TK.
Administrators
    15,248
  1. I removed all references to the CNY17 from my website because of the bad experiences with this optocoupler. It doesn't work together with all MIDI interfaces Best Regards, Thorsten.
  2. Great! :) Best Regards, Thorsten.
  3. I agree with SounDuke. The shorts you noticed could be the reason why the whole circuit is not working anymore, because they could have damaged the transistors (or not...) - it's hard to find this out, especially when you don't know that the module plays together with your PC and windows installation. You could either build a less error-prone programmer like MBHP_BURNER (btw.: I will hide the JDM page as soon as the PCB is ready, because people still ignore the warnings) --- or you could ask somebody from the forum to burn your PICs (for free!) Best Regards, Thorsten.
  4. thats the same connector I had for my first headphones - the advantage was, that I was able to use it for stereo in one direction, and for mono (both channels connected together) in the other direction. Best Regards, Thorsten.
  5. I still don't get the point. Could you please write down exactly the button assignments for which you are searching for? Best Regards, Thorsten.
  6. Are you sure, that your host software doesn't provide such a transpose function? With a Logic Environment this wouldn't be a big problem. If not, you could use either another host, or a plug-in-able (sorry for the strange word ;-)) host like EnergyXT, which provides such functions http://www.xt-hq.com/ Best Regards, Thorsten.
  7. Interesting - this confirms again, that JDM troubles are mostly related to the PC or software environment. It's a big advantage to have a lot of friends (with a lot of different PCs ;-) Best Regards, Thorsten.
  8. You could use the same connectors, but don't do it - the risk that you or somebody else mixes the two connectors and destroys your MIDIbox or any other MIDI gear is too high. Instead just use an alternative format for the PSU plug/socket - there are different DIN formats available, and they cost exactly the same price like a MIDI plug/socket pair Best Regards, Thorsten.
  9. Thats very unlikely - 1) because the flash programming mode is an independent mode which works regardless of the flash content (only exception: if the programming protection has been activated - but it will be deactivated when you erase the whole flash via IC-Prog) (*), and 2) because MIOS and the BSL erases automatically each 64byte sector before it should be programmed. If it wouldn't do this, it wouldn't cause any damage. The effect would be, that old 0s cannot be turned into 1s, MIOS would report an verify error They only reason I know, why a particular PIC cannot be burned is, that the 10k pull-down at RB5 is missing, because this is a random effect (sometimes it works without this resistor, sometimes not...) Best Regards, Thorsten. (*) Sidenote to avoid wrong assumptions: MIOS doesn't modify the protection, and it's very unlikely that this is done by a programming error due to a specia unlock sequence which is required to access the configuration sector
  10. This is the nice looking MIDIbox64 of Greg, he wrote:
  11. Maybe I just don't understand your idea... but... what is the advantage? If a button function of the second layer should always be available, why you don't specify it in all layers at the same position (=pin)? Best Regards, Thorsten.
  12. Maybe it would help to know, which changes you are doing exactly. Are you able to build the original release without any modification? Best Regards, Thorsten.
  13. Previous posting splitted to: http://www.midibox.org/forum/index.php?topic=5543.0 Best Regards, Thorsten.
  14. It is - $10 + taxes + shipping is a fair price compared to the effort which is required to build a discrete filter Yes, it's just the TB303 mode - not the typical TB303 sound. In fact I wasn't able yet to realize the same filter behaviour like on my moog-filter yet, I think that I have to optimize the OP stage at the end of the DAC, or the voltage divider at the CEM3378 filter CV input in order to fix this. However, the filter gave me some enjoyable hours today, it already makes a lot of fun to play with this toy :) Fx processor: there was a guy who realized a DSP project for such jobs, search for "miss parker" in the forum On the other hand: I prefer the use of VST plugins. The usage is simple and more flexible. Best Regards, Thorsten.
  15. Great that it is finally working :) I will answer both questions at the same time: the best PSU solution is the one which is documented in this schematic http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf - it's exactly the circuit that I'm using, and my MBSID is stuffed with 2x8580 and 2x6581 - the same like yours This PSU should also be sufficient to power the PLED display Best Regards, Thorsten.
  16. This posting contains the same content like "type c part list", which one should be removed? Edit: since Kokoon already replied to this posting, I deleted the other one
  17. Please let us know if your MBHP_BURNER is working (Mike currently creates a PCB, I want to get a feeling about the "success level" before the first release) Best Regards, Thorsten.
  18. I'm not a windows expert, and this issue seems to be software related. Did anybody else noticed that ICprog crashes? Best Regards, Thorsten.
  19. I don't think that this is a problem with the core - is this correct: you are getting random MIDI messages even when all analog inputs are tied to ground? Then I would assume, that you forgot the 10k pull-up resistor R9 at pin RD1 Check also, if the 1k pull-up resistor R2 at pin RA4 is connected properly Best Regards, Thorsten.
  20. It definitely makes sense to deactivate all drivers which are using the COM port. And as Raphael mentioned, it makes sense to follow the tips of the JDM page - what are the results of the voltage checks? Best Regards, Thorsten.
  21. Nachdem ich zweimal zum Conrad radeln musste, da diverse Bauteile fehlten (besorgt Euch einen 7905 !), konnte ich den CEM3378 heute in Betrieb nehmen - Report hier: http://www.midibox.org/forum/index.php?topic=5538.0 Gruss, Thorsten.
  22. Today I did the first experiments with a CEM3378 filter, which some of the germans purchased in a collection order from synthtech.com A top view of the workbench: Right side: A AOUT_LC module based on the schematics from Karl Dalen. It mainly consists of 2 * 74HC595 and not less than 36*10k resistors to realize a 12bit DAC, which controls the Cutoff frequency. The final version I'm planning will consist of 48*10k resistors for an 12bit DAC (CutOff) and 4bit DAC (Resonance) (I guess that the resolution is enough, especially because I have to build 4 of them ;-) In addition this module has an OP-Amp to control the gain and offset of the output CV - for the filter it turned out that this is a very important feature Bottom: the CEM3378 circuit (based on the datasheet) + a +/- 5V voltage regulator. Both, the filter and the AOUT_LC circuit are powered with this low biased voltage. In addition, the CEM3378 needs +12V Left side: ok, my beloved MBSID And here the first demo - MBSID in TB303 mode, controlled via MIDI (internal sequencer not used) - filter/envelope parameters tweaked in realtime http://www.ucapps.de/mp3/midibox_sid/mbsid_demo11.mp3 IMHO the filter sounds very good, especially on filter sweeps it can be noticed that the volume doesn't get lower even when resonance is close to self-oscillation. During the first tests I also noticed, that key-tracking is a must for such a filter. Therefore I implemented it into the firmware (CC#6) - now I have to find a way to store this value, because the SysEx data structure is completely allocated :-/ Best Regards, Thorsten.
  23. Search in the forum for "interconnection_test" and "interconnection test", there are a lot of hints within the appr. articles, how to debug the SID module Best Regards, Thorsten.
  24. I just noticed that you are using the wrong JSynthLib version, please use this one: http://www.midibox.org/jsynthlib/JSynthLib-0.20.0_midibox_mod1.jar.zip Best Regards, Thorsten.
  25. Wenn Du den Parameter dort aenderst, muss er auch an anderen Stellen geaendert werden. Welche das genau sind, kann ich Dir nicht so ohne weiteres sagen, zumal in Deinem Fall ja auch der LFO Depth3 Parameter (CC#74) umgelegt werden muesste (ich habe so etwas der einfachheit halber nie vorgesehen, und Du bist der erste, der danach fragt) Vielleicht ist es sicherer, den eingehenden CC einfach in der Empfangsroutine zu konvertieren. Oeffne mal sid_midi.inc, suche nach SID_MIDI_CC und fuege folgendes ein: SID_MIDI_CC SET_BSR SID_BASE ;; convert CC#74->CC#46 movlw 74 IFNEQ MIOS_PARAMETER2, ACCESS, rgoto SID_MIDI_CC_Not74 SID_MIDI_CC_74 movlw 46 movwf MIOS_PARAMETER2 SID_MIDI_CC_Not74 [/code] Gruss, Thorsten.
