TK.
Administrators
    15,248
  1. Wow! It comes with a big spare area for a big LCD and a lot of rotary encoders :) Best Regards, Thorsten.
  2. What is the maximum resistance value of the pot? Hopefully 10k - or higher? Best Regards, Thorsten.
  3. What is the maximum resistance value of the pot? Hopefully 10k - or higher? Best Regards, Thorsten.
  4. By using an external MIDI translator it's possibly easy to turn this device into a full LC, and the translator could also handle with the additional buttons and the jog wheel. But the costs... hm.... Best Regards, Thorsten.
  5. Remind that the development and documentation of another hardware platform possibly requires more effort than you really want. During the last years I've read from a lot of people who planned something similar, but finally gave up due to unexpected problems. Don't think that bigger microcontrollers can do the IO handling much faster than a PIC18F, and keep in mind that once you are using external memories, good system knowledge and soldering skills are required. The setup of a new platform and operating system requires good debugging tools, mostly they are not free available (maybe ARM7 would be a good solution, but a useful IDE costs at least 2000 EUR!) So, from my experience I can give you following advice: if you plan to implement a much more powerfull, reproducible, standalone DIY sequencer with fast success and open possibilities, than use a cheap embedded PC board, use Embedded Linux as operating system, and use an external PIC18F452 (running under MIOS) to handle with the control elements (buttons, encoders, LCDs, LEDs, etc.) - connected via RS232 to the PC. The advantage of this approach would be, that everybody who owns a PC (from 386 upwards) can try your software, so there is no need for bying expensive hardware for the first tests. Best Regards, Thorsten.
  6. The -force option doesn't help here, it forces the script to generate a .syx file without the MIOS address range, regardless if it's embedded in the .hex file or not. You have to use the "-os_upload" option instead. This is described in the README.txt of the binary release, but not in the source release - I will fix this. As Duggle already mentioned, the MIOS upload works only with the primary loader. The reason why I removed the hint of using "-os_upload" from the script is, that a common user may overwrite MIOS in this way - see also this posting http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1067609574;start=4#4 Best Regards, Thorsten.
  7. The -force option doesn't help here, it forces the script to generate a .syx file without the MIOS address range, regardless if it's embedded in the .hex file or not. You have to use the "-os_upload" option instead. This is described in the README.txt of the binary release, but not in the source release - I will fix this. As Duggle already mentioned, the MIOS upload works only with the primary loader. The reason why I removed the hint of using "-os_upload" from the script is, that a common user may overwrite MIOS in this way - see also this posting http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1067609574;start=4#4 Best Regards, Thorsten.
  8. Der Stromverbrauch von Deinem Display ist ziemlich hoch, nunja... musst Du mal ein wenig herumfrickeln. Vektoren: ersetze "EQU <MIOS-addresse>" einfach durch ein "EQU <USER_LCD-adresse>". Du musst die Adresse nicht als Zahl angeben, hier reicht auch das Label Hast Du das ", 1" hinter den call und return Befehlen mittlerweile entfernt? Mir ist eingefallen, warum ich diese Option aus meinem Hirn geloescht habe - weil man sie innerhalb einer MIOS Applikation niemals anwenden sollte ;-) MIOS verwendet bereits die Shadow-Register fuer den schnellen Kontextswitch bei Interrupts. Wenn Deine LCD Routine nun die Shadow-Register ueberschreibt, kracht es, sobald ein Interrupt die Displayroutine unterbricht. Weil ich Deinen Code nicht kenne, kann ich ansonsten nur noch raten - vielleicht verwendest Du TMP1? Sollte innerhalb eines Treibers aber niemals eingesetzt werden - nur die die im Header angegebenen Register sind erlaubt, es gibt spezielle temporaere Register fuer den Display Driver (MIOS_GLCD_TMPx) Gruss, Thorsten.
  9. No, the data transfer rate would be much slower than reading from an IIC EEPROM. So long most pins are free, you could hook a 128k SRAM (like the 628128 ) to the core directly - here an example: data lines could be connected in parallel to the LCD port, 8 address lines could be multiplexed with the data lines like known from 8051 designs (by using a 74HC573 latch) 8 additional address lines could be connected to J5 the remaining address line to J7:RC the chip select to J7:SO the latch enable to J15:RS the R/W to J15:RW You need to implement a (simple) read and write routine for RAM accesses (RAM_Write, RAM_Read) and put it into your application. The resulting access time should be about 2 microseconds (ca. 20 instructions) - fast enough for large data structures. SRAMs can be buffered with a small 3V battery Best Regards, Thorsten.
  10. Again a great work by PayC:
  11. Again a great work by PayC:
  12. Hallo Ferdi, lies Dir am besten mal die Informationen auf der MIDIbox SEQ Seite durch. In den News findet man nun zusaetzlich eine Menge Infos zu der neuen (auf MIOS basierenden) Implementierung. Diese laeuft selbstverstaendlich auch auf einer MB64 (Stichwort: "Vintage Design"), mit der neuen Hardware laesst sich jedoch wesentlich ergonomischer arbeiten. Gruss, Thorsten.
  13. Hallo Ferdi, lies Dir am besten mal die Informationen auf der MIDIbox SEQ Seite durch. In den News findet man nun zusaetzlich eine Menge Infos zu der neuen (auf MIOS basierenden) Implementierung. Diese laeuft selbstverstaendlich auch auf einer MB64 (Stichwort: "Vintage Design"), mit der neuen Hardware laesst sich jedoch wesentlich ergonomischer arbeiten. Gruss, Thorsten.
  14. Also irgendwie sieht das ganz seltsam aus, weder call noch return erlauben ein zweites Argument. Der Assembler scheint an dieser Stelle wohl etwas zu tolerant zu sein. Ich nehme an, dass diese Funktion alle Zeichen ab 0x40 nach 0x28 mappen soll. Das koennte man auch so schreiben: USER_LCD_CursorSet movlw 0x10 rcall USER_LCD_Cmd SET_BSR MIOS_LCD_CURSOR_POS movf MIOS_LCD_CURSOR_POS, W, BANKED BIFSET MIOS_LCD_CURSOR_POS, 6, BANKED, addlw -(0x40-0x28) rgoto USER_LCD_Data Der Trick: in der zweiten Zeile ist Bit 6 gesetzt - das BIFSET macro (dahinter steckt die btfsc Instruction) tested dieses Bit und zieht 0x18 (0x40-0x28 ) davon ab - so wird aus 0x40 eine 0x28 Sonderzeichen: Du koenntest in mios_vectors.inc "MIOS_CLCD_SpecialCharInit" und "MIOS_CLCD_SpecialCharsInit" auf Deine eigenen Funktionen umlenken Vermeiden der Stoerungen waehrend des Einschaltens: dazu kann ich nicht viel sagen, ich habe noch nie mit einem VFD gearbeitet, weiss nicht, wie das mit der Stromaufnahme ausschaut. Vielleicht ist auch einfach nur Dein Netzteil zu schwach, so dass es waehrend des Einschaltens zu einem kurzen Spannungseinbruch kommt. Gruss, Thorsten.
  15. Welcome back, Ian :) Best Regards, Thorsten.
  16. TK.
    SIDplayer
    The SIDplayer reads and plays the .sid file, MBSID only interprets the incoming SysEx events and forwards the values to the SID. > I have couple of spare PIC16Fs. Are they still suitable for SIDPlayer? always the same: the software has been programmed for the PIC18F and for MIOS, it requires too much effort to port this to a PIC16F. But if somebody wants to spent some hours to write the same especially for the PIC16F, step forward... Best Regards, Thorsten.
  17. Here a snapshot of the current hardware: Due to the physical dimensions of the displays, I've to change the panel layout. It doesn't fit on a 19" panel anymore, so I will possibly take a small children's keyboard for the case ;-) If somebody has alternative ideas for the panel layout, don't hesitate to publish your layout here I've also replaced the two MIDI In/Out LEDs by two additional buttons (can't get enough). The 2*40 LCDs are not the final ones (I've to wait until Reichelt sends me the second backlit LCD), these are just two cheap displays w/o backlight from EBay for 5 EUR Best Regards, Thorsten.
  18. Hi Marcel, welcome to the forum! :) Well, the MIDIbox SEQ concept is very different. It's a step and pattern oriented sequencer and arpeggiator (push the button to get some jarry arp sequences) - Zyklus looks like a MIDI stream oriented sequencer, where sequences are stored like in a MIDI file: each track can play multiple MIDI events at once, and the rhythm is defined as "delay between events". If a second team designs a 16 track sequencer which plays the events directly from EEPROM, this method could be taken into account. The difficult task is to implement the editing facilities. Here the Zyklus manual could give useful informations. Best Regards, Thorsten. P.S.: I'm a big fan of your Sidologie album, especially of Knucklebusters - it's my personal Remix of the Year :-)
  19. Du findest den CLCD Treiber nun auch als "Custom Driver" in der MIOS Download Section. Was muss geaendert werden - an der Hardware: TEST# auf +5V klemmen SEL# mit der Enable Leitung verbinden WR# mit R/W Busy mit R/S -- vorsicht: hier einen 100 Ohm Widerstand in Serie schalten, damit es waehrend des Bootens keinen Kurzschluss gibt (Busy ist ein Ausgang). Ausserdem wuerde ich noch einen 10k Pull-Down vorsehen, damit der Core weiterlaeuft, falls das Display mal nicht angeschlossen ist Software: In der Initialisierungsroutine den R/S Pin auf TriState (Input) setzen: bsf TRISD, USER_LCD_PIN_RS Der restliche Initialisierungscode fliegt raus, weil sich das Display selbst initialisiert USER_LCD_Data: "Select Data Register" fliegt raus. Da es nur einen Datentransfermodus gibt, und die Zeichen < 32 Steuerzeichen sind, wuerde ich die Routine so umschreiben, dass nur Zeichen >= 32 uebertragen werden. Ansonsten gibt das Display wohl hin und wieder wirre Zeichen aus, oder macht gar nichts mehr USER_LCD_Cmd: hat bei Deinem Display eine voellig andere Bedeutung. Ich wuerde die Routine so umschreiben, dass sie lediglich Zeichen < 32 uebertraegt USER_LCD_WaitUnbusy: dieser Code wird schlicht und einfach durch folgenden Ersetzt: USER_LCD_WaitUnbusy IFSET PORTD, USER_LCD_PIN_RS, rgoto USER_LCD_WaitUnbusy return USER_LCD_Strobe_Set und USER_LCD_Strobe_Clr: hier muss die Polaritaet geaendert werden, da SEL# ein Low-Aktives Signal ist. Aus "bcf" wird "bsf", aus "bsf" wird "bcf" USER_LCD_Clear: hier muss das entsprechende Steuerkommando an das LCD gesendet werden USER_LCD_CursorSet: dito Gruss, Thorsten.
  20. a SIDstation patch viewer would be a really helpful tool with a high fun factor for people who like to tweak sounds (like me) - I don't need a 1:1 patch converter, but some inspirations from premade patches are always welcome :) Best Regards, Thorsten.
  21. Thanks a lot - it looks simple! :) Update: I got my Reichelt order today, but unfortunately they sent me only one 2x40 LCD, although I ordered and payed for 2 LCDs --- have to give them a call, from my experience with Reichelt it will take 1-2 weeks until they will manage to send me the missing part :-( Best Regards, Thorsten.
  22. This is finally the first open source release of MIOS. The source files are especially interesting for developers who want to get an insight about the tasks which are running in background (hidden for the application), and maybe (or hopefully?) for people who want to optimize or enhance existing functions. The most recent files of the project are hosted at https://sourceforge.net/projects/mios and available via CVS - the repository will contain bugfixes and improvements before a release has been done ChangeLog for MIOS V1.5: if MIOS_SRIO_TS_SensitivitySet is called with WREG == 0x00, the touch sensor Pin RD.4 (J14 of the core module) won't be driven by MIOS anymore and therefore is free for other purposes the AIN handler has been optimized to a two-step state machine with a sample frequency of 200 uS USER_MPROC_NotifyTimeout hang-up has been fixed the internal registers have been rearranged for a better overview. Applications shouldn't be affected from these changes Note: the custom LCD drivers under http://www.ucapps.de/mios_download.html have been updated, since there are some additional public variables available. Thanks to all beta testers! Have fun! Best Regards, Thorsten.
  23. This is finally the first open source release of MIOS. The source files are especially interesting for developers who want to get an insight about the tasks which are running in background (hidden for the application), and maybe (or hopefully?) for people who want to optimize or enhance existing functions. The most recent files of the project are hosted at https://sourceforge.net/projects/mios and available via CVS - the repository will contain bugfixes and improvements before a release has been done ChangeLog for MIOS V1.5: if MIOS_SRIO_TS_SensitivitySet is called with WREG == 0x00, the touch sensor Pin RD.4 (J14 of the core module) won't be driven by MIOS anymore and therefore is free for other purposes the AIN handler has been optimized to a two-step state machine with a sample frequency of 200 uS USER_MPROC_NotifyTimeout hang-up has been fixed the internal registers have been rearranged for a better overview. Applications shouldn't be affected from these changes Note: the custom LCD drivers under http://www.ucapps.de/mios_download.html have been updated, since there are some additional public variables available. Thanks to all beta testers! Have fun! Best Regards, Thorsten.
  24. Wahrscheinlich ist der parallele Treiber am einfachsten zu programmieren. Morgen veroeffentliche ich den Source Code zu MIOS, darin findest Du den CLCD Treiber, den Du als Vorlage hernehmen kannst. Viel muss nicht geaendert werden, lediglich das Polling --> vereinfacht! <-- sich! :) Sonderzeichen werden von diesem Display wohl nicht unterstuetzt, deshalb koennen die huebschen Bargraphs nicht angezeigt werden. Gruss, Thorsten.
  25. Ok, gut versteckt steht es quasi zwischen den Zeilen: source file path exceeds 62 characters Die maximale Pfadlaenge, mit der MPLAB umgehen kann, betraegt 62 Zeichen. Einfach das Verzeichnis nach \mios oder so verschieben, und dann sollte es klappen Gruss, Thorsten.
