Alasdair Moon
    141
    7
Everything posted by Alasdair Moon
  1. Now this is handy to know .... building my CV breakout I was asking myself if the 4.8V Gates and triggers are enough for my +-15V modular.
  2. Hi all, I tried to update my midibox today from 4.090 to 4.092 on STM32F4-Discovery I connected the micro usb and started the mios32 under my Linux Mint. (I have a 5v power-supply connected) USB Ports of my midibox seq are scanned and loaded ... QUERY gives the correct values Filebrowser can access SD-card If I send infos from my midibox to mios32 all works perfect When I tried to upload the new hex-file I get the ERROR .... FILE DOES NOT EXIST and that's it ... the "start" Button of MIOS32 stays grey What could it be? Only weird thing I see in the Infopage is the CPU-load that says 234% Greetings, Sascha
  3. Sorry to heat this up more than a year later I don't know and do not care about MM's internal politics and marketing, and there are some people in the e-m scene that .. out of a lack of solderingskills love to buy finished stuff you normaly only get as DIY (instead of buying other projects from Korg or Roland or DSI or ... ) buuuuuuuuut .... A SID like Wilba's A Synthlab like from Dirk Lindhof A Wasp in a suitecase with Midi .... like the Pixie from Elby ????? Well I would reconcider my marketing strategy ... @InspektorGadjet ... your Midi-converter .. looks good and teensy plus hackable .. thumbs-up .. thats the spirit ;)
  4. The Sequencer is finally up an running in his new Acrylic case ... Todo's ... adding a 5 Volt external PS for the STM32F4 instead of USB-cable and building the Frontpanel for the Line-Driverstuff
  5. Listen to Latigit on .. if you want to add a new core .. the STM4F32 is the newest one .. so go for this one ... there are some updates announced for a Version V4 Plus that might not run on the LPC17 because of lack of RAM ..
  6. This looks cool .... if this is tested and you do a PCB run I'm in ...
  7. Hi Macotronic .... if I did understand it well no additional wiring is needed, only chsngement of 2-3 values in the hwconfig file. I got mine fromvoti.nl, but Peter has some Links to some Alps in his tutorial ..
  8. Great , thanks Peter
  9. I got the rotary encoder with pushbutton from voti.nl ... http://www.voti.nl/winkel/catalog.html?SW-ROT-02 for the wilbapanel. Is the push button function usefull?? Or does the current design only support the encoder part. If yes, how can I assign something to them?? Thanks in advance
  10. Why should the 4x16 BLM not be supported?? It should work just fine with the right lines in the mbseq_hw.v4 Have a look at the bottom of http://www.midibox.org/dokuwiki/doku.php?id=16x4blm_pcb There is a zipped config for v4 ...
  11. Factor to resize in Inkscape is 125% .... Original is 72 dpi, Inkscape makes 90 dpi like mongrol said .. now all seems to fit ... next week ordering the case
  12. I ran out of 15k resistors for the AOUT but still ... Line Drivers connected and all works fine ... well all sockets get 5 V where they should .. still a bit confused with the ribboncables .. hope S0 and S1 are not switched ..
  13. Alasdair Moon
    Midibox 2016
    Midibox Building
  14. From the album: Midibox 2016
    STM32F4 Core done
  15. Alasdair Moon
  16. The SIL couldn't be delivered and I had to do the LED twice because of the round buttons, but progress is visible :)
  17. First of all ... wonderfull work pawaga, Attention, I just tried to open the svg in inkscape and the size is not correct .. (about 18% smaller)
  18. To post the debugging here too from the german topic ... I used the MIOS Terminal to route a midikeyboard from IN1 of the first Midi IO board to OUT4 on the second Midi IO board with set router 1 IN1 all OUT4 all It worked just fine ...
  19. So, grad mal probiert ... Wenn ich an Midi IN 1 ein keyboard klemme kommt nichts im Mios an.. Aaaaaber im MIOS Terminal konnte ich mit set router 1 IN1 all OUT4 all die Midisignale vom ersten IN port des ersten Midi IO auf den 4ten OUT port auf dem 2ten Midi IO board routen. "set router 1 IN1 all IIC4 all" funktioniert ebenfalls .. es scheint also halb so wild zu sein ... hoffe ich
  20. Danke Peter, das beruhigt mich etwas ... die Wilbabauteile kommen Montag, werde es aber gleich mal mit dem Terminal testen ... Bei 5 Volt sollte auch nicht zuviel durchbrennen ... (anders als bei meinen 15 Volt Modulen :) ) Aber gib zu .. komisch ist das schon ... vor allem das auch die Midi Out auf einkommende Signale reagieren ...
