report Posted September 15, 2007 Was alot quicker then the website said, got my screens yesterday :D
Goblinz Posted September 19, 2007 Report Posted September 19, 2007 arrived this morning: 8) I only waited 5 days ;D Did they come packaged in the tins?
reboot Posted September 29, 2007 Report Posted September 29, 2007 helloi ordered 2 of them and...they're too big!the five buttons are covered with the lcd pcb so we have to cut the pcb to mount the buttonsdoes somebody noticed that? :-\
bugfight Posted September 29, 2007 Report Posted September 29, 2007 ...they're too big!the five buttons are covered with the lcd pcb so we have to cut the pcb to mount the buttonsit's mounted behind the cs pcb...
Wilba Posted September 30, 2007 Report Posted September 30, 2007 Yes, don't worry, you're supposed to mount the LCD behind the PCB.After you've used the PCB as a guide for mounting the spacers to the panel, you can solder the switches on, but for the switches that overlap the LCD's PCB, you should solder the pads on the top side, and cut the pins on the bottom - so you can mount the LCD close to the PCB. I will explain this more in the construction guide soon.
ganchan Posted January 23, 2008 Report Posted January 23, 2008 sorry, where you find crystalfotnz LCD for that cheap? i need some, if you can direct me i'll buy. thankyou.FCB Electronics Store on ebay..i ask, i answer :P
zid Posted January 24, 2008 Author Report Posted January 24, 2008 sorry, where you find crystalfotnz LCD for that cheap? i need some, if you can direct me i'll buy. thankyou.FCB Electronics Store on ebay..i ask, i answer :Pjust have a look at the link in my first post of this thread...divineo.com still sell these for 9.99 USD
otto Posted January 27, 2008 Report Posted January 27, 2008 Good price, better than any 20X2 prices I've found. I'm new and just about to order all the stuff to build my first basic midibox sid (and hopefully grow it from there). Will this work ok for that application or do I need to do something special to use the 20X4 format?
