TK.
Administrators
    15,248
  1. Could it be that the other ports send a MIDI clock or something similar? Best Regards, Thorsten.
  2. V4.089 has been released! From the ChangeLog: MIDIboxSEQ V4.089 ~~~~~~~~~~~~~~~~~ o added DIN testmode which can be enabled from the MIOS terminal with the "set din_testmode on" command to display button and encoder movements. o added "Roll Gate" as new optional trigger layer assignment. It gates the Roll or Roll2 value which is configured in a parameter layer. o Euclid Generator: parameter layer into which the pattern will be copied now selectable. Velocity/Accent will only be changed if the first parameter layer is selected. o it's now possible to quickly duplicate the steps of a track: press&hold COPY and press the PASTE button o Groove page: by default, groove configuration changes are applied on all tracks now. It's possible to select a "local groove" by pressing GP7 button in the groove page. o BPM page: it's now possible to configure an output delay for each MIDI port. (positive and negative delays are supported - this is currently an experimental feature!) o fixed NoteOff in Jam Forwarding mode if FTS, Limit or Humanizer is enabled o NOTE: due to a RAM capacity issue, the UNDO function is currently not available for the LPC17 firmware Best Regards, Thorsten.
  3. Signatures are available again, thanks for pointing this out! Peter wanted to say, that I changed from tobacco to e-liquids more than 1 year ago. I should consider to change my signature to "Buy TK a tasty vape liquid" ;-) Best Regards, Thorsten.
  4. I moved the postings about my build to the build guide so that we can collect additional information there: http://midibox.org/forums/topic/19736-blm-16x16x-build-guide/ Unfortunately the URL changed after the merge (I had to learn how to handle the new forum functions... ;-) Best Regards, Thorsten.
  5. It took me around two days (ca. 15 hours) - at the first day I soldered 1N4148 diodes and LEDs, and at the second day the remaining parts. Over time I became faster with SMD soldering, but still ensured that parts are correctly aligned - especially for the LEDs it's important that they sit flat on the PCB, otherwise later they could illuminate in different directions so that you won't see a combined colour through the affected silicon pads later. Therefore the important hint: always solder only 1 pin (tacking), align the part, then solder the remaining pin(s), otherwise you can't fix the position anymore without desoldering the part! This way I tacked one row of LEDs, fixed the positions (when necessary), and then soldered the second pin. The same for any other part - it brings a little bit variety in the boring soldering process ;-) To the colours: In difference to Andys proposal I took blue as "colour 2" (right side of the bottom PCB) and green as "colour 1" for the left side, but this was my personal preference. Don't worry, the firmware allows to swap colors if you are unhappy with your initial decision! :) For the extra row/column and shift button I took red as "colour 1", and blue as "colour 2" again. Therefore (and I only write this as an important reminder for the case that somebody wants to do the same) I had to swap the resistor networks: 220 Ohm for the green/red LEDs (RN3, 7, 11, 15, 19) and 56 Ohm for the blue LEDs (RN4, 8, 12, 16, 20) Best Regards, Thorsten.
  6. In pre7 I added a bugfix for MAPs with duplicated values to cover Bartosz' use case; see also http://midibox.org/forums/topic/19535-encoder-and-maps-problem-bug and http://svnmios.midibox.org/comp.php?repname=svn.mios32&compare[]=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2F%402174&compare[]=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2F%402153 Could you please give me a downstripped .NGC file (and/or .NGR in addition) which demonstrates your intention? It could be that due to the changes a new way has to be found. Best Regards, Thorsten.
  7. Could you please send me a (downstripped) .NGC file which allows to reproduce the problem at my side? Best Regards, Thorsten.
  8. Seems to be related to a bad solder joint? I guess that you can measure the right voltage at IC3, pin 12, right? Now follow the track with your multimeter to pin 11 and 32 of the PIC, and check where the voltage isn't available anymore. Best Regards, Thorsten.
  9. A new BLM has been born Very nice to build, no big troubleshooting required if you are careful enough and don't forget a solder joint or create an unintended short. Andy deserves great respect for his sophisticated design, this is really professional work and sets a new DIY standard! Although the BLM16x16+X project is 5 years old meanwhile, you still can't buy a device with 290 buttons and duo-colour LEDs - you can only build it by yourself - and it has never been easier! Best Regards, Thorsten.
  10. no, IF/ELSE is the wrong approach for this purpose, and the RAM is limited to 16k ;-) But in future I could provide a special command which allows to scale during runtime based on an interpolated curve with n number of nodes. This would consume some additional execution time, but it should be fast enough on a STM32F4 - the memory consumption is then dramatically reduced. In general it's an advantage of the .NGR approach that special commands and mechanisms could be provided in future. Sooner or later I will clean-up the source code to simplify the integration of new commands (I've to improve it anyhow, because currently we've too much quick&dirty spaghetti code) Best Regards, Thorsten.
  11. And I got the mouser parts today & I'm ready for a nice soldering challenge! :) Best Regards, Thorsten.
  12. Yes, it's the MCLR# pin. I improved the documentation Best Regards, Thorsten.
  13. could you please determine with the "show id DOUT:1" command the values between the different states? I could imagine, that this is a side effect caused by the snapshot function Meanwhile I know the reason: after reset the MBNG firmware will wait for 2 seconds until controllers will be enabled. This is to ensure that SD Card content has been read, and voltages are settled. Could you please increase the delay to 2500 mS? if ^section == 0 # wait until all values have been scanned (consider 2 seconds startup delay + a little bit margin) delay_ms 2500 # now capture the AINSER values exec_meta RetrieveAinserValues endifBest Regards, Thorsten.
  14. Potential use cases which didn't work properly in the past, but should be possible now: flexible MIDI event converter/router: reacting on incoming MIDI events, e.g. with SEND commands selected via IF/ELSE conditionsfully customized bank handling via SET_ACTIVE command, interactively switched from a fast turned rotary encoderfast keypad entry (you know the example: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Frunscr5.ngrAlso this issue should be solved now: http://midibox.org/forums/topic/19477-problem-with-keys-and-runsection-command/ Best Regards, Thorsten.
  15. To all fans of .NGR files: please join the beta testing for execution from RAM: http://midibox.org/forums/topic/19728-request-for-beta-testers-ngr-script-execution-from-ram/ Best Regards, Thorsten.
  16. Today I also noticed the case that the file won't be stored if the core generates a lot of MIDI traffic via the same USB channel. The connection wasn't failing though, but I think it's a problem with the communication scheme used by the file browser, it isn't robust against "foreign MIDI traffic". Needs some time to work this out! Best Regards, Thorsten.
  17. Hi, in the last months multiple users requested faster execution of .NGR run scripts to cover their use cases. The only way to achieve this is the execution from RAM, and in order to ensure that even the execution of long and complex scripts is possible, the NGR commands have to be compressed (resp. I call it "tokenized") In the last two days I developed a solution for this request - it was a nice programming challenge (although I hate the immense amount of required spaghetti code to cover all options - next time I will use a code generator... ;-) Typically scripts are now executed in much less than 1 mS, which means that it's finally possible to use them for timing critical operations! Only drawback: this feature is only supported for MBHP_CORE_STM32F4, because the other cores don't have enough RAM available - they are executing the script directly from SD Card like before. Here the current version: http://www.ucapps.de/mios32/midibox_ng_v1_033_pre14.zip It would be helpful if users could help me with the testing by running their existing .NGR files, and maybe also enhancing the files for realtime processing. Any feedback is welcome! :) Best Regards, Thorsten.
  18. Great that we finally solved this mysterious issue! :) you mean, that you attach the keyboard during runtime, or is it already connected while the .NGC script is loaded? You've to capture the AINSER values once they have been scanned. This can be done from the .NGR file: if ^section == 0 # wait until all values have been scanned (should be after >= 50 mS) delay_ms 50 # now capture the AINSER values exec_meta RetrieveAinserValues endif Best Regards, Thorsten.
  19. Thanks for testing! This one should work better: http://www.ucapps.de/mios32/midibox_ng_v1_033_pre13.zip I noticed that I'm able to test the forwarding by myself from the terminal w/o special hardware by entering "ngr trigger AINSER:1" I knew that sooner or later this command could become useful Best Regards, Thorsten.
  20. Thanks! For me it's clear now (although it's still a hypothesis - I haven't doublechecked yet - but I'm very sure ;-): it seems to be related to a software bug indeed! EVENT_AINSER forwards the value to CV; the AINSER event has some custom flags: struct { u16 ain_mode:4; // mbng_event_ain_mode_t u16 ain_sensor_mode:4; // mbng_event_ain_sensor_mode_t } AINSER;and CV has some custom flags as well - they will be shared with the same variable: struct { u16 fwd_gate_to_dout_pin:9; u16 cv_inverted:1; u16 cv_hz_v:1; u16 cv_gate_inverted:1; } CV;You are using a special ain_mode in your configuration: parallax. The corresponding value for this mode is 4 From MBNG_CV_NotifyReceivedValue(): if( item->custom_flags.CV.fwd_gate_to_dout_pin ) { if( debug_verbose_level >= DEBUG_VERBOSE_LEVEL_INFO ) { DEBUG_MSG("-> Setting DOUT Pin #%d=%d\n", item->custom_flags.CV.fwd_gate_to_dout_pin-1, gate_value); } MIOS32_DOUT_PinSet(item->custom_flags.CV.fwd_gate_to_dout_pin-1, gate_value); }Which means: custom_flags.AINSER.ain_mode=4 will turn into custom_flags.CV.fwd_gate_to_dout_pin And therefore MBNG_CV_NotifyReceivedValue() could set DOUT pin 1.D3 to 0 under certain cirumstances (value=0), with the result that the row selection pattern will be influenced! Now I've to find a way how to handle the shared custom_flags for the case that values are forwarded. Currently I think that it's safe to clear the flags before forwarding under the assumption, that the receiver will handle them as "passive". Could you please check this "blind" (untested) change? -> http://www.ucapps.de/mios32/midibox_ng_v1_033_pre12.zip Best Regards, Thorsten.
  21. Ok, we are coming closer to the root cause! :) Next tests with AOUT and AINSER enabled 1) remove the fwd_id=CV:x statements from EVENT_AINSER - problem still occurs? 2) remove the fwd_id=LED:x statements from EVENT_BUTTON - problem still occurs? Best Regards, Thorsten.
  22. Hm, works at my side with a similar setup (it's MacOS 10.10.5 but I think that this doesn't matter, 10.6 was working stable as well) Seems that certain things (events) have to come together so that the failure happens? Best Regards, Thorsten.
  23. Do you save the file from the MIOS filebrowser, or from the MBNG Disk menu? Best Regards, Thorsten.
  24. Hi Andy, meanwhile I've an idea under which conditions this behaviour could be observed (although I've no idea how this could happen with your configuration): if a LED (DOUT) function overwrites the pins at DOUT #1, D7..D0, the matrix row selection pattern would be falsified so that a single row could trigger multiple button events, and turn on multiple LEDs of the same row. In order to check if this hypothesis is the reason for the problems, I added a new debug command "show douts", which should output: [351689.954] Page 0: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.954] Page 1: bf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.954] Page 2: df 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.956] Page 3: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.956] Page 4: f7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.958] Page 5: fb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.958] Page 6: fd 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.960] Page 7: fe 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.960] Page 8: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.961] Page 9: bf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.962] Page 10: df 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.963] Page 11: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.964] Page 12: f7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.965] Page 13: fb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.965] Page 14: fd 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.966] Page 15: fe 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.967] Page 16: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.968] Page 17: bf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.969] Page 18: df 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.970] Page 19: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.971] Page 20: f7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.972] Page 21: fb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.972] Page 22: fd 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.973] Page 23: fe 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.974] Page 24: 7f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.975] Page 25: bf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.976] Page 26: df 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.977] Page 27: ef 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.978] Page 28: f7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.979] Page 29: fb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.979] Page 30: fd 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [351689.981] Page 31: fe 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 So, we've 32 pages which are cycled with each SRIO update, and the first column (which corresponds to a matrix row) shows the output pattern of the SRIO cycle. We should see 8 times the sequence 7f bf df ef f7 fb fd fe (which is nothing else than a running-zero, here the binary representation: 01111111 10111111 11011111 11101111 11110111 11111011 11111101 11111110) Could you please run following firmware version: http://www.ucapps.de/mios32/midibox_ng_v1_033_pre11.zip Wait until random events are triggered, and then enter the "show douts" command. Check if you see four times the value sequence that I explained above, if you notice a different value please let me know (Note that MIOS terminal output can be copy&pasted, just select multiple lines and right-click on the lines) Additional experiment (now considering more the HW side): What happens if you disable the AINSER (configuration) command, what happens when you disable the AOUT (configuration) command, what happens when you disable both? And last but not least: do you have a .NGR file, and what is the content? Best Regards, Thorsten.
  25. Please do following test before we continue with software based troubleshooting: once the circuit becomes unstable, enter the "reset" command in MIOS terminal -> is the circuit stable again, or does it stay unstable? Best Regards, Thorsten.
