TK.
Administrators
    15,248
  1. Everything is done within the driver. E.g., if you would select the sid_aout or sid_aout_ng driver, all values would be forwarded to the DAC with 12bit resolution. The AOUT registers are handled the following way: AOUTx_H[7] is cleared whenever the appr. AOUT value has been updated from the sound engine. The AOUT driver has to check this bit, it has to transfer the 12bit value to the DAC, and set the bit so that the transfer won't be repeated so long the value hasn't been updated again. The lower 8bit of the AOUT value is located in AOUTx_L[7:0], the upper 4bit in AOUTx_H[3:0] The AOUT_LC driver always updates all 74HC595 registers (8 for 4 modules), whenever any AOUTx value has been changed (an individual update is not possible with chained AOUT_LC modules) As you can read in the source code, the SID_AOUT_LC_UPDATE_MACRO extracts a 12bit bitfield from aout_a, and a 4bit bitfield from aout_b. The resulting 16bit value is transfered to 2 chained 74HC595 So, all you need to do is to change the macro, so that it partitionates the bitfield as desired. Or maybe you need to write different macros for different value alignments. This means: if you want to transfer a 8bit value instead, you can get the value from AOUTx_H[3:0] and AOUTx_L[7:4]. But these bitfields into TMP1 (or TMP2), fill the remaining TMP variable with useful data, and call the SID_AOUT_LC_Load2SR routine, which will transfer TMP[12] to the AOUT_LC module Best Regards, Thorsten.
  2. By pressing the "Menu" button, the SID registers will be initialized with the selected patch parameters. Once you restart ASID, the sequence continuous to play, but with the wrong sound settings, as the very first SysEx stream is corrupted (this can be monitored with MIDI-Ox). When you select a different patch (e.g. A059: A Stormy Day), you won't probably hear any sound until the ADSR registers are rewritten with new data. Good idea, I will add this. In long term, I'm also planning to implement the F2A flag within the ASID parser - but such a feature has a low priority. Best Regards, Thorsten.
  3. Sidenote: there isn't really an performance impact when using 4bit mode Best Regards, Thorsten.
  4. Please upload the application with MIOS Studio beta7_5 or higher -> http://www.midibox.org/forum/index.php?topic=7238.0 Best Regards, Thorsten.
  5. I came to the decision, that it doesn't really make sense to provide an optional compile switch for 4bit/8bit editing of the resonance parameter - now it's always edited with 8bit resolution (in V1 it was always edited with 7bit resolution, and nobody complaint...) The change is available in beta7 (-> http://www.midibox.org/forum/index.php?topic=9457.0) Best Regards, Thorsten.
  6. Beta7 now offers integrated SID player support - but there is an issue with Windows XP! :-( o integrated support for ASID protocol, which has been originally developed for the SIDstation to replay .sid files. (see also http://www.midibox.org/forum/index.php?topic=2038.0) Only the master core (Device ID 00) will play SID tunes! Nice visual effect: the LED matrix of the CS shows three animated meters whenever a gate flag of an oscillator is set. SID player mode is automatically enabled once an ASID stream is received. It can be exit by stopping the player on the PC, and pressing the MENU button Unfortunately it turned out, that there is currently no SID player available which can replay .sid files properly via MIDI. - SIDplay (http://www.d.kth.se/~d93-alo/c64/spw/sidplayw.html) Perfect integration, but plays tunes too fast under WinXP. Works fine under Win95/Win98/WinME. Not tested under Vista - ASID (http://www.sidstation.com/sidsupport.php) Crashes under WinXP once the tune should be played - ASID XP (http://www.sidstation.com/files/asid_xp_1.0.zip) Tunes played correctly, but the MIDI stream is corrupted at the very beginning when the player is started. Accordingly the sounds are not properly initialized. Workaround: start a tune with SIDplay (for proper sound initialisation), thereafter play it with ASID XP [/code] Best Regards, Thorsten.
  7. Hallo, eins kann ich schonmal vorweg sagen: die SW MIDI In/Out Routine musste ich aus der MBFM entfernen, da sie zuviel Platz verbraucht. Und Flash Speicher ist auf dem PIC18F452 rar... vielleicht kommt ja irgendwann einmal eine PIC18F4685 Version nach - doch sicherlich nicht dieses Jahr ;-) Trafo: dieses Problem kommte mit der alten Schaltung auftreten. Wichtig ist, dass nur ein einziger Gleichrichter verwendet wird. Naehere Infos gibt es hier: http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu Gruss, Thorsten.
  8. Just type "ratsnest" into the command window to see the ground connections. Best Regards, Thorsten.
  9. It's very silent on the JSynthLib mailing list since years Best Regards, Thorsten.
  10. This means that you have to chain two 32 step tracks. By doing so, each pattern can store 2 * 64 step tracks, means that you need to run two patterns in parallel. Up to four patterns can be played. In general there are 16 32step tracks which can run in parallel, there are different event modes which allow you to play a single note from a track, or multiple notes, or note+CC, or multiple CCs, etc.... this is explained in the user manual. More than 16 encoders cannot be used. And it isn't easy to realize different hardware layouts. Mostly some PIC assembly programming experience is required. Best Regards, Thorsten.
  11. The AOUT driver gets 8 x 12bit values, and you don't need to change the patch structure just to add some additional controls. So long the F2A option is not enabled, you can control the AOUT values individually within the EXT menu, and if you prefer F2A, you are also able to disable or change the channel assignments within the setup_*.asm file. You can for example disable the assignments for the right SID very easily, so that the channels are free accessible from the modulation matrix when the F2A option is enabled. When it is not enabled, the channels are free accessible anyhow. First AOUT value is in AOUT0_[LH], second in AOUT1_[LH], third in AOUT2_[LH], etc... In a later version I'm planning to add an optional 8bit resonance support for external filters. It's already prepared (8bit are stored within the patch structure), just only a compile switch needs to be added which changes the max value and mapping of the CS menu entry for resonance. Best Regards, Thorsten.
  12. Upload is working now For anybody who isn't in the "frequent writer" group, but wants to upload new files quickly: just go into the chat and ask for help. Best Regards, Thorsten.
  13. Hi Rutger, the MBSID V2 feedback thread is not intended for discussing general hardware issues - if everybody would do this, the oversight would get lost even more. 1: Unfortunately I'm not an expert in solving grounding problems - I would have to see the circuit and would have to do some experiments in order to find out the root cause. Maybe somebody else has an idea Encoders: the "speed mode" (acceleration factor) is automatically selected depending on the resolution. On higher resolutions, values will be incremented faster depending on the encoder speed. The idea is, that you are still able to sweep over the whole value range with a single turn (press SHIFT button in addition), but that you can also finetune parameters when moving the encoder slowly. With lower resolutions (especially for 4bit resonance), the acceleration has no effect I don't know about an issue with a resonance limit check - it's handled like any other menu parameter, and it works since years. Did you already try another encoder? E.g., swap it with a one which is working? Best Regards, Thorsten.
  14. Durisian: I must say, that I don't know how to create subdirectories - maybe it's well hidden in the documentation? (has somebody already found it) Stryd: so, it seems that I selected the wrong group (they are not named, only enumerated) Now I selected the rights for the last group in the list - please try it again Durisian again: I gave you user based permission (seems that I selected the "newbie" group instead of "frequent writer" group) Best Regards, Thorsten.
  15. In other words: I wouldn't be able to link files from ucapps.de ;-) Btw.: the reason why I want to restrict upload permissions "for world" is not the traffic issue, but the liability issue. We especially have to check for illegal material... frequently! Best Regards, Thorsten.
  16. Yes, e.g. the MAX489 could work yes, but by enabling the MIDI merger you could chain the core modules Sorry, I don't have another idea for a stable solution - maybe somebody else has more experiences with long distance connections? Best Regards, Thorsten.
  17. P.S.: Frequent Writers should see a new icon now: just click on it to open the media file manager. It's possible to create subdirectories for different projects (recommented!) Files can be referenced with internal links: {{<filename>}} Best Regards, Thorsten.
  18. Redirects: please specify the URL for this plugin Graphviz: requires unix tools which we cannot install on our server tag: installed code2: installed sidebar: installed Uploading images: it's already possible to upload any file into the wiki media library, permissions are controlled via ACL (Access Control List). Permission can be granted for groups and individual users. Frequent writers should now be able to upload by default (please test! I'm not sure if I selected the correct group, as the name is not displayed), if somebody else needs access, just drop me a mail Best Regards, Thorsten.
  19. TK.
    .hex hack
    Die Berechnung einer Checksumme ist sehr fehlertraechtig, immerhin gibt es 256 moeglichkeiten, und davon sind 255 falsch ;-) Das .hex File muss wie folgt gepatcht werden: :080000000000000000000101F6 Gruss, Thorsten.
  20. I like this layout and therefore installed the box plugin. Now where I know how the plugin manager is working: are there more interesting dokuwiki plugins? Best Regards, Thorsten.
  21. The ECAN peripheral is not supported by MIOS itself, it's an application specific function which needs a lot of programming. It isn't a compatible replacement to MIDI, it's just another networking concept. There isn't a step-by-step guide available which explains how to integrate CAN support into MIDIO128 - it can be assumed, that this has to be worked out by a dedicated freak. The maximum distance for DIN/DOUT signals is about 0.5m .. 1m, so this is no feasible solution for your plan. Maybe it would be easier to convert the MIDI signal to RS422. There are transceiver chips, e.g. from Maxim, which can be used for such a purpose. The maximum distance of RS422 is about 1000 m @ MIDI speed (but I never tested this myself) Best Regards, Thorsten.
  22. Hi Timofonic, I removed most of the direct .mp3 links from my homepage to reduce the traffic, because too many people are using tools which download the complete website. Some of the guys don't hesitate to update their "backup" periodically --- this is annoying! Best Regards, Thorsten.
  23. thanks! I knew how you mean your article, and just wanted to highlight again for people who propably join the discussion and don't know the background, that there are huge differences between programming 8bit controllers (which are mainly constructed to save costs and therefore come with many restrictions) and 32bit controllers (which mostly provide much better peripheral functions, and in addition allow to apply state-of-the-art programming concepts) yes, thats the most comfortable way to go for PICs which are connected to a PC anyhow (this wouldn't be the case for MBSEQ or MBSID/MBFM...). Best Regards, Thorsten.
  24. Hi Didier, I fear that I won't have enough time to discuss this topic intensively enough. Since you have some fresh ideas how to improve MBNet, I would recomment that you start to work out an alternative protocol in order to prove that it is working sufficiently enough to meet all requirements. MBNet was mainly tailored for interconnecting MIDIbox SID V2 cores with the limited features of the integrated ECAN peripheral of PIC18F4685. Therefore the restrictions were driven by free resources (under resources I understand flash, RAM, CPU load and peripheral features) and special requirements of this synth application. I'm sure that there are better CAN based solutions possible, e.g. for MIDI controllers - like OSC/ACN as you proposed by you in this article http://www.midibox.org/forum/index.php?topic=9376.msg67121#msg67121 But I'm also sure, that a synth which is running on a 8bit controller would never be able to support all features. And I'm also sure that you would never achieve the same performance and robustness. As mentioned above: it was tailored around an existing application. And this application is one of the most complex one I ever implemented. Best Regards, Thorsten.
  25. This topic has been moved to Miscellaneous. [iurl]http://www.midibox.org/forum/index.php?topic=9564.0[/iurl]
