pawaga
23 -
Gender
Male
Location
France
Recent Profile Visitors
pawaga's Achievements
2
hi, here is a bug report. i made a fresh session with 4 drum tracks (64/2*64) on group 1. Copied the 4 track from group 1 to groups 2 3 4. On group 1, everything is fine, but in groups 2-4, track 3 has a weird behaviour : active steps are skipped. I joined a zip containing the session. Best regard. mbseq_debug.zip
hi, here is what i've done with some pieces of wood, aluminium and acriglass i had around, very cheap and yes, it's really usefull :) that way, i can use my seq also flat when i wish.
MIDIbox SEQv4 - Wilba Frontpanel - Round Buttons - Request
pawaga replied to jzurd0's topic in MIDIbox SEQ
@mongrol yes it's possible to shave a bit the panel, maybe 1cm on each side, if you tie the cs to bottom. it would be a cool evolution. i did it that way because i'm too lazy to redesign the whole thing ! here is the original acrylic layout : @EsotericLabs i don't think i will use an ethernet module as i don't have use of the OSC and probably won't..i did not knew that when i build it, so.. i put an ethernet plug to fill the hole, to avoid *bugs* to come in. You will says that there are some holes on the sides, but those are for bees. -
about the usb panel mount screw holes, i send an updated version of the svg file in the original post, i'm not sure it's 100% perfect but it should be good now. Of course you should check with datasheets if possible. -
yes it is ! cheapo panel mount usb and ethernet plugs, from the bay. *beware* of the screw holes for the usb adapter, they are a little bit too distant (~1mm each ; it works as it is but it should be better). Here is the regulator board layout, adapted from the ambika schematics : -
@mongrol yes, the cs is mounted with 10mm standoff, the midi io and quad iic are mounted on 12 mm standoff. the core on 10mm standoff. there are also 6 extra standoff from cs to bottom, they are ~ 61mm long : 2x 25mm + 1x10mm + 1 washer to make it really tight here is a shoot of the inside : -
yes, they are cheap, but there is a cost for that : they do not fit exactly with standard tact switch : i had to put some tiny piece of wood inside the caps to allow them to push correctly the switch.. not a big deal but it has to be said -
the caps are chip one from ebay, like those : http://www.ebay.fr/itm/25-Pcs-Round-Tact-Tactile-Piano-Key-Switch-Caps-Pushbutton-Covers-Gray-/231735004579?hash=item35f47b8da3:g:zS0AAOSwA4dWMYFE the top diameter is 9mm. -
hi, if you want to go the ponoko route, i made a design with rounded buttons.. It can be a bit better as the button holes are a bit loo large for mine (~0.5mm, but it's still good enough) : the laser beam size must be included, so beware of that.. Fortunately, here is the svg file so you can modify it if needed :) seq_enclosure_pvi_3.svg.zip seq_enclosure_pvi_3b.svg.zip -
hi, some troubles with the USB Host support here : i use a k-board which works fine on a pc. if used with the midiseq, sometimes, the noteoff or noteon events are lost. It seems to happen randomly though only when the sequencer is running...
hi, i just wanted to share my view : some times ago, i experimented a custom firmware which use the delay layer to record that human touch ; that way we can use the benefit of the 384ppqn, for any step resolution.. it would also be much easier that way to view and modify the quantization, re-quantize the whole pattern, use different quantization methods... The way i did it is just a hack and it would be better written in a proper way (with a bipolar % of the the step length, from -50% to +50%..). Maybe an idea for the seqV4+ ? best regards, Patrice
- 8 replies
- ticks
- unquantized
(and 2 more)
Tagged with:
hello Thorsten, thanks for your help, i understand now. yes, i tested it and it work now for different clock dividers ! i also added the quantization : } else { //handle the delay layer // if a delay layer is present, record to it u8 num_p_layers = SEQ_PAR_NumLayersGet(track); u8 *layer_type_ptr = (u8 *) & tcc->lay_const[0 * 16]; int par_layer; u8 instrument = 0; u16 delay; for (par_layer = 0; par_layer < num_p_layers; ++par_layer, ++layer_type_ptr) { if (*layer_type_ptr == SEQ_PAR_Type_Delay) { delay = ((SEQ_BPM_TickGet() - t->rec_timestamp ) * 96) / t->step_length; if( delay >= 96 ) delay -= 96; // because quantisation has put the event into the next step delay -= (delay * seq_record_quantize) / 100;//quantize it SEQ_PAR_Set(track, ui_selected_step, par_layer, instrument, delay ); break; } } } The next point i want to tackle is the pitch layer : discrete values are not very useful for that, it would be nice to glide values between two step...(for CCs as well) best regards Patrice
hi, the "delay" layer is not recorded in live rec mode, so i tried something : I added this in seq_record.c, around line 472 : } else { //handle the delay layer // if a delay layer is present, record to it u8 num_p_layers = SEQ_PAR_NumLayersGet(track); u8 *layer_type_ptr = (u8 *) & tcc->lay_const[0 * 16]; int par_layer; u8 instrument = 0; u8 delay; for (par_layer = 0; par_layer < num_p_layers; ++par_layer, ++layer_type_ptr) { if (*layer_type_ptr == SEQ_PAR_Type_Delay) { delay = (SEQ_BPM_TickGet() - t->rec_timestamp) / 4; // not sure about the "/4", but give weird results if the delay val is too large SEQ_PAR_Set(track, ui_selected_step, par_layer, instrument, delay ); break; } } } it works but not very accurate... Anyway , so far, i like it! best regards Patrice
it works great now. thanks a lot !
About the nth feature, I think there is a problem with drum tracks : if i set a nth param on a step, it will work until another drum play on the same step.
