I made a TB-303 Clone and try to use my MIDIbox 64 as sequencer. My clone uses velocity to control the accent, so i have to control - note - velocity and note length with my MIDIbox. Is this possible?
I could control the note and the gate but not the velocity.
best regards,
??? Thomas  ???
Hi Thomas,
you can control note, velocity and gate at the same time with the 3 upper pot tracks in all modes beside of "independent mode" - best results in "transpose hold" and "arpeggiator hold" mode. :)
Yees, thank you. I tried i just in independent mode.   ::) But there is still a little problem. My tb plays a slide when i note is legato. The Slide Led is flashing on every note, it doesn't matter how short a note is. I tried this in combined mode. Is the MIDIbox playing every not legato? Is this possible?
Greetings,
8) Thomas
I made the one from LosDos Germany. Yes i'm very happy with it. I have an original to compare and they sound 99% the same. The schematic is exactly the same as the original. I think the difference exactable. The pcb was not the best and he used a 80C31 and an eeprom for the midi interface witch is a bit oversized and to expensive i think.
http://home.t-online.de/home/TB-303/tocd.htm
Thomas
