TK.
Administrators
    15,247
  1. Brian stopped with his developments long time ago, and since some months there is no sign of life from Hiroo anymore. I wrote him a mail, but never got an answer :-/ Best Regards, Thorsten.
  2. Hi, yes, both is possible without problems. In order to send a sequence of bytes, you need to use "meta events", a description with some examples can be found in mb64_meta.inc All pots provide "min" and "max" values, you can use them to reduce the value range - see midibox64.ini, which is part of the "mk_syx" package. Best Regards, Thorsten.
  3. Hi Rene, if you start the "convert.bat" batch file, all these .syx with the appr. device IDs will be created automatically (read the .bat file in order to see, which commands are used). In principle you've done everything correctly. I'm sure that you will be able to find out, why the upload to Slave1 didn't work (based on your descriptions it's hard to find this out). General hint: the upload with MIOS Studio is more secore, since it notifies you if a block hasn't been uploaded correctly. Now you are at the same point like Wisefire, so just read this thread: http://www.midibox.org/forum/index.php?topic=5277.msg35621#msg35621 Best Regards, Thorsten.
  4. Hi, this remembers me, that somebody had a very similar problem. After a lot of mail exchanges, it turned out, that he used a bad parallel cable to the PC. Are you using a new one? And how long is it? Another thing what could be interesting: what is the Vpp voltage during programming? Is it stable? Best Regards, Thorsten.
  5. Hi Adam, MIOS has to be uploaded within 2 seconds after power-on. Did you take this into account? Best Regards, Thorsten.
  6. Hallo Claudio, meiner Meinung nach ist der Background Noise ist nicht so laut, dass es sich lohnen wuerde, soviel Aufwand reinzustecken. Karl Dalen hat schomal einen aehnlichen Vorschlag gemacht (siehe http://www.midibox.org/forum/index.php?topic=4075.0), aber ich persoenlich habe kein Interesse, diesen auch umzusetzen. Vielleicht jemand anderes? Gruss, Thorsten.
  7. Hi Rene, since some weeks I'm thinking about a new "HowTo" page for the SID setup procedure, but the problem is, that I haven't found the "newbie-friendliest" solution yet. For somebody who has worked with (some!) MIOS projects before, it's easy to understand what has to be taken into account in this special MIDI wiring which is used by MIDIbox SID (e.g., since the MIDI Outs of the slaves are not connected to the PC, the "don't use feedback from core" switch in MIOS Studio has to be enabled. Another point: the slave needs a reset pulse for uploading MIOS via 1st level bootloader, this can be done by tipping ground to pin 1 of the slave SID). At the end I think the newbie-friendliest method to setup the slaves which doesn't require much explanations is: don't follow the comfortable, but the easiest way! Unplug the PIC from the master module, plug the PIC which is used as slave into this IC socket, and program MIOS and the application from there. Thereafter the PIC is ready for use and you can plug it into the slave core socket again. Since you've programmed the master core successfully, doing the same for the slave shouldn't be that difficult anymore (check the device ID!). It doesn't require any knowledge about how to enable the MIDI merger without a Link button (beside of the SysEx string, you could also send a MIOS_MIDI_MergerSet function call via MIOS Studio), it is less error prone (because who knows if the slave module works, and that master and core are linked correctly?), and you have the LCD in order to check if the application is running. Please let me know how long it took to setup the slaves based on this method. If it works without problems, I will change the documentation at the csB page. JSynthLib: take care, the official JSynthLib release has a bug in the MIDIbox SID editor (which wasn't my fault...), a modified version can be found here: http://www.midibox.org/jsynthlib/JSynthLib-0.20.0_midibox_mod1.jar.zip Best Regards, Thorsten.
  8. Hi Kokoon, you could ask the guy to assemble the source code for the PIC18F452, it's nearly source-code compatible. He only needs to change the baudrate settings. You could also use the bootstrap loader to upload the code like you would do it with MIOS. It's only important that the program starts with two "goto"'s to the start label (the first one will be overwritten by the BSL) Best Regards, Thorsten.
  9. Hallo Andreas, stimmt - ich habe verschwiegen, dass ich zusaetzlich zum 2x12V Netzteil noch ein davon voellig getrenntes 5V Netzteil gebaut habe. Dies hat den Vorteil, dass man sich um die Spannungsfilterung keine Gedanken machen muss (digitale Stoerspannungen streuen nicht auf die analoge Schaltung ein). Ausserdem wird der 7805 nicht so heiss, wenn man ihn mit weniger Spannung (ca. 7VDC) betreibt. 12V vor dem 7805 waere bei diesem hohen Stromverbrauch zu viel. Ein Foto gibt es hier http://www.midibox.org/midibox_fm_photos/3.html Dass auf der Lochrasterplatine ein Gleichrichter/Elko/7805 fuer den 5V Zweig vorgesehen ist, hat historische Gruende - die Stabilisierungsschaltung auf der Core Platine ist voellig ausreichend. Ja, MBFM und MBSEQ haben einen Merger eingebaut. Bei der MBFM heisst er "MIDIbox Link" (siehe Doku), beim MBSEQ kann man ihn im MIDI Menue einschalten. Gruss, Thorsten.
  10. Here a new tutorial which describes, how to modulate sound parameters with the wavetable sequencer: http://www.ucapps.de/howto_sid_wavetables_2.html Have fun! :) Best Regards, Thorsten.
  11. Hallo Andreas, Die Schaltung von meinem MBFM Netzteil findest Du hier: http://www.ucapps.de/mbhp/mbhp_opl3_psu.pdf Ja, das ist moeglich. Es gibt verschiedene Routingmoeglichkeiten fuer die verschiedenen Einsatzwecke. Fuer Noten eignet sich AOUT1-4 am besten. In diesem Fall wird der Notenwert an CV Kanal 1/3/5 oder 7 weitergeleitet, und der Velocitywert an CV Kanal 2/4/6 oder 8 Das Ziel "AOUT" laesst sich im Event Menu anwaehlen, und zwar fuer jeden Track separat. Statt eines MIDI Events sendet der Sequenzer den Step also einfach an das CV Modul. Ja Ja - wie ich sehe, hast Du doch alles richtig verstanden :) 2x40 LCDs gibt es guenstiger bei voti.nl (kann man gleich zusammen mit den Encodern bestellen). Gehaeuse und Frontplatte: hier sind die anderen gefragt Gruss, Thorsten.
  12. Ok, sample is angekommen. Der Sound hoert sich bereits ziemlich clean an, kein Brummen und kein Zirben, welches man durch zusaetzliche Hardware unterdruecken koennte. Was im Hintergrund noch uebrig bleibt, ist der Output der drei Oszillatoren. In Deinem Beispiel wird nur ein Oszillator verwendet, die anderen beiden stehen auf "Off". Das kann auch so bleiben, ich wuerde Dir jedoch empfehlen, diese Oszillatoren genauso wie den ersten einzustellen. Zusaetzlich koenntest Du sie noch auf -64 transponieren, dadurch sollten sie wesentlich leiser werden. Mehr laesst sich nicht machen - der VCA kann einfach die OSC Outputs nicht komplett runterregeln. Gruss, Thorsten.
  13. yes, all unused analog inputs of the J5 connector have to be connected to ground as well, no other pins of the PIC (!) Best Regards, Thorsten.
  14. Hi Justin, some applications require this (not sure if this is the case for MB64), so just add a "movf MIOS_PARAMETER1, W" before branching to the handler. it looks very compact :) Best Regards, Thorsten.
  15. I like the band, too! I've purchased the Live DVD from http://www.c64audio.com/ some time ago, their performance is just great! :) Best Regards, Thorsten.
  16. Hi Verbel, pay attention for the faders, there are different ones! For audio applications, they normaly have a logarithmic output curve, but such a characteristic is absolutely unusable for MIDI. Especially stereo faders are only for audio, so it should be a mono fader with 10k linear output (it's not possible to convert log->linear properly!). For the buttons look for "normaly open" types, it doesn't matter, how many poles they have, but single pole buttons are normaly cheaper. Required Modules: MBHP_CORE, MBHP_AINX4 (for faders/pots) and MBHP_DINX4 (for buttons). MBHP_USB isn't really cheaper than a commercial MIDI interface today, and this project is especially not easy to handle for newbies, therefore just buy an interface for less than 40 EUR Or take the MBHP_LTC module for the to-COM option MBHP_BURNER: not required if you buy the PIC at SmashTV's or Mike's Shop, they will program the bootstrap loader into the flash. But you need to tell them, if the to-COM baudrate should be enabled or not, because this option cannot be easily changed via MIDI Best Regards, Thorsten.
  17. Hi Justin, welcome back! :) You only need to invert the button value at the beginning of the USER_DIN_NotifyToggle hook, this could be done with "comf MIOS_PARAMETER2, F" - if only a certain number of buttons should be inverted, you need to check the button number in MIOS_PARAMETER1 before Best Regards, Thorsten.
  18. Great! So, the analog inputs are working. Next steps: upload the MIDIbox64 application, it should also send random MIDI events. Thereafter tie all unused analog inputs to ground (or connect all pots you have with the right pinning) to avoid this Your box should be ready for use then :) Best Regards, Thorsten.
  19. What happens when you upload the ain64_din128_dout128 application? If still no MIDI events are sent, could you please post a SRAM dump here? You can do this with MIOS Studio: open the debug window, select the "SRAM read" function, enter Address: 0x000, No. Bytes: 0x600 (see also: http://www.midibox.org/mios_studio/mios/gui/help/mios_debug_functions.html Best Regards, Thorsten.
  20. Alright, the upload works fine, but it seems that there is a problem with your pot. The SysEx message (it's an upload request, the first number is the "timestamp") is not intended, it seems that once you move the pot, the core will be reset, even when there is no application running which scans for pot values. So - propably you've connected the pot in the wrong way (ground and +5V should be connected to the outer pins, the analog input of the core or AIN module should be connected to the middle pin). Or maybe your pot has a different pinning? If you own a multimeter, you can measure this. What does happen if no pot is connected at all? Upload the MB64 application and put your finger on the (open) analog inputs - the core should send a lot of random MIDI controllers. Btw.: after this experiment, connect all unused analog inputs at the core and AINX4 module to ground, otherwise the random MIDI events will always be sent Best Regards, Thorsten.
  21. This message indicates, that the core has been reset. Maybe MIOS (or the application) has not been uploaded successfully, even when MIOS Studio reports this? You can verify the MIOS program range with the CRC application. Just upload it, and check the sysex message which will be sent out. It should be: F0 0B 0B 01 05 F7 Do you see this message, or something else? Best Regards, Thorsten.
  22. Vielleicht sehe ich es zu sehr von der Programmiererseite. Sobald die Trigger Bedingung eintrifft (bspw. Level > -50 dB) muss das Gate ja geoeffnet werden. Wuerde man es sofort auf 100% oeffnen, wuerde man auch ein deutliches "Ploppen" vernehmen. Also oeffnet man es langsam mit der eingestellten Attack Rate. Ist diese groesser als die Attack Rate des Eingangsignals, so wird der Klang verfaelscht. Ok, ich revidiere meine Meinung, und sage demnaechst, dass sich ein Envelope Follower mit Look Ahead Funktion einfacher konfigurieren laesst ;-) Gruss, Thorsten (benutzt lediglich das "Kill Reverb" Preset)
  23. Nein, ist nicht unbedingt notwendig, MIOS erkennt automatisch, dass kein LCD angeschlossen ist. Doch noch ein Tip am Rande: wenn Du dem Sequencer zumindest ein 2x16 LCD spendierst (gibts fuer EUR 7.50 bei Reichelt), koenntest Du den Sequencer komplett ueber eine MIDI Tastatur konfigurieren: http://www.ucapps.de/midibox_seq/mbseq_remote_functions.pdf Gruss, Thorsten (so, das war das letzte Posting dieses Jahr ;-)
  24. Hallo, Du koenntest die Vintage Option nachbauen, und diese so stark reduzieren, dass sie Deinen Anspruechen entspricht. Also: ein Core Modul, ein DINX4 Modul (nur die 16 "General Purpose Buttons", sowie den Play/Stop Button bestuecken), ein AINX4 Modul (nur die ersten 16 Potis anschliessen, die restlichen analogen Eingaenge am AINX4 Modul und am Core Modul auf Masse klemmen!) MIOS und die MBSEQ Applikation (setup_mbseq_vintage.hex) aufspielen - und schon kann es losgehen :) Die Geschwindigkeit wuerde ich vom Virus aus regeln, so dass der Sequenzer auch on-sync mit dem Delay Fx ist. Spart ein zusaetzliches Poti, und ist sowieso sinnvoller. Saemtliche MBSEQ Parameter lassen sich uebrigens via CCs aendern, vielleicht auch vom Virus aus (falls er CCs senden kann) - damit sparst Du das LCD: http://www.ucapps.de/midibox_seq/mbseq_cc_implementation.txt Per default wird sich die MBSEQ jedoch bereits so verhalten, wie Du es moechtest... Gruss, Thorsten.
  25. Hallo Moroe, der Joystick Anschluss bietet (meistens) einen MIDI Eingang, deshalb kann man davon ausgehen, dass das Keyboard sich diesen zunutze macht. Vermutlich befindet sich das MIDI Signal auch schon auf TTL Pegel, Du brauchst also lediglich zwei 220 Ohm Widerstaende, sowie eine DIN Buchse, um den Anschluss MIDI-Kompatibel zu machen. Hier die Anschlussbelegung des Joystick-Steckers: http://www.hardwarebook.net/connector/userinput/gameportpcmidi.html An Pin 1 befindet sich 5V - diesen via 220 Ohm Widerstand an die DIN-Buchse An Pin 15 befindet sich der MIDI Out des Keyboards - diesen ebenfalls via 220 Ohm an die DIN-Buchse Um die richtige Polung herauszufinden, kannst Du Dich nach dem Core Schaltplan richten: http://www.ucapps.de/mbhp/mbhp_core.pdf Gruss, Thorsten.
