15,248 -
Ooops - He did it again! Based on experiences with his sensational 2 x MIDIbox LC design (http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=gallery;action=display;num=1050012551), Axel redesigned his MIDIbox completely to a 24 motorfader device (1 master LC, 2 slave LCs). Hope that he will find the time to answer all your questions! :-)
ToFiC sent me these pictures some weeks ago, but I haven't found the time to integrate it into the MIDIbox gallery yet. On the other hand I don't want to wait any longer to introduce his great design! Well done! :) (more pictures can be found under http://perso.wanadoo.fr/kasper.korrils)
I've no idea, since you never mentioned which application your are using. With MB64E you've up to 128 encoder entries, they have to be referenced with the functions under mb64e_fsr.inc Best Regards, Thorsten.
Hi Thomas, could it be that you haven't found the MIOS bootstrap loader page yet? It describes the required steps for the code upload: http://www.ucapps.de/mios_bootstrap.html It's simpler and less error-prone than using the JDM - and especially: it's much faster! Therefore this is the only way I'm suggesting on my website - everything else would lead to an immense amount of additional support effort. Once you've learned how to program a single MIOS core via MIDI, you will be able to program the other cores within 5 minutes - believe me ;-) Therefore I don't understand why parallel programming would be required (btw.: it works, but only with expert knowledge) For the SID application you want to assign unique MIOS device IDs as well as unique SID device IDs to the 4 cores. See also http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1075154388;start=4#4 And if the MIDI connection shoudln't work, here another useful page: http://www.ucapps.de/howto_debug_midi.html Best Regards, Thorsten.
Hi, I haven't noticed such a problem with my display, which is 4 times slower then a CLCD, therefore I still assume it isn't a software problem (buffer overrun or whatever), but an electrical problem. The host software only updates small pieces of the display view when it has been changed. This explains, why random characters are still visible. You could check, if this was a problem with the MIDI In line or with the display lines by changing the display page. This refreshes the display. If random characters are still visible, you know that the connections to the LCDs are not affected. Thereafter you could check if the same problem appears when Motorfaders are disabled (I guess that you already know the MF_ENABLED switch in main.asm) -- if no random characters appear anymore, you know that the MF module influences the core voltage (and especially the core supply voltage) Best Regards, Thorsten.
Hi, you've connected the encoder to the pins which are normaly used for the menu navigation. I guess that you haven't adapted the MB64E setup to your hardware, no? The problem is that I currently haven't time to explain the setup detailed enough, so maybe somebody else can help? It would especially be helpful if somebody could write down some step-by-step instructions for the MIDIbox configuration, because it seems that the comments in the source files are too confusing for non-programmers. Jimminy: in the meantime you should try the MIDIO128 application. If this application sends multiple MIDI events with a single push on a button, you've definitely a hardware problem. If it sends a single event, you've a configuration problem. Best Regards, Thorsten.
Hallo, die Probleme mit dem Filter kann ich bestaetigen - einige 6502 klingen nach 15-20 Jahren nicht mehr so toll. Aber der 8580 ist sowieso der bessere SID. :) Das Oszillator-Problem ist mir neu. > nachdem ich meine midibox sid noch immernicht zum laufen gebracht ich habe Dir bereits vor zwei Wochen angeboten, dass Du mir das Core/SID Modul einfach mal zuschicken kannst... nachdem ich soviel Zeit investiert habe, um Dir beim Debuggen zu helfen, moechte ich unbedingt mehr ueber die eigentliche Ursache wissen. Nich zuletzt, um anderen Leuten mit aehnlichen Problemen passende Ratschlaege geben zu koennen, ohne die ganze Prozedur noch einmal durchziehen zu muessen. Gruss, Thorsten.
Hallo, ist das Patch Format denn irgendwo dokumentiert? Dann wuerde ein simples (Perl) Script ausreichen, um die Sounds in das MIDIbox SID Format zu konvertieren. Das gleiche gilt uebrigens auch fuer die SIDstation (die Beschreibung der SysEx-Struktur kann man von der Elektron Homepage downloaden) - doch leider hat sich bisher noch keiner gefunden, der die Arbeit uebernehmen moechte. Gruss, Thorsten.
Hallo, das Protokoll ist im englischen User Manual beschrieben, und das kann man irgendwo auf der Emagic Seite downloaded (weiss leider auch nicht mehr, wo genau - ist schon etwas her...) Gruss, Thorsten.
Chriss' hint is very important - in my own MBHP_AOUT layout I will take care about multiturn trimmers, because it's too difficult to calibrate the output voltage with a common pot. Balanced outs: thats a new feature especially for synths with -4V/4V inputs (like Kobol). I will add some more words about this extension once I find the time! (currently I'm very busy@work, so - not before end of next week...) This extension isn't required for common analogue synths, so just ignore it if you haven't heart about balanced CVs before. Best Regards, Thorsten.
Hi, there is a special meta event which is prepared for this, the answer is somewhere in mb64_meta.inc, mb64e_meta.inc or mbmf_meta.inc, depending on the MIDIbox you are planning to build Best Regards, Thorsten.
And who checks the AOUT schematic??? Just yesterday I found another bug (Ry/R_p have to be connected to E-!) New version can be found here: http://www.ucapps.de/mbhp/mbhp_aout.pdf And there is now also a small extension for a balanced CV output (e.g. -5..5V) http://www.ucapps.de/mbhp/mbhp_aout_balanced_cv.pdf Best Regards, Thorsten.
Hi Thomas, I hope that this picture shows exactly, where the MIOS ID has to be specified: "142" is just an example!! Your IDs: 00 01 02 03 Best Regards, Thorsten.
Spacing between tracks means the clearance between those funny copper lines. It makes sense to visually check if they are too near together (high risk for shorts). RCLK and SCLK are the clock signals between J1:SC -> J2:SC and J1:RC -> J2:RC of the DINX4 module. See also the schematic http://www.ucapps.de/mbhp/mbhp_dinx4.pdf Sometimes people reported exactly the same problem, and the reason was mostly a short circuit between these tracks. So maybe this is something which could be improved in the PCB layout to reduce the failure rate... Best Regards, Thorsten.
Hi, this is correct. The exit button behaves exactly like the "exec" button of the other MIDIboxes. Sometimes people suggested to call this button Exit button, since it makes more sense - so I only followed the suggestions ;-) yes, since there is no other useful purpose for this button within the menu. Advantage: people who are using the sequencer application with a different hardware (e.g. MIDIbox16E users who only stuffed 8 or 16 buttons) are able to start the sequencer without an additional button. Btw.: all known bugs, imperfections and planned features are listed at the bottom of http://www.ucapps.de/midibox_seq.html - it makes sense to check this page from time to time... See http://www.ucapps.de/midibox_seq_options.html (search for "setup_*.asm") and http://www.ucapps.de/mios/mios_encoder_modes.gif Note also that the pinning of some encoders (especially ALPS) is different. Best Regards, Thorsten.
See tutorial #1 http://www.ucapps.de/midibox_seq_tutorial1.html By using the ALL button you can set the Note value for all steps at the same time, thereafter you can mute/unmute the steps with the GP buttons like known from a drum sequencer. You are also able to select another drum sample by using the track transpose function w/o changing the steps. So, I don't see the need for additional drum support - it already works Best Regards, Thorsten.
S* happens, it seems that I modified your message, PayC - this wasn't my intention :-( Do you have a copy of this message? Best Regards, Thorsten.
From your logfile it can be assumed that a single input triggers a lot of MIDI events, so it seems that either RCLK or SCLK is not correctly connected - check your modules for short circuits - check especially the spacing between the tracks. Best Regards, Thorsten.
MIDIbox SEQ V2 is finally available for download ("...in the hope that it will be useful"). Here some informative links: MIDIbox SEQ mainpage: http://www.ucapps.de/midibox_seq.html MIOS Download section: http://www.ucapps.de/mios_download.html MIDIbox SEQ Hardware Options: http://www.ucapps.de/midibox_seq_options.html MIDIbox SEQ User Manual: http://www.ucapps.de/midibox_seq_manual.html MIDIbox SEQ Tutorial #1: http://www.ucapps.de/midibox_seq_tutorial1.html Happy sequencing! :-) Best Regards, Thorsten.
the first contributions have been made: http://logo.midibox.org
Probiere bitte nochmal das aus, was ich weiter oben zur RCLK Leitung geschrieben habe. Evtl. auch mal mit Deinem alten SID Board. Falls es auf dieser Leitungen einen Kurzschluss gibt, waere es plausibel, warum der Interconnection Test im Gegensatz zur MBSID Firmware funktioniert. Gruss, Thorsten.
OOops! Mir faellt gerade auf, dass die Verbindung CORE:J10:Vd -> SID:J2:Vd noch fehlt - so wie unter http://www.ucapps.de/mbhp/mbhp_sid.pdf zu sehen. Hier muessen 5V anliegen. Wie schaut das bei Deinem SID Modul aus? Gruss, Thorsten.
das waere nicht notwendig, der SIDplayer wird ueber eine spezielle SysEx-Sequenz aktiviert, und kann so auch wieder deaktiviert werden. also fuer Presets verschwende ich keinen Flash Speicher ;-) BankSticks sind wirklich nicht soo teuer, wie Du bereits festgestellt hast. (den Hinweis auf Conrad habe ich nun hinzugefuegt) Getrennte MIDI Kanaele gibt es bereits (Source Code Leser wissen mehr ;-)) Allerdings ist die MIDI-Implementierung noch nicht optimal, da die CC's der drei Oszillatoren ausschliesslich auf dem MIDI-Kanal des ersten Oszillators angesteuert werden koennen. Hierzu muesste ich also eine alternative CC Tabelle definieren und einbauen, und dazu hatte ich noch keine Zeit/Lust. Aber solange es nur um die getrennte Ansteuerung geht, kannst Du die MIDI Kanaele auch erstmal via SysEx aendern (und irgendwann dann auch mal ueber das Control Surface...) Gruss, Thorsten.
Hallo Chris, etwas Formales am Rande: Du solltest erwaehnen, dass Deine Box mit der PIC16F basierenden Firmware laeuft, da sie sich an sehr vielen Stellen von der MIOS basierenden MIDIbox SEQ unterscheidet - "MIDIbox SEQ Vintage" ist die (mehr oder weniger) offizielle Bezeichnung fuer die Poti-Option von MIDIbox SEQ V2 Alternativ koenntest Du die Fragen auch einfach an den alten Thread anhaengen, der rutscht dann automatisch nach oben und man erfaehrt mehr ueber die Vorgeschichte. Ok, nun etwas zu den MIDI-Events: sobald der Sequencer laeuft, sendet er permanent MIDI Clock events, so dass sich andere MIDI Geraete mit dem Tempo synchronisieren koennen. In MIDI-Ox gibt es eine Filter-Funktion, mit der die Clocks dann nicht mehr angezeigt werden: Options->MIDI Filter->System Realtime (Filter fuer F8 aktivieren) Danach solltest Du nur noch Start/Stop und die eigentlichen Events sehen. Und hier evtl. das zweite "Problem": auf der MIDIbox SEQ Seite steht geschrieben, dass die Steps gespielt werden, wenn die LED leuchtet. Bei der alten Firmware war es jedoch noch so, dass die LEDs dann aufleuchten, wenn alle Tracks der gleichen Zeile gemuted sind - also nicht gespielt werden. Das ist genau das entgegengesetzte Verhalten. Gruss, Thorsten.
Hi Frank, I haven't found the time to check this yet, but I guess that it could be a performance issue with the encoder driver, since I haven't taken the CPU load into account during the last changes (means: if this is the reason, it can be solved by spenting some special effort on the optimization). Could you please check if the LED rings still display wrong patterns when only 48 or 32 encoders are defined in mios_tables.inc? Just remove the 48th or 32th encoder entry and replace it by ENC_EOT to terminate the table. If it works thereafter, I know where I need to optimize MIOS. Best Regards, Thorsten.
