Hi all
I have no coding experience but a friend helped me very fast to write a piece of code, he said would do the job i want to be done with my core module. I'll post it here just to show, I'm not sure it's perfectly correct but that's not my problem. I don't know how to get this code onto the 18f4685. As I'm not coding myself the world of compilers and files seems huge. I've tried to play around in MPLAB, sdcc skeleton, using example programs etc, but I'm not getting very close. I figured i need to include some mios files, a pic file? (452 only choice?) but how, where, more precise.
short said i need some kinda step by step help to make this code a working hex  :) I'm into learning C so if i knew how to get code going with the MIOS i could go learning from there. I know it's a pretty big question but also advice leading in the right direction is much appreciated!
As you can see (i guess  :)), the code is supposed to output a bunch of data which i´ll connect to several shift registers and then LED´s giving one LED for each button on a digital piano, via MIDI. Im posting the code mostly because it might be funnier for you coders ^^
Thank You
#include "cmios.h"
#include "pic18f452.h"
#define BIT_CLOCK	0
#define BIT_LATCH	1
#define BIT_DATA	2
#define CHANNEL	1
#define NOTEON	0x90
#define NOTEOFF	0x80
#define NOTE_OFFSET 15
#define BITASSIGN( bit, val ) PORTA = ( PORTA & ~( 1 << bit ) ) | ( val << bit );
unsigned char min( unsigned char a, unsigned char b )
	return a < b ? a : b;
unsigned char buffer[ 11 ];
void Init( )
	TRISA &= ~( ( 1 << BIT_CLOCK ) | ( 1 << BIT_LATCH ) | ( 1 << BIT_DATA ) );
void Delay( )
	int i=0;
	for( i; i<1000; ++i );
void ShiftBits( )
	BITASSIGN( BIT_CLOCK, 1 );
	Delay( );
	BITASSIGN( BIT_CLOCK, 0 );
void LatchRegisters( )
	BITASSIGN( BIT_LATCH, 1 );
	Delay( );
	BITASSIGN( BIT_LATCH, 0 );
void UpdateLeds( )
	unsigned char j=0;
	unsigned char bit=0;
	for( j; j<11; ++j )
		for( bit; bit<8; ++bit )
			BITASSIGN( BIT_DATA, ( buffer[ j ] >> bit ) & 1 );
			ShiftBits( );
	LatchRegisters( );
void OnNoteOn( unsigned char note )
	buffer[ note >> 3 ] |= 1 << ( note & 7 );
	UpdateLeds( );
void OnNoteOff( unsigned char note )
	buffer[ note >> 3 ] &= ~( 1 << ( note & 7 ) );
	UpdateLeds( );
void USER_MPROC_NotifyReceivedEvent( unsigned char evnt0, unsigned char evnt1, unsigned char evnt2 )
	if( ( ( NOTEOFF | CHANNEL ) == evnt0 ) || ( ( ( NOTEON | CHANNEL ) == evnt0 ) && ( 0 == evnt2 ) ) )
		OnNoteOff( min( 0x6C, evnt1 - NOTE_OFFSET ) );
	else if( ( NOTEON | CHANNEL ) == evnt0 )
		OnNoteOn( min( 0x6C, evnt1 - NOTE_OFFSET ) );
In that case i could try to be more specific. I was following those steps before, downloaded perl, sdcc and gputils, installed it correctly etc. Here the help stops in the docs and info i can found on all the midibox pages.
Running make.bat on the "empty" main.c in the /sdcc_skeleton/ works without error. I figured i could use this method and get it to work with some more code added. I get some error but there might just be coding errors left then?
I'm currently including cmios.h and pic18f452.h
EDIT: worked it down to just one error i think, what can that be?
Here´s the compiling:
[tt]
Compiling main.c
Processor: 18F452
main.c:103: error 65: function 'Init' already has body
main.c:110: error 103: code not generated for 'Tick' due to previous errors
main.c:118: error 103: code not generated for 'Timer' due to previous errors
main.c:129: error 103: code not generated for 'DISPLAY_Init' due to previous err
ors
main.c:138: error 103: code not generated for 'DISPLAY_Tick' due to previous err
ors
main.c:145: error 103: code not generated for 'MPROC_NotifyReceivedEvnt' due to
previous errors
main.c:153: error 103: code not generated for 'MPROC_NotifyFoundEvent' due to pr
evious errors
main.c:161: error 103: code not generated for 'MPROC_NotifyTimeout' due to previ
ous errors
main.c:168: error 103: code not generated for 'MPROC_NotifyReceivedByte' due to
previous errors
main.c:175: error 103: code not generated for 'SR_Service_Prepare' due to previo
us errors
main.c:182: error 103: code not generated for 'SR_Service_Finish' due to previou
s errors
main.c:190: error 103: code not generated for 'DIN_NotifyToggle' due to previous
errors
main.c:199: error 103: code not generated for 'ENC_NotifyChange' due to previous
errors
main.c:206: error 103: code not generated for 'AIN_NotifyChange' due to previous
errors
ERROR!
[/tt]
Hi fsvo,
Just look at the first error:
[tt]main.c:103: error 65: function 'Init' already has body[/tt]
That tells you, that there are two Init() functions, and there are indeed:
- from main.c the emtpy skeleton method: void Init() {}
- from your code snippet: void Init() { TRISA &= ~( ( 1 << BIT_CLOCK ) | ( 1 << BIT_LATCH ) | ( 1 << BIT_DATA ) ); }
Just merge your code properly into main.c
Not sure about the USER_NotifyReceivedEvent() method in your snippet; I never worked with the USER_ namespace, maybe that's okay - I'd use the MPROC_NotifyReceivedEvent() from main.c if it does not receive any MIDI Messages as expected
Best,
Michael
As for the compile error...
That's your problem. Take a look at line 103. It's your code:
void Init( )
Now look at line 35:
void Init(void) __wparam
Uh oh.
Now you *could* just rename your function to like... myinit() or something... but... All that bitbanging, you don't need it. It's in MIOS already. Scope out the LOAD SR stuff in the function reference :)
Edit: Beaten. Hi AC :D
Thanks guys, awesome, i shoud've figured that one out by myself. Im getting a sucessful compile that feels great. I will see later today how well it works after an upload, i guess not very good the first try  ;D
OK as i mentioned i'm using the 4685 with the 452.h file. Is this a problem? I tried upload the hex now but the display dies after rebooting MIOS and nothing seem to work. Actually even the sdcc skeleton 1.9 template program only running a "Hello World" on the display isn't displaying a Hello World. I can't find a .h file for 4685 anywhere on the net. Is this my problem anyway?
- Use the pic18f4685.h provided with sdcc (or better pic18fregs.h if you can make portable code)
- Don't forget to fix the asm generated by sdcc with the provided perl script
- Link with the following modified pic18f4685.lkr linker script
... and all should compile and work well!
pic18f4685.lkr :
// linker script for a MIOS project
// Thorsten Klose (tk@midibox.org), 2004-07-10
LIBPATH .
CODEPAGE   NAME=vectors    START=0x2C00         END=0x2FFF         PROTECTED
CODEPAGE   NAME=page       START=0x3000         END=0x17FFF
CODEPAGE   NAME=idlocs     START=0x200000       END=0x200007       PROTECTED
CODEPAGE   NAME=config     START=0x300000       END=0x30000D       PROTECTED
CODEPAGE   NAME=devid      START=0x3FFFFE       END=0x3FFFFF       PROTECTED
CODEPAGE   NAME=eedata     START=0xF00000       END=0xF003FF       PROTECTED
DATABANK   NAME=miosvars   START=0x000          END=0x00F
ACCESSBANK NAME=accessram  START=0x010          END=0x05F
DATABANK   NAME=gpr0       START=0x060          END=0x0FF
DATABANK   NAME=gpr1       START=0x100          END=0x1FF
DATABANK   NAME=gpr2       START=0x200          END=0x2FF
DATABANK   NAME=stack      START=0x300          END=0x37F          PROTECTED
DATABANK   NAME=miosram_u  START=0x380          END=0x5FF          PROTECTED
DATABANK   NAME=gpr3       START=0x600          END=0x6FF
DATABANK   NAME=gpr4       START=0x700          END=0x7FF
DATABANK   NAME=gpr5       START=0x800          END=0x8FF
DATABANK   NAME=gpr6       START=0x900          END=0x9FF
DATABANK   NAME=gpr7       START=0xA00          END=0xAFF
DATABANK   NAME=gpr8       START=0xB00          END=0xBFF
DATABANK   NAME=gpr9       START=0xC00          END=0xCFF
DATABANK   NAME=sfr13      START=0xD00          END=0xDFF          PROTECTED
DATABANK   NAME=sfr14      START=0xE00          END=0xEFF          PROTECTED
DATABANK   NAME=sfr15      START=0xF00          END=0xF5F          PROTECTED
ACCESSBANK NAME=accesssfr  START=0xF60          END=0xFFF          PROTECTED
SECTION    NAME=CONFIG     ROM=config
Thanks again. I also took the easy way and switched to a 452 and it's working now :) I will however look into your advice for other projects  ptitjes. Now i just need to work some more on the code, it's not working exactly as intended with my shift register setup yet.
I will come back and show u the result of the porject when it's done  :)
Uhm...........
Yes, I would also propose to use the integrated shift register handling of MIOS, it is *much* faster, and there are many C examples for the usage (see bottom of http://www.ucapps.de/mios_c.html)
In addition, it makes sense to play a little with the examples in order to get a feeling about the programming model.
What I'm missing in your C code is the initialisation of the IO pins at J5. By default these are analog pins, in order to enable the digital stage, following value has to be written into ADCON1:
ADCON1 = 0x07;
In addition, I would propose to set the pins directly on the following way:
LATAbits.RA0 = 1;
and
LATAbits.RA0 = 0;
This will result into a single instruction. The currently used "BITASSIGN" macro will probably generate 10 instructions or more
Anyhow, as mentioned above: try some programming examples first, and especially consider the usage of the natively supported SRIO chain
