Patience. Patience. Patience.
Patience was never a strong trait of mine, at least when I'm obsessing on something. This MB-6582 project is certainly my main obsession right now, and I've run into another snag that I can only blame myself for.
I was not expecting to be able to get any work done last night, but the opportunity came up. So, I started putting in the tactile switches into the CS PSB. When working on the CS, I'm following Hawkeye's amazing thread. I rocked step 6 while in a zone of meticulousness and awareness.
I hit step 7, which just involved popping in the remaining switches without having to snip off any leads, and I got impatient. Maybe I was tired. I didn't re-read Hawkeye's instructions. I put in the switches and soldered them in record time. While I'll admit my soldering technique is getting pretty efficient, I didn't solder them on while my front panel was attached. The front panel will go on after about 40sec to a minute of fiddling. Hmmmmm. I don't think that will work for the JB-Weld step (I believe step 9 in the tutorial.)
So, let this be a lesson to you so that you don't make the mistakes I did here.
Read and follow directions.
Do not rush.
Have patience.
At 41 years old, you'd think I'd know by now. This is the price of being a still very excitable kid at heart, I suppose.
So, I have two options at this point.
- I could just go for broke and take a chance on mucking up my beautiful obnoxious new front panel. If I do this, every time I have to remove and replace the front panel from the CS board, it'll be a pain in the butt. However, once I finish this (assuming that me and my front panel survive the gluing stage) I shouldn't be needing to remove the front panel very much. I'll be too busy rocking out. (Famous last words)
- I could get a new CS board. I wouldn't need to order any new parts, as I have enough diodes and switches to populate another board. This option will pretty much ruin any chances of finishing this project in time for the concert.
I'm leaning towards #2. I sent an email to SmashTV to see if he can hook me up with just a CS board. We'll see.
Hawkeye, have you any words of wisdom?
5 Comments
