user_projects
MIDIbox User Projects
This space is for user projects and project documentations.
Projects don't have to be finished, works in progress should also be linked here!
For a complete overview of official projects see the MBHP Projects page!
<box 47% left blue|Controllers>
Completed
- Protodeck - Ableton Live Controller
- Pedal Box / Board- Expression Pedal Controller / Floorboard
- Stukontrol- MIDI Controller
- Modulbox- Modular Control Surface
- Questionable- DJ Controller
- Selektor- DJ Controller
- TOS - DJ Controller
- ACSensorizer - Sensorizing controller
- Arkade Joysticks, Distance sensors, Ribbons Controller
- MIDIboxKB- C64 keyboard as input
- VOIRINOV- Akai MPD24-like MIDIbox
- MIDIbox UC - Universal Control: Extended SysEx Handler
- MB-LRE8x2- 16 Led rings encoders
In Progress
- MB-Modulbox-NG Modular Controllers
- MB_OLRE16- 1 row of 16 encoders with oleds and 32 segments RGB led rings.
</box>
<box 47% right red|Synthesizers>
Completed
- MB-6582- MIDIbox SID Synthesizer V2 using 8xSID PCB and “step C” control surface PCB.
- MB-TWINsid- MIDIbox SID Synthesizer V2 using 2xSID PCB and dedicated control surface PCB .
- SID R8TR- 3U rackmount case SID
- MIDIbox FM V2.1 - A complete multitimbral synth using two OPL3s and the STM32F4 core
- OPL3 module, modified - 5V option
- MIDIbox VGM Player - Plays VGM files on up to four Sega Genesises' sound chips (YM2612/YM3438, SN76489/SN76494/SN76496)
- Apparat 20 - Seppoman's MBFM & vocoder phone
- Antix MBFM - A MBFM Build by Antix
- MIDIbox SpeakJet - SpeakJet speech synthesizer
- MIDIbox SpeakJet K64 Modul - C64 Keyboard Controller for SpeakJet
- MIDIbox TIA - Atari 2600 Synthesizer
- MIDIbox AY (YM) V2 - AY-3-891x / YM2149 Synth
- Coresound - Pic based digital synthesizer
In Progress
- MB-ReSynth - 4U FM/TIA/SID Synths
- MB-DigiRoland - Roland Analog Drums driven by digital Pots
- MIDIbox Quad Genesis - Up to four Sega Genesises' worth of sound chips, controlled by STM32F4 core. 4x YM2612 OPN2, 4x SN76489/94/96 PSG
- MIDIbox SNES APU - Super Nintendo APU synth
- MIDIbox POKEY - Atari Pokey synth
- MIDIbox 3396 - CEM3396 based synth
- MIDIbox SD Card Sample Player - SD Card Polyphonic Sample Player
</box>
<box 47% left green|Miscellaneous>
Completed
- MIDIbox Mixer based on PGA chips
- MIDIbox Matrix - MIDI I/Os Matrix
- MIDI Mapper - MIDI Channel Mapper
- MB Clock - How to handle a realtime clock (RTC) with I2C
- SSM2044 VCF - Low pass filter board
- clock2audio2clock - Record/Playback Midiclock via Audio-Recording
In Progress
- MB Sync24 - Midi clock to Roland sync24 converter
- MB Visual Metronome - Midi Metronome
- MidiboxDMX - DMX light control with Midibox
- MBlight Mind-Machine - an audio/visual brain stimulator
- mb-scope - 6ins+2sync Dual TFT Scope
- MIDIbox Audio Matrix - digitally controlled analogue audio/CV patch router
- MIDIbox Live - Complete and automatic integration of MIDIbox and Ableton Live using LiveAPI.
- SSM2164 VCA - Quad channel VCA board
- EASY CV - EuroRack-sized - 8x LFO+ENV-combi with 8AOUTChannels for VCA-VCF based Setups
- MIDIbox 2069 - Based on the KORG NJM2069 Music Voicing System
</box>
<box 47% right orange|Sequencers>
Completed
- BLM16x16+X Matrix Controller
- TPD - Track Position Display
- BLM 16x4 - Button LED Matrix
- MIDIbox Arp - A MBHP Arpeggiator
- DSEQ32 - 32 step drumseq
- Chaos Matrix Oberheim Matrix 1000 Programmer
In Progress
- Triggermatrix - 16track Trigger-Sequencer & Trigger-router - a liveact based center of a midisetup
- 16th fixed PolySequencer - 16th fixed 2x4track-poly-Sequencer - the poly note/melody-source for Triggermatrix
- AlternativeSequencer - Alternative ideas for sequencers
- MB808 - 808 Clone Sequencer
- MB909 - 909 Full Clone
</box>
user_projects.1512097501.txt.gz · Last modified: 2017/12/01 03:05 by phatline
