Zam
Posts
625 -
Joined
Last visited
Days Won
26
Content Type
Profiles
Forums
Blogs
Gallery
Posts posted by Zam
Hello
Did you check the analog side ? I mean the pots to multiplexer path ?
If you make the 8 pot wiper like a single bus...
Best
Zam
- 1
2 hours ago, TK. said:
My first KiCAD project - I don't miss xcircuit and Eagle & I'm happy that other people can now edit the files with state-of-the-art open source SW as well :-)
KiCAD is great ! Glad you switch
Best
Zam
Hello
Why not just use a resistor/fuse (or resetable fuse) and a zener ?
Best
Zam
Hello Thorsten
I have something like "MF_HD" in head since time but don't start because of no more real need for me (I have my motor driver)
It's hybrid, between MF_NG and My 89MotioN, in all aspect probably (cost, quality and performance)
Your two AD scan from fader servo seem to show improved noise at 200kHz.
Best
Zam
8 hours ago, TK. said:
Depends on the desired resolution for the duty cycle. The timers are clocked at 80 MHz
Means: with 20 kHz we could have 4000 different "speed levels" (but actually I'm currently only using 64 speed levels, which is sufficient)Ok ! don't know what is the agenda or if any major MFNG update is on the road (which I can help on by the way...)
I suggest to factor at least 10 the clock in case of hybrid system (analog close to or in the fader...)
let say 312.5kHz , which correspond to 256 speed level (you have room over 64...) also a value over 192kHz (HD audio)
I mean If it's easy don't hesitate to change this...
Best
Zam
On 14/12/2019 at 8:23 PM, TK. said:
I'm now able to control motorfaders, and the accuracy is much better than ever before, because dedicated PWM outputs are used (which are normally intended to fade LEDs), clocked at non-audible 20kHz range
Hello Thorsten
That's interesting, what is the max possible clock speed ?
Best
Zam
Hi all
Look promising
Especially if RTPM via wifi is implemented
Best
Zam
Hello
Fader are just pot, 3 pin, you should find the pinout within 30 sec with a ohm meter...
The pin that have variable resistance (across any two other) when moving the fader is the wiper
The two pin that have fixed resistance when moving the fader are 0 and Vref
The pin across the wiper which indicate low resistance when moving the fader down is the 0v
The pin across the wiper which indicate low resistance when moving the fader up is the Vref
Best
Zam
Hey TK
Just now, TK. said:Second: you could simply toggle between the two values 0x10 and 0x01, and insert it into the SysEx string via ^val:
of course...my bad
Best
Zam
1 hour ago, ssp said:
let me know if this is correct
event_button id=1 fwd_id=sender:1 range=0:127 button_mode=toggle
event_sender hw_id=1 id=1000 fwd_id=led:1 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x10 0xf7" if_equal=0
event_sender hw_id=1 id=1001 fwd_id=led:1 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x01 0xf7" if_equal=127
ok so looking at this
event_button id=1 #This is the event (button press) id=1 this is the first button on shift register 1=D0
fwd_id=sender:1 #this forwards the event_button idno!!! it forward the button value to the sender event with hw_id 1range=0:127 #midi value range
button_mode=toggle #button type
event_sender hw_id=1 #this is the event id that was forwarded to the senderNO this is the sender event with his IDid=1001 #this gives the event an id (could this be a number say 01 then the second 02?)
Have a look at id= and hw_id= there is difference
when using same hw_id you better use id out of the hardware range (1-256) to a avoid cross forwarding because an event without hw_id definition with take the id definition as hw_id too
then it's up to your logic to choose a comprehensive patern
fwd_id=led:1 this turns on the dout led 1 on shift register pin 1
type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x01 0xf7" # this is the transmitted sysex stream
if_equal=127 # this is the on off state of the toggle button either off=0 or on=127
This is the input condition for the sender to be active, meaning sending the sysex
Best
Zam
Hello
If you need more toggle steps use a map for value
MAP 1 2 3 4
in event button range=map1 the button value will toggle 1,2,3,4,1,2,3......
and 4 sender with contitional if_equal=1.... if_equal=4
i think i made a mistake you have to separate the fwd_id led (otherwise led will get the sysex and not the button value)
event_button id=1 fwd_id=sender:1 range=0:127 button_mode=toggle event_sender hw_id=1 id=1000 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x10 0xf7" if_equal=0 event_sender hw_id=1 id=1001 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x01 0xf7" if_equal=127 event_sender hw_id=1 id=1002 fwd_id=led:1:0 if_equal=0 event_sender hw_id=1 id=1003 fwd_id=led:1:1 if_equal=127
Best
Zam
Hello
You can do it this way:
event_button id=1 fwd_id=sender:1 range=0:127 button_mode=toggle event_sender hw_id=1 id=1000 fwd_id=led:1 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x10 0xf7" if_equal=0 event_sender hw_id=1 id=1001 fwd_id=led:1 type=SysEx stream="0xf0 0x00 0x01 0x16 0xE0 0x18 0x01 0xf7" if_equal=127
Best
Zam
- 1
Hello
Don't know if it's related but I remember having app issue (MB_NG) when in debug mode combined with large "regular" data transfer or config file update from/to computer.
So maybe as a start just be sure debug mod is off as soon as you don't need it and send lot of data.
Best
Zam
Hello
If you reset (button) the core wile pressing (and keep pressing) user (button), you should start the core in bootloader mode.
MIOSstudio should recognize and connect via USB, as hex upload working to update/load your mios app.
Just keep your finger at user button all the time, if you release it the core reboot.
Best
Zam
Hello
Welcome here !
What hardware did you build ? did you install the bootloader ?
We need more information to help you.
Best
Zam
Hello
Can't say... you have to try in your design
Here I run aprox 35cm wire and trace from 10 to 25cm, with 3 connector in the path, from pot to AINSER input pin
Vref have dedicated regulation.
No jitter at 11bit
Side note, I use AINSER8, no multiplexing, can't say what is the noise introduced by switching nor if there is some.
IIRC you can chain AOUT up to 4 TLV (32 out) with a single RC line,
so yes, 64in/16out is possible at J19
Best
Zam
Hello
You don't need a second one ! assuming you talk about midi resolution ?
Set your AINSER module at 11bit in NG, and set event type= according to your requested resolution (7 or 14bit)
NG should scale
1 hour ago, macsaif said:but in that case I will have problem with jittering of all AINs
With proper design and dedicated ref regulator you should go up to 11bit
Best
Zam
2 hours ago, Antichambre said:
I finally decided to add CAN transceiver to the board.
that's definitely even better
Best
Zam
Hello
maybe this ?
kb_transpose=<-128..127> Only valid for EVENT_KB: specifies the transpose value for the played key from -128..127
Best
Zam
Just now, Antichambre said:
really? then how do you get the position from the faders?
By using highend dual track motor fader with one servo track (linear taper) and one audio log track
Best
Zam
- 1
12 hours ago, Antichambre said:
I'm not sure but there's no audio signal passing thru his faders
I'm sure that audio pass through my fader
Best
Zam
29 minutes ago, Thomasch said:
My english is not the best, , so what means 15/100 error at tangent?
sorry, I mean 15/100 millimeter, If you draw a (quarter) circle of 1mm diameter inside a 90° angle
44 minutes ago, Thomasch said:Because of tolerances a little bit of gap between hole and LED might be necessary. Just enough, that it don't needs any force to slide the LEDs in.
That's what I say, add 3/10 mm and you'll be fine for a soft mount, dust won't come in that much and aestheticly it's not noticeable
Best
Zam
42 minutes ago, piepermd said:
So that is the actual app that you posted 8/30/17?
yep... almost two years back (thinking about one)
but more precisely, this is not the app (.hex) but the change in code.
You can copy/replace that at the correct place, IIRC the only change I made to "fake" raw dual CC as NRPN (note that standard NRPN won't work any more but HUI don't use it) I can also provide the compiled app which should be based on NG1.035 or 1.036 (don't remember what's up at that time), so not up to date regarding newer implementations.
Best
Zam
ps: I sent you an email earlier today
More AINSER Problems
in MIOS programming (C)
plz wait until OP say something...can be dumb too
Still (no offense) I find pples around so focused on digital and code that they usually miss the first things to check in the chain
Best
Zam
