TK.
Administrators
    15,248
  1. This will be possible with the multi engine of MBSID V2 see http://www.ucapps.de/midibox_sid_v2_wishlist.html Best Regards, Thorsten.
  2. Dann schaut es wirklich schlecht aus! Der SID chip ist defekt :-/ Gruss, Thorsten.
  3. The second SID module is connected to the same pins like the first one, just only the CS# line is connected to J14 of the core module to allow individual accesses All core modules (master/slave) support a AOUT or AOUT_LC module I will implement several options on request. The AOUT gates will be supported of course Currently not, as the PIC18F4685 is not completely software compatible, the RAM area from 0x60-0x7f is not directly accessible. But with some small changes in the code, the MBFM application will run. This is on my TODO list, but currently other things have a higher priority Best Regards, Thorsten.
  4. Thanks for the input, Dave! Ole has already informed me about your posting, your observations are very helpful! Especially because you've encountered exactly the same problem! It seems that Mike has done everything correctly. He sent me a .hex readout of a programmed PIC18F4620, and it matches 1:1. So, I definitely need Ole's PIC in order to continue with the analysis. thats an interesting speculation, as flash memories are sensitive against X-rays. But with todays scanners this shouldn't be an issue anymore, otherwise 1000 of people would lost their MP3 collection when they are scanned at the airport... however, nothing can be excluded. Best Regards, Thorsten.
  5. Wenn Du den Momentanwert, und nicht den im Snapshot abgespeicherten Wert versenden moechtest, muesstest Du in der MB64_PATCH_Send Funktion noch die "call MB64_DUMP_RestorePatch" Anweisung entfernen Gruss, Thorsten.
  6. Hast Du mal das DIN Modul abgeklemmt? Hast Du mal den Patch neu aufgespielt? Gruss, Thorsten.
  7. Hallo, in mb64_patch.inc nach "#if DEFAULT_NUMBER_BUTTONS" suchen, und durch "#if 0" ersetzen Gruss, Thorsten.
  8. It can be assumed, that the PICs from SmashTV are programmed properly, otherwise you wouldn't have MIOS preinstalled - MIOS has been uploaded via MIDI (this is a great quality assurance :)) So, voltages are ok, connections are ok, it must be any other hardware related problem. Maybe the crystal or the 33pF caps? Best Regards, Thorsten.
  9. Hoert sich wirklich seltsam an, so ohne weiteres kann ich mir nicht erklaeren, welcher Parameter hier die Frequenz verbiegt. Du koenntest einfach mal die DIN Module voellig abklemmen (es wuerde ausreichen, den pin J9:SI am Core Modul zu trennen). Ausserdem koenntest Du den Patch nochmal aufladen - vielleicht ist ja nur der SysEx Transfer schiefgelaufen. Gruss, Thorsten.
  10. Die Links zeigen leider ins leere :-( Gruss, Thorsten.
  11. I don't think that the crystal is the problem - you wouldn't be able to upload a program (wrong baudrate) It sounds like a software problem (wrong data conversion), but when I look into the program, I cannot see an error, and unfortunately I'm not able to test this with my own equipment so easily (means: it could take weeks until I find the motivation to open the case and to resolder my AOUT_LC modules, just to test if the conversion is done correctly). On the other hand: are you really sure, that the modules are configured correctly for 2*8 bit mode. What happens when the CV outputs are controlled via CC events? Are you able to sweep over the whole voltage range? (compare with http://www.ucapps.de/mbhp/mbhp_aout_lc_res_options.gif And another note: the Hz/V curve normaly requires a resolution higher than 8bit, otherwise it isn't accurate enough. You could try the 12/4bit resolution (with the appr. setup in main.asm) - this is the one which I've tested on a MS20 I'm also interested in this - or in a substitute for the MAX6007B shunt (I'm not an analog expert) Best Regards, Thorsten.
  12. Very innovative and great presentation! :) I'm curious about the technical details of the hand tracker. Does it allow to scan for different gestures? And is it possible to generate 3d controller informations? Looks like you've invented the "3d beam" :) Best Regards, Thorsten.
  13. Thanks again, Stryd! :) You've included much more scales than really required, they consume a lot of memory. However, so long I haven't reached the max (there are still ca. 6k free) I will left the tables as it is. General info: the user manual is 80% finished, a final release can be expected in the next days. In addition to the new scale tables, it will also get a bugfix for the morphing function Best Regards, Thorsten.
  14. It's a limitation of the program. :-( You have to use TL's Patch Manager instead, but it only runs under Windows Best Regards, Thorsten.
  15. It's just the router project, slightly extended by some very specific button/encoder functions for my private needs: Button A: MBSEQ routed to MBSID/MBFM Button B: Force MIDI Channel of Keyboard to a specific Channel Button C: Transpose Keyboard Button D: Keyboard to MBSID enable/disable Button E: Keyboard to MBFM enable/disable Button F: Keyboard to MBSEQ enable/disable I don't plan a customizable version, it wouldn't be worth the effort... I'm happy with the available functions and I'm using them intensively since 1 year The routing/filtering/mapping can be changed in the source code, accordingly this is the most flexible MIDI router you can find ;-) Best Regards, Thorsten.
  16. http://www.midibox.org/dokuwiki/doku.php?id=lcd_module_liquid_crystal_display Search for Jim Henry's superb guide about LCD soldering Best Regards, Thorsten.
  17. Have you ever checked the multiplexer control lines between CORE:J6 and AIN:J6? If four analog channels are not working, it sounds like one of the three select lines is not connected, or that it has a short Best Regards, Thorsten.
  18. I added the keyword "schematic" to the .pdf's... Best Regards, Thorsten.
  19. Finally: Best Regards, Thorsten.
  20. The waveforms of the encoder pulses are inverted, as the DIN register chains are working with low-active. As you've already noticed, it doesn't make a difference. However, maybe the output signals of your encoders are too unstable when it is rotated. There is no encoder debouncing implemented (would consume too much RAM and too much CPU performance), but you could decrease the update frequency - maybe this helps. So, what does happen when the update frequency (MIOS_SRIO_UpdateFrqSet) is 5 mS instead of 1 mS? Best Regards, Thorsten.
  21. This is the link to the Walkthrough: http://www.ucapps.de/midibox_sid_walkthrough.html Best Regards, Thorsten.
  22. thats strange, because there is no "bootloader V1_2a" file released, only bootloader_v1_2a_pic18f4620.hex and bootloader_v1_2b_pic18f4620.hex, whereas for PIC18F4620, there is no functional change in both versions I will contact Mike, maybe it is a wrong version Nevertheless it could make sense to send me the PIC for further analysis. I could read out the bootloader and compare it with the official version. And if it is identical, I could check it on my core module. Since there are not so many users who have tried the PIC18F4620 yet, I cannot exclude that a certain chip revision doesn't work properly Best Regards, Thorsten.
  23. Hi Ole, I made some experiments with the bootloader in order to get a feeling about what happens, when the wrong one is programmed into the PIC. If the PIC18f452 bootloader is programmed, you wouldn't receive any MIDI data at all, only zeroes The PIC18F4685 bootloader would work like the PIC18F4620 bootloader So, it's very likely, that the problem is not caused by a wrong bootloader I also checked my suggested SysEx sequence, and noticed, that an error won't be sent as expected. Problem is, that the core will be reset before the last byte (F7) is sent out. However, following sequence should return an error response, could you please try it? f0 00 00 7e 40 00 02 7f 00 00 01 11 22 33 44 55 66 77 00 00 00 00 f7 Best Regards, Thorsten.
  24. TK.
    opl3 with +/-5V
    Hi, there are no modifications required for +/- 5V, the TL074 works fine in this voltage range. Best Regards, Thorsten.
  25. so, thats definitely not a PSU problem. Unfortunately you forgot to answer my other question (who has programmed the PIC) Best Regards, Thorsten.
