fsvo Posted December 13, 2007 Report Posted December 13, 2007 Hi allI have no coding experience but a friend helped me very fast to write a piece of code, he said would do the job i want to be done with my core module. I'll post it here just to show, I'm not sure it's perfectly correct but that's not my problem. I don't know how to get this code onto the 18f4685. As I'm not coding myself the world of compilers and files seems huge. I've tried to play around in MPLAB, sdcc skeleton, using example programs etc, but I'm not getting very close. I figured i need to include some mios files, a pic file? (452 only choice?) but how, where, more precise.short said i need some kinda step by step help to make this code a working hex :) I'm into learning C so if i knew how to get code going with the MIOS i could go learning from there. I know it's a pretty big question but also advice leading in the right direction is much appreciated!As you can see (i guess :)), the code is supposed to output a bunch of data which i´ll connect to several shift registers and then LED´s giving one LED for each button on a digital piano, via MIDI. Im posting the code mostly because it might be funnier for you coders ^^Thank You #include "cmios.h" #include "pic18f452.h" #define BIT_CLOCK 0 #define BIT_LATCH 1 #define BIT_DATA 2 #define CHANNEL 1 #define NOTEON 0x90 #define NOTEOFF 0x80 #define NOTE_OFFSET 15 #define BITASSIGN( bit, val ) PORTA = ( PORTA & ~( 1 << bit ) ) | ( val << bit ); unsigned char min( unsigned char a, unsigned char b ) { return a < b ? a : b; } unsigned char buffer[ 11 ]; void Init( ) { TRISA &= ~( ( 1 << BIT_CLOCK ) | ( 1 << BIT_LATCH ) | ( 1 << BIT_DATA ) ); } void Delay( ) { int i=0; for( i; i<1000; ++i ); } void ShiftBits( ) { BITASSIGN( BIT_CLOCK, 1 ); Delay( ); BITASSIGN( BIT_CLOCK, 0 ); } void LatchRegisters( ) { BITASSIGN( BIT_LATCH, 1 ); Delay( ); BITASSIGN( BIT_LATCH, 0 ); } void UpdateLeds( ) { unsigned char j=0; unsigned char bit=0; for( j; j<11; ++j ) for( bit; bit<8; ++bit ) { BITASSIGN( BIT_DATA, ( buffer[ j ] >> bit ) & 1 ); ShiftBits( ); } LatchRegisters( ); } void OnNoteOn( unsigned char note ) { buffer[ note >> 3 ] |= 1 << ( note & 7 ); UpdateLeds( ); } void OnNoteOff( unsigned char note ) { buffer[ note >> 3 ] &= ~( 1 << ( note & 7 ) ); UpdateLeds( ); } void USER_MPROC_NotifyReceivedEvent( unsigned char evnt0, unsigned char evnt1, unsigned char evnt2 ) { if( ( ( NOTEOFF | CHANNEL ) == evnt0 ) || ( ( ( NOTEON | CHANNEL ) == evnt0 ) && ( 0 == evnt2 ) ) ) OnNoteOff( min( 0x6C, evnt1 - NOTE_OFFSET ) ); else if( ( NOTEON | CHANNEL ) == evnt0 ) OnNoteOn( min( 0x6C, evnt1 - NOTE_OFFSET ) ); } Quote
nILS Posted December 13, 2007 Report Posted December 13, 2007 Thanks for sharing the source.Yes, it's a big question, BUT it's been answered: http://www.midibox.org/dokuwiki/application_development Quote
fsvo Posted December 13, 2007 Author Report Posted December 13, 2007 In that case i could try to be more specific. I was following those steps before, downloaded perl, sdcc and gputils, installed it correctly etc. Here the help stops in the docs and info i can found on all the midibox pages.Running make.bat on the "empty" main.c in the /sdcc_skeleton/ works without error. I figured i could use this method and get it to work with some more code added. I get some error but there might just be coding errors left then?I'm currently including cmios.h and pic18f452.hEDIT: worked it down to just one error i think, what can that be?Here´s the compiling:[tt]Compiling main.cProcessor: 18F452main.c:103: error 65: function 'Init' already has bodymain.c:110: error 103: code not generated for 'Tick' due to previous errorsmain.c:118: error 103: code not generated for 'Timer' due to previous errorsmain.c:129: error 103: code not generated for 'DISPLAY_Init' due to previous errorsmain.c:138: error 103: code not generated for 'DISPLAY_Tick' due to previous errorsmain.c:145: error 103: code not generated for 'MPROC_NotifyReceivedEvnt' due toprevious errorsmain.c:153: error 103: code not generated for 'MPROC_NotifyFoundEvent' due to previous errorsmain.c:161: error 103: code not generated for 'MPROC_NotifyTimeout' due to previous errorsmain.c:168: error 103: code not generated for 'MPROC_NotifyReceivedByte' due toprevious errorsmain.c:175: error 103: code not generated for 'SR_Service_Prepare' due to previous errorsmain.c:182: error 103: code not generated for 'SR_Service_Finish' due to previous errorsmain.c:190: error 103: code not generated for 'DIN_NotifyToggle' due to previous errorsmain.c:199: error 103: code not generated for 'ENC_NotifyChange' due to previous errorsmain.c:206: error 103: code not generated for 'AIN_NotifyChange' due to previous errorsERROR![/tt] Quote
audiocommander Posted December 13, 2007 Report Posted December 13, 2007 Hi fsvo,Running make.bat on the "empty" main.c in the /sdcc_skeleton/ works without error. I figured i could use this method and get it to work with some more code added. I get some error but there might just be coding errors left then?Just look at the first error:[tt]main.c:103: error 65: function 'Init' already has body[/tt]That tells you, that there are two Init() functions, and there are indeed:- from main.c the emtpy skeleton method: void Init() {}- from your code snippet: void Init() { TRISA &= ~( ( 1 << BIT_CLOCK ) | ( 1 << BIT_LATCH ) | ( 1 << BIT_DATA ) ); }Just merge your code properly into main.cNot sure about the USER_NotifyReceivedEvent() method in your snippet; I never worked with the USER_ namespace, maybe that's okay - I'd use the MPROC_NotifyReceivedEvent() from main.c if it does not receive any MIDI Messages as expectedBest,Michael Quote
stryd_one Posted December 13, 2007 Report Posted December 13, 2007 As for the compile error...main.c:103: error 65: function 'Init' already has bodyThat's your problem. Take a look at line 103. It's your code: void Init( ) { TRISA &= ~( ( 1 << BIT_CLOCK ) | ( 1 << BIT_LATCH ) | ( 1 << BIT_DATA ) ); } Now look at line 35: void Init(void) __wparam { }Uh oh.Now you *could* just rename your function to like... myinit() or something... but... All that bitbanging, you don't need it. It's in MIOS already. Scope out the LOAD SR stuff in the function reference :)Edit: Beaten. Hi AC :D Quote
audiocommander Posted December 13, 2007 Report Posted December 13, 2007 hehe... S1 is back ;D cheers, mate Quote
stryd_one Posted December 13, 2007 Report Posted December 13, 2007 Hahah I'm 10 pages of unread posts deep... ahhhh!Good to see you bud :D Quote
fsvo Posted December 13, 2007 Author Report Posted December 13, 2007 Thanks guys, awesome, i shoud've figured that one out by myself. Im getting a sucessful compile that feels great. I will see later today how well it works after an upload, i guess not very good the first try ;D Quote
fsvo Posted December 13, 2007 Author Report Posted December 13, 2007 OK as i mentioned i'm using the 4685 with the 452.h file. Is this a problem? I tried upload the hex now but the display dies after rebooting MIOS and nothing seem to work. Actually even the sdcc skeleton 1.9 template program only running a "Hello World" on the display isn't displaying a Hello World. I can't find a .h file for 4685 anywhere on the net. Is this my problem anyway? Quote
audiocommander Posted December 13, 2007 Report Posted December 13, 2007 IMHO you have to edit the 452.h file; don't think there's a 685.h file around -http://www.midibox.org/dokuwiki/mios_pic18f4685Though I guess the PIC selection got easier with the latest MIOS releases, maybe stryd knows more about this?I always took the easy way and bought 452's instead ;)best,Michael Quote
ptitjes Posted December 14, 2007 Report Posted December 14, 2007 - Use the pic18f4685.h provided with sdcc (or better pic18fregs.h if you can make portable code)- Don't forget to fix the asm generated by sdcc with the provided perl script- Link with the following modified pic18f4685.lkr linker script... and all should compile and work well!pic18f4685.lkr : // linker script for a MIOS project // Thorsten Klose (tk@midibox.org), 2004-07-10 LIBPATH . CODEPAGE NAME=vectors START=0x2C00 END=0x2FFF PROTECTED CODEPAGE NAME=page START=0x3000 END=0x17FFF CODEPAGE NAME=idlocs START=0x200000 END=0x200007 PROTECTED CODEPAGE NAME=config START=0x300000 END=0x30000D PROTECTED CODEPAGE NAME=devid START=0x3FFFFE END=0x3FFFFF PROTECTED CODEPAGE NAME=eedata START=0xF00000 END=0xF003FF PROTECTED DATABANK NAME=miosvars START=0x000 END=0x00F ACCESSBANK NAME=accessram START=0x010 END=0x05F DATABANK NAME=gpr0 START=0x060 END=0x0FF DATABANK NAME=gpr1 START=0x100 END=0x1FF DATABANK NAME=gpr2 START=0x200 END=0x2FF DATABANK NAME=stack START=0x300 END=0x37F PROTECTED DATABANK NAME=miosram_u START=0x380 END=0x5FF PROTECTED DATABANK NAME=gpr3 START=0x600 END=0x6FF DATABANK NAME=gpr4 START=0x700 END=0x7FF DATABANK NAME=gpr5 START=0x800 END=0x8FF DATABANK NAME=gpr6 START=0x900 END=0x9FF DATABANK NAME=gpr7 START=0xA00 END=0xAFF DATABANK NAME=gpr8 START=0xB00 END=0xBFF DATABANK NAME=gpr9 START=0xC00 END=0xCFF DATABANK NAME=sfr13 START=0xD00 END=0xDFF PROTECTED DATABANK NAME=sfr14 START=0xE00 END=0xEFF PROTECTED DATABANK NAME=sfr15 START=0xF00 END=0xF5F PROTECTED ACCESSBANK NAME=accesssfr START=0xF60 END=0xFFF PROTECTED SECTION NAME=CONFIG ROM=config Quote
fsvo Posted December 14, 2007 Author Report Posted December 14, 2007 Thanks again. I also took the easy way and switched to a 452 and it's working now :) I will however look into your advice for other projects ptitjes. Now i just need to work some more on the code, it's not working exactly as intended with my shift register setup yet.I will come back and show u the result of the porject when it's done :) Quote
stryd_one Posted December 15, 2007 Report Posted December 15, 2007 i just need to work some more on the code, it's not working exactly as intended with my shift register setup yet.Uhm.............. All that bitbanging, you don't need it. It's in MIOS already. Scope out the LOAD SR stuff in the function reference :) Quote
TK. Posted December 15, 2007 Report Posted December 15, 2007 Yes, I would also propose to use the integrated shift register handling of MIOS, it is *much* faster, and there are many C examples for the usage (see bottom of http://www.ucapps.de/mios_c.html)In addition, it makes sense to play a little with the examples in order to get a feeling about the programming model.What I'm missing in your C code is the initialisation of the IO pins at J5. By default these are analog pins, in order to enable the digital stage, following value has to be written into ADCON1:ADCON1 = 0x07;In addition, I would propose to set the pins directly on the following way:LATAbits.RA0 = 1;andLATAbits.RA0 = 0;This will result into a single instruction. The currently used "BITASSIGN" macro will probably generate 10 instructions or moreAnyhow, as mentioned above: try some programming examples first, and especially consider the usage of the natively supported SRIO chainBest Regards, Thorsten. Quote
