Echopraxia Posted October 4, 2007 Posted October 4, 2007 Where is that picture of mike's banktick pcb schematic? I ordered one and remember seeing the diagram somewhere.
midiboxxer Posted October 4, 2007 Posted October 4, 2007 I think you mean this:http://www.ucapps.de/mbhp_bankstick.htmlLook at the bottom of the page.
Echopraxia Posted October 11, 2007 Author Posted October 11, 2007 I just got my bankstick pcbs from mike and I had a question. One side has the copper tracings and the other side is just plain bread board. My question is do the banksticks get placed on the bread board side ,then I flip the board over and solder the pins on the copper side correct? There is no nice legend like on smash's boards. I would hate to solder the banksticks on the wrong way. I don't need any dil sockets to mount the banksticks to the pcb right? Sorry that these are very simple questions which I should know by now but smash has spoiled me. ;D Also what are the pins to the right with the red line going down used for?
Davo Posted October 11, 2007 Posted October 11, 2007 I just got my bankstick pcbs from mike and I had a question. One side has the copper tracings and the other side is just plain bread board. My question is do the banksticks get placed on the bread board side ,then I flip the board over and solder the pins on the copper side correct? There is no nice legend like on smash's boards. I would hate to solder the banksticks on the wrong way. I don't need any dil sockets to mount the banksticks to the pcb right? Sorry that these are very simple questions which I should know by now but smash has spoiled me. ;D Also what are the pins to the right with the red line going down used for?What you have is a single-layer board. Parts go on the plain side (see the pictures for the correct alignment). About sockets, YES. Use sockets. The red line probably indicates where a jumper wire needs to be soldered. Again, check carefully.
Echopraxia Posted October 12, 2007 Author Posted October 12, 2007 Thanks for the reply. So I guess banksticks can be mounted on 8 pin Dual sockets? Banksticks seem so small is there a special type of socket? Has any one ordered these before. I asked mike if I need anything else when I ordered but never got a reply. Mike Help me out! :PIf I don't use sockets can I damage the bankstick when soldering?
audiocommander Posted October 13, 2007 Posted October 13, 2007 If I don't use sockets can I damage the bankstick when soldering?Yes, these chips are heat-sensitive. Get normal 8-pin sockets, they're just a few cents each.They are quite common, plain 8-pin IC sockets like the one for the optocuppler on the Core:eg at Reichelt: - GS8 for 0,03 EUR (!)- GS8P (golden contacts) for 0,10 EURBest,Michael
rbv2 Posted September 2, 2008 Posted September 2, 2008 hi alli also received a bankstick PCB from Mike.and of course i have a question.my banksticks are all soldered in like shown here: (with sockets ;) )http://www.midibox.org/forum/index.php?action=dlattach;topic=9981.0;attach=1636my question is regarding the pins: is the position of the pins the same like here?:http://www.ucapps.de/mbhp_bankstick.htmland is it still necessary to add the jumper-wire.i watched the copper traces for about a hour to find out about the pinning but ???is it possible to find out the pinning by using a multimeter?thank you allbtw. i also received my displays last week...switched on...aaaand its alive and says hello (READY) ;D feels good
ris8_allo_zen0 Posted September 4, 2008 Posted September 4, 2008 my banksticks are all soldered in like shown here: (with sockets ;) )http://www.midibox.org/forum/index.php?action=dlattach;topic=9981.0;attach=1636my question is regarding the pins: is the position of the pins the same like here?:http://www.ucapps.de/mbhp_bankstick.htmlYes, it is the same circuit.and is it still necessary to add the jumper-wire.Yes, it is necessary to bring Vcc to IC5-IC8.i watched the copper traces for about a hour to find out about the pinning but ???I can't fully understand your question. Anyway, try to imagine each chip rotated by 180 degrees. The "pin 1 marker", located in the ICs' upper side in the schematic and in their lower side in the board, says that.is it possible to find out the pinning by using a multimeter?Why not?Best regards, RAZ
rbv2 Posted September 4, 2008 Posted September 4, 2008 heythank you for the reply.i figured it out by changin the pins while mios was runnig.. ::)cant wait to get my frontpanel..thanksrbv2
