TK.
Administrators
    15,248
  1. TK.
    my project
    You are really fast! :) Best Regards, Thorsten (loves acronyms, too ;-))
  2. I've prepared MIOS for the final open source release which will be published under https://sourceforge.net/projects/mios Some parts of the code have been improved for better readability, the internal registers have been sorted and relocated, and the sample period of the AIN handler has been reduced from 300 uS to 200 uS per input (after I noticed that this higher sampling period is possible w/o provoking jittering pot values). Due to these drastical changes I'm searching for people who would like to test the new firmware on their MIDIbox before the official release. I'm especially unsure about the higher sample rate - so the guys who built a MIOS based MB64, MBMF or MIDIbox LC: please step forward! :) -> Mail to tk@midibox.org Best Regards, Thorsten.
  3. Here some input if you are searching for a good PSU for your MIDIbox NG(s): since one month I'm using a cheap switching power supply from Pollin (price: 4.95 EUR) on my MIDIbox LC and it works without problems. More infos can be found here: http://www.ucapps.de/midibox_lc/midibox_ng_switching_psu.pdf I guess that up to 3-4 MIDIboxes with Motorfaders can be powered from this PSU. Best Regards, Thorsten.
  4. Insider ;-)
  5. Alright, now the fun begins ;-) Did you take a look into mb64_meta.inc? Then you could change the SysEx example for AN1x for your M3r and try it out. Best Regards, Thorsten.
  6. Erik: concerning the article: you will see the problem once a lot of people answering to different questions... you will lost the oversight. Most of your questions will never be answered Pilo: I see no reason why to use a 7806+4V Zener before the LM317 - the LM317 is nothing else than a LM78xx with adjustable output voltage. In general the LM317 should be the most prefered voltage regulator for the MF module, due to the adjustability. I cannot recomment any other solution, since some motorfaders require a different driving voltage for best performance (from 7.1, 7.2, 7.3 ... 9.0V) - you have to try this out! Erik: if you are not able to get the LM317 working, download the datasheet and try to build a minimal circuit, just to ensure that the chip is still ok. It doesn't really make sense to try out different regulators (see above) Broken Link: could you please specifiy exactly where it is? I just tried it again (I clicked on the link at the top of the MBHP_JDM page) - it works and it points to exactly the same page like 3 years before There is no conversion method, the original JDM programmer was designed for PIC16F84, just compare the original schematic with the MBHP_JDM schematic and you should notice the "conversion method" (just only the pinning is different, and nothing else) Best Regards, Thorsten.
  7. TK.
    ADA MIDI Delay
    Ich kann Deinen Argumenten nur teilweise zustimmen. Deine Schaltung ist voll Digital aufgebaut, mit einem Rechner laesst sie sich also 1:1 nachbilden. Der SID enthaelt analoge Komponenten, somit laesst er sich nur teilweise emulieren - Reaktor hilft da nicht weiter (hier ist man auf vorgefertigte Modelle angewiesen), und selbst eine voll ausprogrammierte SID Emulation kommt nicht an das Original heran (siehe SIDPLAY2 oder QuadraSID) - schonmal den SID Filter uebersteuert? Was das Handling angeht: nunja, das haengt halt vom persoenlichen Workflow ab. Ich wollte ja auch nur nochmal andeuten, dass ich mich fuer dieses Thema nicht interessiere und deshalb von meiner Seite aus auch leider keine Unterstuetzung zu erwarten ist (der Vorschlag fuer ein Delay kam ja schon mehrmals auf). Gruss, Thorsten.
  8. Cool! Ist mir noch nie aufgefallen :) Best Regards, Thorsten.
  9. Very good, I would also realize it that way. But I wouldn't push the MIDI events into the Tx Buffer from an ISR. Although this works for debugging purposes, there are some cases which "hurt": a) the integrated MIDI merger could fail, b) the MIOS SysEx parser could fail, c) a deadlock scenario if the Tx Buffer is full and the Tx sender (which is also an ISR) cannot be executed since your own ISR blocks the execution (nested interrupts are not possible) So, it's better to notify changes to a second routine which is called from USER_Tick - thats the common programming style which saves you from a lot of trouble. Example can be found in j5_din_v1_3.zip Best Regards, Thorsten.
  10. So much absolutely different questions in one posting? So, am I allowed to pick out the one I like? ;-) (such cross-postings are making the search function of the forum inefficient) LM317: no idea 78L08 and 78L09: absolutely not recommented, especially the L type will blow away immediately, remember that the current drain can be 1A and higher PIC16F84A: read the original JDM page - the JDM was originally designed for the PIC16x84x - the link can be found at the MBHP_JDM page PIC16F877A: new flash technology, it requires different programming settings in IC-Prog. The rest is compatible to the PIC16F877 (if users would sort their postings better, you propably would find this answer with the search function... ;-)) Best Regards, Thorsten.
  11. Well, you haven't told us where you've found the error exactly, who should know if there are more similar errors? I guess: yes ;-) The ready message will only be displayed after the upload of MIOS, and it will be overwritten once you upload an application Best Regards, Thorsten.
  12. not multiclient capable (the MIDI port...)
  13. Hi Geoff, the timer function has a resolution of 100 nS (nanoseconds!) ;-) 1 ms capturing cycle is used by the SRIO handler for the DIN and DOUT module, if a higher rate is required, then just program a USER_Timer routine and call it every 100 uS (microseconds) or so... In this case it's easier to connect the sensor signals directly to the PIC pins for best performance. J5, J6, J7, the SO and RC pin of J10 and J14 (requires MIOS V1.5) can be used for this. If these 15 IO pins are not enough, then you could control some serial shift registers from your routine. Best Regards, Thorsten.
  14. TK.
    ADA MIDI Delay
    Hallo Benni, ich halte mich aus diesem Thema mal raus, alldieweil ich mit Reaktor eigentlich eine wesentlich flexiblere Loesung habe - zum Synchronisieren auf die MIDI Clock habe ich mittlerweile ein eigenes Macro :) Siehe auch: http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=songs;action=display;num=1050884202 Gruss, Thorsten.
  15. Hallo Peter, wahrscheinlich arbeitest Du noch mit einer aelteren Version von MPLAB, in der Version 6.4 wurde dieser Bug endlich gefixed. In dieser Version ist auch die "use one-to-one project-workspace model" Option standardmaessig eingeschaltet, mit der auf die Files nicht mehr ueber einen absoluten Pfad zugegriffen wird. Du findest diese Option unter Configure->Settings->Projects Gruss, Thorsten.
  16. Hallo Holger, die bekommt man leider nur direkt bei Waldorf. Vor einem Jahr hat mal jemand die Leute solange belabert, bis sie ein paar Knoepfe aus dem Ersatzteilsortiment herausgerueckt haben. Aber ich bezweifle, dass sich diese Aktion wiederholen laesst (zumal es der Firma angeblich nicht mehr so gut geht... :-/) Gruss, Thorsten.
  17. soundcard
  18. Hi Jost, ...but this must be a short anywhere between pin RD1, RD2 and RD3 of the PIC and your DIN module Best Regards, Thorsten.
  19. Hi Geoff, are we speaking about delays of some microseconds or miliseconds? Best Regards, Thorsten.
  20. Hi Meeshka, the circuit for the ICP port is part of the mbhp_core.pdf schematic - see MBHP->Core Module Best Regards, Thorsten.
  21. Hi Wilba, it still sounds strange. The latch input is driven by a strong driver pin, the signal shouldn't be influenced by ambient noise that much. Could you lift the RC.4 pin of the PIC from the socket and make a direct connection to the SID module with a short cable? If this works, the root cause must be a bad track or junction. Best Regards, Thorsten.
  22. Hi Thomas, my suggestion: just send me your core module, it will save your time and give me the possibility to explore the most mysterious upload problem of the last year ;-) Best Regards, Thorsten.
  23. gr@s! :-) Best Regards, Thorsten.
  24. Hi Jost, thanks for the input! Other interfaces are not working with a buffer size < 2048, so it's difficult to specify values which fits with all requirements. :-/ Maybe with the upcoming Java environment this will work better without modifying any value. Best Regards, Thorsten.
  25. The protocol is identical to HD44780. All what you need to do is to adapt the "Y Offset" values. A table for different display types can mostly be found in the applications which get use of the 2 additional lines (example: see the main.asm header of MIDImon or MB64) Best Regards, Thorsten.
