TK.
Administrators
    15,248
  1. These applications got a new patch mode feature some months ago, but I never found the time to write a documentation about the new possibilities. However, they also include some bugfixes which had been reported by users, therefore I release them "as they are": o a patch mode has been implemented which can be selected as an alternative option to the common "bank" mode in main.asm In patch mode, each BankStick contains only one bank configuration (means: pot/button/label setup), but 128 snapshots! This allows you to prepare one configuration for your MIDI gear, and to store/recall/morph up to 128 scenes. o there are two new SysEx commands for storing/restoring patches o patches and banks can be changed from external with a "Program Change" command. The channels are specified in main.asm. Default: Channel 16 - Banks; Channel 15: Patches o some minor bugfixes and improvements [/code] Best Regards, Thorsten.
  2. MIDIbox MM V2.0 is the first application which has been completely written in C. For myself it is a prototype for the MIOS Wrapper and a nice demonstration example, how HUI protocols can be handled with MIOS. Another application which will be available soon is the ported MIDIbox LC (it's nearly finished, but I want to complete the MBSEQ hardware option before the first release - means: you will be able to use a Mackie/Logic Control emulation with your MIDIbox SEQ V2) In addition I'm planning to port MIDIO128, MIDIbox TC, MIDImon and MIDIbox CV in the next months to improve the re-usablility. There will also be a new application: MIDIbox KMK (Korg microKontrol) emulation However, here the changelog for MIDIbox MM MIDIbox MM V2.0 ~~~~~~~~~~~~~~~ o the complete application has been ported to C More infos about how to compile the code can be found under http://www.ucapps.de/mios_c.html MIDIbox MM V1.0 ~~~~~~~~~~~~~~~ Initial version which emulates the Motormix nearly completely: o eight motorfaders send and receive position data with 10 bit resolution o eight touch sensors can be connected o eight virtual pots (rotary encoders) send relative events o one additional rotary encoder ("jog wheel") sends relative events o all 67 button functions are available o all 72 LED functions are available o two status digits (7 segment digits) o messages are displayed on a 2x40 LCD (only!) Additionally this application provides following functions: o a dirty hack makes it possible to add eight LEDrings to the V-Pots. However, the host application must send the absolute V-Pot position to the display - currently it only works with Sonar, Cubase doesn't get use of the so called "rotary pointer" (see Motormix specification) o a layer function which allows to map Motormix button functions and LEDs to a smaller number of buttons (additional "Shift Key") o 128 general purpose controllers can be send with the V-Pots in GPC mode o optional "dont-send-if-touchsensor-not-pressed" function (disabled by default to avoid confusion, but heavily recommented if touchsensors available) Following function of the original Motormix is not implemented: o different graphical forms of the "rotary pointers" at the lower LCD line, since the graphics are not documented. Instead, always a vertical bar + the decimal value will be displayed Additional Notes: o Meters are not supported by the Motormix protocol o MTC digits are not supported by the Motormix protocol o LEDrings normaly not supported by the Motormix protocol. The LEDring hack works only with Sonar, and not with Cubase o the two 7 segment digits have to be connected directly to the shift registers --- no multiplexing required o only one 2x40 LCD is supported by the Motormix protocol o tested with the MIDIbox NG hardware, buttons and LEDs are assigned according to the existing design. The mapping can be changed in mm_io_tables.inc o *IMPORTANT* since I'm a Logic user (and therefore prefer the Logic Control emulation), this application has only be tested with following demo programs: o Sonar 3 Producer Demo Edition o Cubase SX Demo V1.02 No guarantee that it also works with other versions o Note for Cubase users: most buttons are not assigned to a function by default - you have to do this by hand in the device configuration! It seems that these functions don't have a LED feedback, but this could be different in newer Cubase versions. Please read also the "Remote Control Devices" Documentation which can be found at the Steinberg Website [/code] Best Regards, Thorsten.
  3. TK.
    MIOS V1.8
    The public release of MIOS V1.8 is finally available at the http://www.ucapps.de/mios_download.html page Changes: the interrupt handler now also saves FSR0L and FSR0H. This allows the use of C programs compiled with sdcc a wrapper for the SDCC compiler is now available in a seperate package. More informations can be found under http://www.ucapps.de/mios_c.html the motorfader driver has been overworked. The new concept works with a "dynamic deadband" and a definable PWM which will be used once the fader reaches the target position. The details are described at http://www.ucapps.de/mbhp_mf.html on a MIOS up- or download, the BankStick number is now selected with an address extension, which is part of the SysEx command the "Brown Out Reset" (BOR) settings in the configuration sector are changed automatically when MIOS detects unproper settings - the appr. cell in this sector will be overwritten and the device will be reset. New Setting: Brown Out Reset at 4.5V This ensures that the PIC won't access devices during power-off which cannot operate at voltages < 4.5V (e.g. the BankStick, which could get an unintended write command) support for PIC18F4620 (64k flash device) --- in the source code only (no precompiled binary available) Unfortunately this derivative is currently not qualified for MIOS due to a silicon bug in the EUSART peripheral (rev3) Some words to the PIC18F4620: Synapsys informed me about this new derivative some days ago (thanks Bob!) - it is a great replacement for the PIC18F452, because it is pin compatible and provides 64k flash (two times more than the 18F452), 3966 bytes RAM (> two times more than the 18F452), 4k EEPROM (four times more than the 18F452) There is already an updated Bootstrap Loader in the CVS which is located to 0xfc00. Also the mk_syx script has been updated in order to support the upper memory area (thats the reason for the new "address extension" in the SysEx upload/download command). So: this could be the future chip for the MBHP platform, because the price isn't much higher, but the benefit is -- let's say --- unbelievable! :-) It opens a lot of new possibilities for applications which ran out of memory, especially for MIDIbox SID, FM and especially SEQ BUT: the current silicon release contains the same EUSART bug which I found on the PIC18F4550 (I checked this with a rev3 sample) - It makes the chip unusable for high-performance MIDI applications! Therefore please DON'T BUY THIS CHIP yet, until Microchip has regognized that this is a serious problem, and released a new silicon version. This could take some weeks, some months, ... nobody knows. There is a workaround, but I must say that this won't be supported from my side due to development effort and performance drawbacks: by using an external USART, which is connected via SPI or IIC it should be possible to realize reliable MIDI transfers. But this can only be a "tinkering solution", it requires changes in MIOS and increases the CPU load I prefer to wait for a full functional silicon. Once available, just replace the PIC18F452 and be happy about a lot of new possibilities :) ----- Following applications have been updated: mf_calibration: due to new MF driver mf_direct_control: due to new MF driver midibox_hn: due to new MF driver midibox_lc: due to new MF driver, got also some minor bugfixes midibox_mm: due to new MF driver, has been completely rewritten in C skeleton_v1_8: due to new MIOS release sdcc_skeleton_v1_0: first C wrapper release Have fun! Best Regards, Thorsten.
  4. Kann es sein, dass Deine MIDIbox noch mit einer alten MIOS Release laeuft? Gruss, Thorsten.
  5. Hi Heitor, thanks for your interest. :) It is very important that you are working exactly on the current flow, otherwise you will produce a lot of additional effort at my side (please don't! :-/) Moxi: could you explain how you edit the pages in the meantime? Best Regards, Thorsten.
  6. Why did you open a new thread to the same topic? As I already wrote, there is no memory free for snap mode - not only flash, but also RAM (snap mode requires a copy of the last pot values) Please believe me that an enhancement into this direction requires a lot of conceptional changes in the MB64E (e.g. forget the possibility to handle 128 positions in RAM) There is no 1-2-3 solution, otherwise you would find it already in the application (isn't this clear?) Best Regards, Thorsten.
  7. How are these rubber switches normaly adapted to a keyboard controller? I've no idea how the hardware looks like, do you have a schematic? Best Regards, Thorsten.
  8. Thanks Marcel - a lot of stuff to read! Best Regards, Thorsten.
  9. Hi Jeff, Do you know more details why MIOS doesn't run on this chip? normaly not, you have to downstrip MIOS (e.g. remove the routines for graphical LCDs), and you have to put the "application" directly into the MIOS source in order to save memory. You can download it from the CVS - here a link to the web interface: http://cvs.sourceforge.net/viewcvs.py/mios/mios/ It is possible to use MIOS without bootloader, but this means that MIOS itself cannot be updated via MIDI, and that a PIC programmer has to be used instead. This is much less comfortable, and especially slower than updating the code via MIDI. Yes, just search for "PIC_DERIVATIVE_TYPE" in the bootstrap loader and MIOS source code These are the places which have to be adapted Best Regards, Thorsten.
  10. Hi Adam, the output voltage of the 74HC595 is 0V..2.5V, it depends on the following analog circuit if a biased voltage is required or not. If I should ever make a PCB for the AOUT_LC module, I will prefer a biased voltage, because all filters I own are working with biased voltages, too... Best Regards, Thorsten.
  11. Hi, yes with 2 OPL chips you have the choice of 4 audio outputs The number of external filters is limited by the number of audio outputs, the CVs for the filters can be mapped to any voice no, this has to be managed by yourself - in real life this is no limitation, up to 8 BankSticks can be connected -> makes 1024 patches. It's possible to play chords in poly mode, but in this case all 3 oscillators are routed through a single filter. The "super poly mode" which allows you to play 4 SIDs over a single MIDI channel in polyphony is still a planned feature, but with some sequencer tricks it's already possible - see http://www.ucapps.de/midibox_seq_tutorial1.html Best Regards, Thorsten.
  12. Yes, it should. You could use MIDI-Ox or another MIDI monitor in order to check if any message is sent by the core. If this is the case, you can search for the reason in your MIOS Studio Setup Just follow each point of the MIDI Troubleshooting Guide until you find the error Best Regards, Thorsten.
  13. Hi, I guess that you need at least a keyboard matrix with double pole switches at the hardware side, and n delay counters (n = number of keys) at the software side. This should allow to measure the time which passed when you started to press a key (upper contact gets deactivated), and reached the bottom of the key (lower contact gets activated) The main reason why you cannot find an application which supports velocity is just, that I don't own such a keyboard which I could use for experiments Best Regards, Thorsten.
  14. these are high-frequency signals which cannot be measured with a multimeter obviously not, otherwise it wouldn't send a request message It's clear, MIOS hasn't been uploaded completely. I'm not sure why, maybe you haven't selected the right MIDI In Port in MIOS Studio, so that the upload tool doesn't receive the return message from the core. This would explain why only one block has been uploaded. So: check the MIDI configuration in MIOS Studio (you should see the request message in the MIDI IN monitor of MIOS Studio) Alternatively you could try to upload MIOS with the "Don't use feedback from core" option Keep in mind that MIOS itself has to be uploaded within 2 seconds after power-on. Without the feedback option, you could enable the "Wait for upload request" option instead. power-on the core and wait until all blocks have been uploaded --- but this feature really requires a proper MIDI connection Best Regards, Thorsten.
  15. Evtl. die Release Zeit der VCA Huellkurve zu hoch gedreht? Gruss, Thorsten.
  16. TK.
    74HC595
    Es ist knapp an der Grenze, doch mit normalen LEDs (Rot/Gelb/Gruen) treten damit keine Probleme auf. Blaue LEDs sind jedoch eine Ausnahme, manche benoetigen 30 mA und mehr (Herstellerspezifikation lesen!)... hierfuer ist ein 74HC595 (ohne zusaetzlichen Treiber) sicherlich ungeeignet Gruss, Thorsten.
  17. TK.
    MBLink FP und EP
    Hallo Markus, fuer den MIDIbox Link musst Du den Source Code nicht modifizieren, bei den meisten Applikationen laesst sich das auch vom User Interface (bzw. vom .syx Konfigurationsfile) aus einstellen. Der MIDI Merger des letzten Cores sollte auf "MBLink EP" (Endpoint) eingestellt werden, der Merger der uebrigen Module auf "MBLink FP" (Forwarding Point) Entferne Deine Modifikationen am besten wieder, die bringen den Datenfluss nur durcheinander. Gruss, Thorsten.
  18. TK.
    74HC595
    ja, das koenntest Du bspw. machen. Der Tristate Mode ist vor allem dann interessant, wenn die Ausgaenge mehrerer Shift Register zusammengeschaltet sind (Bus-Treiber) Ausgang QA bis QH aktiviert/deaktiviert Gruss, Thorsten.
  19. TK.
    MBLink FP und EP
    Hallo, zu welchem Deiner Postings gehoert diese Frage? Ich fuehle mich verwirrt ;-) (Bitte die Thread Struktur einhalten) Gruss, Thorsten.
  20. Hallo Moritz, ja, beides ist richtig. ja, das war gemeint. Bei der MIDIO128 kann man bspw. auch eine 1-zu-x Steuerung realisieren, bei der ein einziges Event (bspw. ein Program Change), mehrere ausgaenge gleichzeitig schaltet. Ja, ihr benoetigt 4 DOUTX4 Module und ein CORE Modul. Zusaetzlich ein PIC Programmiergeraet (JDM oder besser PIC_BURNER), wobei hier jedoch optional jemand aus dem Forum den Bootstrap Loader flaschen koennte (MIOS und MIDIO128 werden ueber MIDI aufgespielt) Gruss, Thorsten.
  21. yes, no free memory for all this stuff Best Regards, Thorsten.
  22. Hi, I haven't noticed this effect yet, could it be that a scanner or printer driver is running in background which accesses the LPT port from time to time in order to detect a connected device? I have a similar problem when my Mustek scanner driver is active Best Regards, Thorsten.
  23. For one of future releases I'm planning an AOUT mapping feature which allows you to map these analog outputs to internal/external CC/Note events (so: 512 possibilities!). So, it's not only possible to control the outputs from internal stuff like envelopes/LFOs/etc... or static parameters, but also from the wavetable sequencer or --- of course (this is the easiest thing) from external notes or CC The implementation will be similar to MIDIbox FM, for myself it's low priority since it can already be changed in the source code (so, the functionality is already available for somebody who knows the internals). I collect all the requirements before starting with this part, so that I don't miss anything which could "hurt" in the future (incompatibility issues) I will provide a very detailed description once I find the time. To give you an impression: last weekend I overworked the MBHP_MF page (http://www.ucapps.de/mbhp_mf.html), it took me several weeks until I reached the right mood for writing down all this stuff. A similar "delay" can be expected for the TB303 mode description ;; 0: no AOUT module ;; 1: enable access to the AOUT module via Port J6 ;; 2: enable access to the AOUT_LC module via Port J6 #define ENABLE_AOUT 2 [/code] [code] ;; -------------------------------------------------------------------------- ;; FUNCTION: SID_AOUT_LC_Load2SR ;; DESCRIPTION: This function loads a 16bit value into the shift register ;; IN: o low byte of SR value in TMP1 ;; o high byte of SR value in TMP2 ;; OUT: - ;; USES: TMP[12345] ;; -------------------------------------------------------------------------- BIFCLR SID_SE_OPTION, SE_OPTION_TB303, BANKED, rgoto SID_WT_Branch_Play_NotTB303 SID_WT_Branch_Play_TB303 ;; in TB303 mode: ;; increment tick counter, reset if counter >= 6 incf SID_WT_303_TICK_CTR, F, BANKED movlw 0x6 cpfslt SID_WT_303_TICK_CTR, BANKED clrf SID_WT_303_TICK_CTR, BANKED ;; play note when counter-1 == 0 decf SID_WT_303_TICK_CTR, W, BANKED bz SID_WT_Branch_Play_TB303Note ;; release gate when counter-1 == 3 decf SID_WT_303_TICK_CTR, W, BANKED xorlw 3 bz SID_WT_Branch_Play_TB303G0 rgoto SID_WT_NextClkLoop SID_WT_Branch_Play_TB303G0 IRQ_DISABLE ;; exception: don't clear when slide is active BIFCLR SID_WT_STATE, WT_STATE_SLIDE, BANKED, rgoto SID_WT_Branch_Play_TB303G0_Clr SID_WT_Branch_Play_TB303G0_Slide bsf SID_WT_STATE, WT_STATE_SLIDE_PREV, BANKED rgoto SID_WT_Branch_Play_TB303G0_End SID_WT_Branch_Play_TB303G0_Clr bcf SID_WT_STATE, WT_STATE_SLIDE_PREV, BANKED bcf SID_V1_BASE + SID_Vx_MODE, SID_MODE_GATE_SET_REQ, BANKED bsf SID_V1_BASE + SID_Vx_MODE, SID_MODE_GATE_CLR_REQ, BANKED ;; rgoto SID_WT_Branch_Play_TB303G0_End SID_WT_Branch_Play_TB303G0_End [/code] (the counter has a predivider --- it's the WT rate --- and it can be synched to MIDI clock) The beta release is already available on request In fact everything is finished since 2 weeks, only the documentation is missing ;-) Best Regards, Thorsten.
  24. TK.
    Schaltung
    Hallo, Im prinzip wird es so funktionieren, allerdings muss der MIDIbox Link Port so wie auf folgendem Diagramm zu sehen verdrahtet werden: Auf keinen Fall die anderen Pins auf Masse legen! Gruss, Thorsten.
  25. TK.
    USB PIC Module
    dann muss man entweder warten, bis TK seine 1000 andere Plaene verwirklicht hat, bis er dazu kommt, sich in den AVR einzuarbeiten, oder man muss hoffen, dass jemand anderes diesen Job uebernimmt ;-) Gruss, Thorsten.
