15,248 -
The plans are already available :-) http://www.ucapps.de/midibox_seq_options.html http://www.ucapps.de/midibox_seq_manual.html Best Regards, Thorsten.
Hi, the last survey shows, that most of you want to have a competition for a new MIDIbox logo. So, here we go - it starts now! All talented designers are invited to attend the competition. Just send your contibution(s) to tk@midibox.org until the dead line of Sunday, 11th April 0:00 GMT. The logos will be published under http://logo.midibox.org at the same day. You are allowed to submit more than one logo. Every forum user will be able to vote for a logo after the 11th. Ofir (who made the first contribution) helped me to work out the rules and suggestions. There are just three rules which have to be followed: the logo should be global and not related to any one religion/country/language/gender or skin color the logo should reflect the spirit of midibox.org (we are not a shoe factory) you must be the copyright owner of the logo (that means not using something done by someone else) And some suggestions: the logo should be black&white only - not even shades of gray (in color as an option) - this is for ease-of-use (think of printing on PCB) please work with a high resolution (150 pixel/inch minimum). better work with a vector format so that the logo is easily resizable. the logo should be simple and clear, easy to see and understand please don't use any of these logos before we chose the one the font "arial black" should be prefered Best Regards, Thorsten.
Hallo, danke fuers Lob! Es freut mich sehr zu hoeren/lesen, dass es auch Leute gibt, bei denen der SID auf Anhieb funktioniert! :) Momentan waere es noch moeglich, aber sobald das AOUT Feature erweitert wird, koennte es mit dem Speicher knapp werden. Andererseits koennte man es als Option anbieten (also entweder AOUT oder SID Player)... schaunmer mal gute idee! Seit MIOS V1.5 ist es moeglich, den BankStick Inhalt komplett zu sichern und wieder aufzuspielen. Diese Funktion koennte man natuerlich auch fuer die Presets benutzen. Werde bei Gelegenheit mal ein entspr. .syx File bereitstellen. Gruss, Thorsten.
Ja, die MD Leitung ist ueberfluessig. Ich war mir damals nicht so sicher, ob ich sie evtl. nochmal brauchen wuerde (bspw. fuer den Core Clock). Aber da Du nicht der erste bist, der danach fragt, werde ich diese Verbindung nun aus dem Schaltplan entfernen. Gruss, Thorsten.
Hallo, Dann eben nochmal die Antwort auf Deutsch... ;-) magic_midi_delay_v1_3 ist nicht kompatibel zur aktuellen MIOS Version, deshalb gibt es seit Januar einen Update. Leider habe ich vergessen, diesen in die Download Seite einzutragen: mios_magic_delay_v1_5 Gruss, Thorsten.
Hi, I just noticed that the wrong version was in the MIOS download area, magic_midi_delay_v1_3 is not compatible with MIOS V1.5 and higher. I've updated the page, please download magic_midi_delay_v1_5 Best Regards, Thorsten.
Hi Dan, it's still available in the tmp directory, see also: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=mios;action=display;num=1066834196 It was accidently released with alpha1, but I removed it again since I cannot support this code (I don't own the hardware for testing...). Best Regards, Thorsten.
Why not trying MIDIbox64E? Best Regards, Thorsten.
I guess that it fails since there must be a delay of some mS before sending any other MIDI data, otherwise the update will be aborted. This is due to the fact that at least the Wavetable (0x80-0xff) has to be stored in EEPROM Therefore it's possible to send a single parameter. So long as it is in between the range of 0x00-0x7f, no delay is required (and sounds can be changed smoothly). The appr. SysEx command is used by JSynthLib. I don't know the possibilities of sounddiver, but doesn't it support a function which sends a single byte of a patch? Best Regards, Thorsten.
Meiner Meinung nach liegt es an der RCLK Leitung, aber nunja. Spaetestens mit dem zweiten SID Modul muesstest Du das merken.. ;-) Motorpotis: danke fuer den Tip! Wusste gar nicht, dass Pollin so etwas anbietet. Fuer die MIDIbox SID sind sie jedoch voellig ungeeignet. Es muesste einiges umprogrammiert werden, ausserdem koennte das Timing der SID Sound Engine ins schwanken geraden. Aber warum ein Motorpoti? Mit Endlosreglern faehrt man wesentlich besser. Kaufe Dir doch einfach einen bei Schuricht, und dazu noch ein 2x20 Display + 5 Buttons bei Reichelt, und schon hast Du ein Control Surface (Step A) mit dem Du superbequem auf saemtliche Parameter zugreifen kannst - ohne Programmieraufwand! Gruss, Thorsten.
Hi Frank, this snippet works with some temporary registers which have been preinitialized before. So, it won't work in another context. However, toggling a LED is quite easy. Just get the DOUT pin status, invert it, and write it back whenever the button has been pressed. Example: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an button has been toggled ;; Input: ;; o Button number in WREG and MIOS_PARAMETER1 ;; o Button value MIOS_PARAMETER2: ;; - 1 if button has been released (=5V) ;; - 0 if button has been pressed (=0V) ;; -------------------------------------------------------------------------- USER_DIN_NotifyToggle ;; exit if button has been depressed IFSET MIOS_PARAMETER2, 0, return ;; store button number in TMP1 movff MIOS_PARAMETER1, TMP1 ;; toggle LED which corresponds to the button number movf TMP1, W ; button/LED number in TMP1 call MIOS_DOUT_PinGet ; get LED status xorlw 0xff ; invert status movwf MIOS_PARAMETER1 ; store new status in MIOS_PARAMETER1 movf TMP1, W ; button/LED number in TMP1 call MIOS_DOUT_PinSet ; set new LED value (expects value in MIOS_PARAMETER1) return Best Regards, Thorsten.
Hi Steve, it means both. EMC (electromagnetic compatibility) is the generic term for everything which can distrurb an electronical circuit Best Regards, Thorsten.
Hi, since you are asking this, I would say: yes, it will be difficult. However, once you've learned the most important assembly instructions and the programm execution flow of MIDIbox LC, you should be able to do this change. A good starting point is the PIC18F452 datasheet, which can be downloaded from the Microchip Homepage. http://www.piclist.com provides some tips for common programming problems, the MIOS examples are always a good starting point to learn more about the interactions with the OS, and finally you can try to modify the MIDIbox LC code (step by step...) Best Regards, Thorsten.
Hi Kriz, informations about the MBSID SysEx format can be found here: http://www.ucapps.de/midibox_sid/midibox_sid_sysex_implementation.txt The current patch can be accessed with command 05 and 06 Even more informations can be found in the JSynthLib package, see synthdrivers/MIDIboxSID/MIDIboxSIDSingleEditor.java and especially: synthdrivers/MIDIboxSID/MIDIboxSIDSingleDriver.java Best Regards, Thorsten.
Es gibt tatsaechlich noch eine logische Erklaerung fuer dieses mysterioese Verhalten: falls die RC (RCLK) Leitung nicht richtig verbunden ist, muesste der Interconnection Test trotzdem durchlaufen, in der MBSID Application wuerden alle Output Pins des 74HC595 auf '0' stehen. Deshalb das alte Spielchen - um evtl. Kurzschluesse auf der Platine auszuschliessen (um das herauszufinden, hilft Dir kein Durchgangspruefer!) Pin #23 (RC4) des PICs sowie Pin #12 der beiden 74HC595 zur Seite biegen und direkt miteinander verbinden. Falls das dann auch nicht der Grund war, liegt es entweder am Core, oder am SID Modul. ;-) Gruss, Thorsten.
Ok - das flag "SID_STAT_USE_BANKSTICK" ist gesetzt, somit ist der BankStick aktiv. Das war auch schon alles, was ich zu diesem Thema beitragen konnte. Vielleicht solltest Du nochmal den sidplayer ausprobieren, ansonsten kann ich Dir keinen weiteren Tip mehr geben. Die Sache wird mir einfach zu aufwaendig - aber vielleicht hilft Dir ja jemand anderes weiter. Gruss, Thorsten.
Bzw., ich sehe gerade, dass Du am Ende der MIOS_MIDI_TxBufferPut's ein return eingefuegt hast. Habe ich davon etwas erwaehnt? Denke nicht... Also so koennen wir noch wochenlang weitermachen.. ;-) Gruss, Thorsten.
Jo, die Firmware versucht alle SID Register neu zu laden, SID_SR_Handler wird jedoch nie aufgerufen. Kann es sein, dass Du in sid_tick.inc den urspruenglichen Code entfernt hast? Falls Du Dir nicht sicher bist, lade bitte die alpha3 Release erneut von der Webseite und spiele das Original .syx File auf Gruss, Thorsten.
...ohne ein LC Display nur wenn der SID richtig angeschlossen ist oder man den Source Code kennt ;-) Baue mal folgendes in sid_tick.inc ein: movlw 0xb0 call MIOS_MIDI_TxBufferPut movf SID_STAT, W andlw 0x0f call MIOS_MIDI_TxBufferPut swapf SID_STAT, W andlw 0x0f call MIOS_MIDI_TxBufferPut Dieses Prograemmchen sendet permanent den SID Status. Welche Daten zeigt Dir MIDI-Ox an (ich muss eigentlich nur den letzten Controller Event wissen) Gruss, Thorsten.
So hoert sich der SID an, wenn er im Reset ist - passt also (leider) Gruss, Thorsten.
Danke! :) Von der Software Seite her sehe ich keine Probleme. Beim Aufbau der Hardware solltest Du jedoch penibelst auf EMV achten. Die 128 LED Ringe werden mind. 1 Ampere benoetigen, vielleicht sogar mehr. Und da die einzelnen LEDs nicht permanent eingeschaltet bleiben, sondern von der Firmware im Zeitmultiplex-Verfahren sehr schnell ein- und ausgeschaltet werden, koennte dadurch die 5V Versorgungsspannung mit extremen, hochfrequenten Stoerungen ueberlagert werden. Und dies wuerde sich wiederum als Jitter bei den analogen Fadern bemerkbar machen. Deshalb mein Vorschlag: verwende am besten zwei getrennte Netzteile (gibt es bei Pollin sehr guenstig) fuer die MB64 und MB64E/MIDIO128, und verbinde den MB64 Master via Optokoppler mit den Slaves (also eine "normale" MIDI-Verbindung ueber MIDI In/Out). Die Slaves koennen untereinander ueber den MBLink Port - ohne Optokoppler - verbunden werden, solange die analogen Eingaenge ungenutzt bleiben. Ich bin mir nicht sicher, ob es etwas ausmacht, wenn die Massen der beiden "Voltage Domains" miteinander verbunden sind - das muesstest Du dann ausprobieren. Es macht sicherlich auch Sinn, an jedes DINX4 und DOUTX4 Modul Stuetzkondensatoren (jeweils 10uF und 100 nF parallel) zwischen Vss und Vdd anzuschliessen, um die Spannung zu stabilisieren und Stoerungen abzufangen. Auch Spulen und Drosseln sollen hier helfen, aber das ist absolut nicht mein Gebiet. ;-) Gruss, Thorsten. P.S.: diese Anmerkungen gelten hauptsaechlich fuer Mega-Konfigurationen mit mehreren Cores. Meine MIDIbox LC kommt bspw. ohne besondere EMV Massnahmen aus...
Dann hast Du Glueck gehabt ;-) Nun schliesse mal den BankStick an. Und zwar aus dem Grund: nach dem Formatieren (dauert > 1 Minute, wie bereits geschrieben), wird kurzer ein Ton gespielt. Und zwar direkt ohne dass der MIDI Kanal oder der Preset-Sound irgendeine Rolle spielt. Ist der BankStick erstmal formatiert, wird dieser Ton ca. 5 Sekunden nach jedem Einschalten gespielt. Ergebnis? Gruss, Thorsten.
Argl! Mach' die Bruecke weg, die erzeugt einen Kurzschluss und koennte den 74HC595 zerstoeren! :-/ Den Widerstand kannst Du weglassen, aber daran wird sich nicht viel aendern. Im Schematic steht ja "it isn't required anymore...." und "could be left out". Mit der Bruecke erzwingst Du nun, dass der SID keinen Reset mehr erhaelt, und das wird so ebenfalls nicht funktionieren. Was hat sich bei der direkten Verbindung der beiden Pins ergeben? Die Pins duerfen dabei keinen Kontakt zur Leiterplatte haben! /edit: es macht wirklich Sinn, das mal auf diese Weise zu testen, glaube mir einfach... ;-) Gruss, Thorsten.
Hallo, es ist normal, das manche SIDs (vor allem die ersten Revisionen) ziemlich heiss werden. Oder hast Du den Eindruck, dass der Chip wesentlich heisser als im C64 Gehaeuse wird? Nun, das wuerde alles erklaeren. Der Reset ist Low-Aktiv, das heisst: solange an diesem Pin keine 5V anliegen, befindet sich der SID im Reset und wird garantiert keinen Mucks von sich geben. Ich halte es fuer unwahrscheinlich, dass es am 10k Widerstand liegt (zumal es sich hier ja um einen Pull-Up handelt). Vielleicht liegt es an der Bruecke zwischen dem SID und dem 74HC595? Sie hat hoffentlich keinen Kontakt zum Oszillator-Gehaeuse? Ist es Dir gelungen, den Reset Pin mit dem SID Interconnection Test "wackeln" zu lassen? Du koenntest mal Pin #5 des SIDs und Pin #2 des 74HC595 zur Seite biegen und direkt miteinander verdrahten. Gruss, Thorsten.
A 2 HE solution would be really interesting! But an inportant tip: try to arrange the "real" components before ordering the panel! When you compare my first panel idea with the final one, you know why... ;-) It's always a good idea to prepare all boards before ordering a panel! To the button functions: EDIT: changes to the common edit view, steps are muted/unmuted with the 16 general purpose buttons. 1/2/3/4 to select the track, A/B/C to select the layer. MUTE: changes to the appr. menu page which is used to mute the tracks with the general purpose buttons. PATTERN: changes to the pattern menu. 1/2/3/4 to select the pattern, GP buttons to enter the pattern number SONG: changes to the song menu. 1/2/3/4 to select the pattern, GP buttons to enter the pattern number, A selects the song number, B: song position, C: End/Repeat/Loop points (in fact the cursor within the menu page is controlled by 1/2/3/4/A/B/C) SOLO: only the currently selected "edit" tracks will be played. With the 1/2/3/4 button you are able to select multiple tracks at once (like known from the MIDIbox SID) ALL: allows you to set a value for all selected tracks, steps and layers at the same time with a single encoder FAST: faster encoder movements - works for all encoders at the same time. If you are using encoders with inbuilt push-button, you can activate the function also from there Best Regards, Thorsten.
