TK.
Administrators
    15,248
  1. So, if it has worked before, there is a high chance to detect the problem by going through the MIDI troubleshooting list: http://www.ucapps.de/howto_debug_midi.html Which tests are working, which not? Best Regards, Thorsten.
  2. Could you please copy&paste all messages which are print by MIOS Studio within the upload window? Best Regards, Thorsten.
  3. Sidenote: I already tried to help Shum via email, but without much success. So - if anybody else has an idea? Best Regards, Thorsten.
  4. My proposal is to let these caps on the core module, and to bypass the outer pin holes of the 7805 (which is not mounted) as well as the pin holes of the rectifier (which is also not connected), so that all caps are routed to 0V/+5V This results into less noise at the digital line -> better sound capabilities! Best Regards, Thorsten.
  5. TK.
    Abschirmung von Trafos
    Ich verwende keine Abschirmung, klappt trotzdem ;-) Gruss, Thorsten.
  6. No, this is wrong. The modulation matrix provides two different modes. In one mode, it shows the connections between the source and targets. This display is always correct, you can switch to a slave and you will see the connections made for the slaves. Then there is a new feature which I've quickly implemented based on a suggestion from a user. It shows the current (modulated) LFO and ENV values in realtime. You can see the waveforms sweeping! This is always a very nice attraction when you show the MBSID to your friends. Of course, these sweeping values can only be known by the PIC at which the engine is running, therefore you can only see the master values If you don't like this feature, just switch to the normal mode! Best Regards, Thorsten.
  7. Ooof, your J2 connections at the SID module are looking very error prone! Best Regards, Thorsten.
  8. Yes, the matrix is only a supplement. You could even control the modulators without any control surface, if the core module is connected to a PC, and you are using the JSynthLib editor, or a program which allows you to send MIDI Controllers Best Regards, Thorsten.
  9. Meinst Du wirklich Pin #25, oder Pin #6 des SID (dort wo vorher der Oszillator angeschlossen war). Dieser Pin muss nun mit PIC Pin #17 verbunden werden - siehe Schaltplan, dort habe ich es beschrieben. Damit in Zukunft nicht noch mehr Leute darueber stolpern, habe ich bereits eine neue Core und SID PCB Version in der Mache. Deshalb wird die MBHP_CORE und MBHP_SID Seite momentan auch nur stiefmuetterlich gepflegt - das wird sich aendern Warum: die Details stehen hier http://www.midibox.org/forum/index.php?topic=5748.0 Kurzbeschreibung: wenn PIC und SID Takt asynchron zueinander laufen, kann es vorkommen, dass bei einem Schreibzugriff auf das SID Control Register das Gate getriggert wird, obwohl es bereits geloescht war. Gruss, Thorsten.
  10. Yes, the transistor will work with both voltages without danger Best Regards, Thorsten.
  11. Hi, the most common error which are made are wrong interconnections between SID and CORE module - note that on the old PCB versions, the two 8pin ports are not connected 1:1. At the MBHP_SID module webpage you will find some diagrams which show the wiring (e.g. mbhp_sid_c64_psu.pdf), and at the MIOS download page you will find an mbsid_interconnection_test which allows you to test all cables to the SID module Is this test passing? (Test procedure is described in the header of main.asm) Best Regards, Thorsten.
  12. You've got mail Best Regards, Thorsten.
  13. I want to start with the implementation in autumn 2006, I assume that the final release will be ready very fast if everything is planned properly (this document and the long time span until the start). Most features which are listed here have already been evaluated in MIDIbox FM, MIDIbox SEQ and MIDIbox SID-D, so that I don't expect difficulities. Since MBSID V2 will be almost hardware compatible, I don't know if it really makes sense to wait - just start with MBSID V1, and upgrade later Best Regards, Thorsten.
  14. Maybe there is an internet cafe close to your location where you are able to download all the required packages for 1..2 EUR? Best Regards, Thorsten.
  15. MIDI doesn't provide handshaking, this means: it's not enough to send the bitstream, you need some error correction or a second level protocol in order to ensure data coherency Best Regards, Thorsten.
  16. No, you need to download the MPLAB toolchain from the microchip homepage as well in order to assemble the source code. The resulting .hex file can be uploaded with MIOS Studio Best Regards, Thorsten.
  17. I also think that this is because of a missing heatsink - the two LCD backlights make the 7805 really hot, sooner or later the voltage will drop much below 5V, and this resets the chip Exit button: it should work, you will get into the menu Drum mode: the future MBSID V2 will offer more possibilities, but I don't plan to enhance the drum mode. Instead I'm planning a more general way to assign values to the layers, which makes the drum mode obsolete. (as Moxi has mentioned - check the wishlist -> http://www.ucapps.de/midibox_seq_v3_wishlist.html :) Best Regards, Thorsten.
  18. Rio, I think that you've just missed all the infos I've already written down here: http://www.ucapps.de/midibox_sid_v2_wishlist.html Best Regards, Thorsten.
  19. Changes in cs_menu_io_tables.inc are only required when you've built a Control Surface, and when the control elements (rotary encoders, buttons, LEDs) are not connected to the original pins which are documented in my connection diagrams. In general: so long you are building a MIDIbox which doesn't differ with my own hardware, then you normaly don't need to change the sources, and you can use the precompiled .hex files Perl: I think you don't really need it for MBSID so long you already have MIOS Studio and Java, is this the case? Your "problem" with internet bandwidth brought me to the idea, that somebody could compile a CD which contains all tools which are required for MIOS based applications. It could be distributed via mailorder. Unfortunately I don't have that much time to do such things in parallel to all the other stuff, but maybe somebody else feels motivated? Writing docs: this would be really great, especially because I think that you will see the projects more from the user, and not from the developer side. This should result into a much more understandable documentation for normal MIDIbox users who don't have the technical background knowledge. The Wiki is predestinated for such "user manuals" - regardless how much will be contributed, it makes me and all the users happy :) Best Regards, Thorsten.
  20. I think that even driving a matrix with let's say 1024 buttons (via 1 DOUT and 4 DINs) is not impossible, it's only a question of RAM consumption and desired latency Best Regards, Thorsten.
  21. Hallo Pico, ich glaube, dein Projekt wuerde auch die Allgemeinheit interessieren! :) Solche Messstreifen sind schon etwas feines, wie hoch ist die Aufloesung? Und wieviel kosten sie? Man koennte sie bspw. als Ersatz fuer Motorfader hernehmen :) Gruss, Thorsten.
  22. yes, of course! The metal plate is like a huge 50 Hz sender - take care! In general I would never tinker with electronical gear on a metal workbench, you should put an additional wooden board at the top Best Regards, Thorsten.
  23. Hi Moxi, My proposal: just try it out, there are always cases which nobody do consider, regardless how often they look into the code (it's also my own problem - therefore I cannot release variations without the possibility to try it with the appr. hardware) Best Regards, Thorsten.
  24. it looks like a 0x55 with wrong baudrate - did you setup your RS232 interface correctly? baud rate: the PIC always sends with 19200 baud. It sends a 0x55 for autobaud detection after startup Resets: there are two cases where this can happen: 1) the 1k pull-up is not connected to the IIC SC(K) like, or 2) MIOS_IIC_Stop() hasn't been executed from the Init() function I guess that you've considered both (I just checked your code again, you have a call to SPEAKJET_Init, which propably contains MIOS_IIC_Stop() Have you ever accessed an IIC device (e.g. BankStick) from this core module? Is the cable between PIC Pin #28 and J4:SC connected? ;-) Best Regards, Thorsten.
  25. All the switches and levers can be found in main.asm, or in the setup_*.asm file you are using. I know that there are so many options in the meantime, that it is hard to get an oversight. But hey, you guys asked for these features, and never helped to write a documentation about them - so it's on you to read my comments in the code! ;-) Kobayashi: the switch for which you are searching is named CS_MENU_DISPLAYED_ITEMS Best Regards, Thorsten.
