matrigs Posted November 27, 2007 Report Share Posted November 27, 2007 so, the question may seem a little weird but my local store will get 10k linear faders for me in january and i need some quick solution for my live sets until then !the problem is that the store provides just two other models: 10k log or 20k linear. now my question is - what option is better (assuming that nothing else comes into mind ?) - they are used for volume so maybe the logarhytmic ones ?(please don't answer things like: buy from another store or anything like that just stay focused please...) Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted November 27, 2007 Report Share Posted November 27, 2007 ... well to stay focused: Search the forum for a long answer. ;)Short: If you're building a controller, use the 20k lin.Greets, Roger Quote Link to comment Share on other sites More sharing options...
NorthernLightX Posted November 28, 2007 Report Share Posted November 28, 2007 ...they are used for volume... If you are pushing audio signal over them then I think to remember that volume potentiometers need to have a LOG taper. If insted the faders send digital data to a controller which then attenuates the analog audio signal you definitely need a LIN taper, like Screaming_Rabbit says. Quote Link to comment Share on other sites More sharing options...
