TK.
Administrators
    15,248
  1. The J1/J2 sockets are not "polarized" (no notch) - probably you decided this due to the missing space. But I would prefer this against J2 - so, just remove J2 again to make place for a polarized J1 connector. If somebody would like to chain multiple modules, he has to build an external adapter and solder it directly on the required pins. to which ground are they connected? I would use the digital GND for both planes. Best Regards, Thorsten.
  2. Unfortunately this isn't possible - the PWM is already generated as fast as possible (assembler optimized) Best Regards, Thorsten.
  3. Good progress! :) This shouldn't happen if you remove "Bank=2" from the EVENT_ENC statements which should be controlled from the .NGR script. Because with "Bank=2" the encoders will be part of the bank, and therefore automatically activated on each bank switching. Best Regards, Thorsten.
  4. Argl! Who should ever document and understand all those options! ;-) The problem at my side: I can't test this, since my matrices are connected correctly. Therefore the implementation of a proper solution can take a lot of time (low prio for me) Best Regards, Thorsten.
  5. TK.
    MIDIbox KB
    Unfortunately this isn't possible with the LPC1769 due to a hardware bug in the chip. As you can read at the MBHP_CORE_LPC17 page: -> http://www.ucapps.de/mbhp_core_lpc17.html output pins can't be used in open drain mode if a peripheral function like SPI or UART is assigned to it. This seems to be a design bug, because it isn't mentioned in the user manual (in distance: the description of the IO configuration implies that it should work, but it doesn't) - NXP support contacted, no reply yet! The consequence is, that the MIDI OUT pin can only switch between 0V and 3.3V, because works in push-pull mode. A workaround would be to level-shift the output to 5V, e.g. with a 74HCT541. This chip is already used for level-shifting, see also http://www.ucapps.de/mbhp/mbhp_core_lpc17.pdf You would need another one for the MIDI OUT port. Best Regards, Thorsten.
  6. Looks like a bug in the RAM based Wavetable option - I will check this soon! (I wasn't able to try SysEx access with this option due to the MacOS Java issues... :-/) As a temporary workaround, you could disable this option in your setup_*.asm file: #define WAVETABLES_IN_RAM 0 Best Regards, Thorsten.
  7. MBCV2 got a hardware configuration file which allows to specify the DIN/DOUT pin assignments, and the AOUT interface. -> http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fprocessing%2Fmidibox_cv_v2%2Fhwcfg%2Fstandard%2FMBCV_HW.CV2 IMPORTANT: upload the MBCV_HW.CV2 file to the root directory of your SD Card, and especially check the AOUT_IF setting, because this is the only way to select the right AOUT interface meanwhile. (the AOUT selection in DEFAULT.CV2 is obsolete!) I also increased the number of banks to 8. With the default LRE encoder assignments, it "feels" like each CV channel has it's own bank which allows to change values like Octave/Semitone transpose, Finetune, Portamento, LFO1/2 Depth and Rate, ENV1 Depth and Decay, ENV2 Depth and Rate and MOD1..4 Depth. It's possible to customize the assignments by pressing SCS SHIFT+"Enc Cfg". E.g. you are able to change the assignments, so that parameters of different channels can be controlled from a single encoder bank! :) Best Regards, Thorsten.
  8. Fine! :) Best Regards, Thorsten.
  9. Yes, I would prefer this. We never know how long these OLEDs are available - and how long they are working! E.g. let's say the end-of-life is in 5 years and you need a replacement for whatever reason. Then it's a big advantage if the case has a larger window so that other displays fit as well. Meanwhile in the MIDIbox lab: I mounted the modules at the top of a wooden case so that they have stable interconnections and are transportable. For a user this might look ugly, but for me as developer it's the ideal way of mounting, since I've access to all signals, connectors, jumpers without opening a case! :smile: I also replaced the cheap LCD by a Newhaven 2x20 OLED. This display is not so high like the previous CLCD, but this has to be changed by using standoffs. Otherwise the height isn't aligned with the graphical OLEDs and the encoder knobs. Best Regards, Thorsten.
  10. MIOS32 successfully connected to the SD Card, but didn't find a FAT16 or FAT32 filesystem. You can format the SD Card with your computer, or (maybe better) with the "sdcard_format" command in the MIOS Terminal. Best Regards, Thorsten.
  11. You could add a ULN2803 after the DOUT shift registers and power the COM pin at +12V (voltage taken from the AOUT module). Since this is an open collector driver, you've to add 1k resistors between 12V and each output. In addition, you've to invert the gates in the MBCV2 configuration. Btw.: current state - I added many performance improvements in the last days - support for LRE8x2 (encoders and LED rings). Up to two LRE8x2 modules can be connected, makes 32 encoders and 32 LED rings. - each LRE8x2 has 8 banks with soft-assignable parameters - assignments stored on SD Card - parameter names and values are print on LCD whenever an encoder is moved - bidirectional updates. E.g. if a parameter which is assigned to an encoder is changed in Lemur or in the SCS, the LED ring will reflect the new value. And vice versa: Lemur will be informed whenever a parameter is changed with an encoder - fixed bidirectional OSC based communication. Here the setup instructions: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fprocessing%2Fmidibox_cv_v2%2Flemur%2FREADME.txt Best Regards, Thorsten.
  12. The deselected DHCP is unusual (but of course allowed - seems to be the parameter which causes the problem). Could you please check if the crash can still be reproduced with DHCP enabled? Then I would know where to start searching. Best Regards, Thorsten.
  13. Hi Bela, it's very similar to the faders that I'm using, they are just smaller. So: yes, they should work :) Best Regards, Thorsten.
  14. Welcome on board! :) If pots and faders are still desired, it's probably better to work on a different control surface which uses dedicated control elements (pots/faders/buttons/LEDs) for each parameter. Today such a controller would be created with MIDIbox NG: http://www.ucapps.de/midibox_ng.html The MIOS32 platform isn't much more expensive than the old PIC based platform, but easier to use and especially more flexible. How would your ideal control surface look like? We could help you to create the appr. .NGC setup Best Regards, Thorsten.
  15. Cool! :) Best Regards, Thorsten.
  16. Could you please give me your complete network configuration? (enter "network" in MIOS Terminal, and copy&paste the output into this thread) It doesn't matter if an ethernet cable is connected or not, I mainly need to know how which OSC protocol is selected for the different ports. Maybe this helps me to reproduce the issue with some stress tests Best Regards, Thorsten.
  17. TK.
    MBFM 5V option?
    The only OPA that we know (proposed by Nils) is SMD based, and not pin-compatible to TL074; therefore it won't be so easy to modify the OPL3 module accordingly. :-/ Best Regards, Thorsten.
  18. No, you don't need it. I don't know why you assigned a CC to this event... if not necessary, why not triggering RunSection:2 with this button? Best Regards, Thorsten.
  19. TK.
    Display options
    I would connect the first 8 displays to buffered outputs as well. Change the schematic the following way: connect the J15 based SCLK output to A0, A2, A4, A6 of the 74HC541 connect the J15 based SDA output to A1, A3, A5, A7 of the 74HC541 connect D0/D1 of the first 8 displays to Y0/Y1 of the 74HC541 connect D0/D1 of the next 8 displays to Y2/Y3 of the 74HC541 Best Regards, Thorsten.
  20. Well, in your .ngc setup the section is only executed with button id=70 You could execute it with id=1371 as well (just configure it as a meta event); the CC event could be sent with the "send <midi-event>" command from the .ngr script. Best Regards, Thorsten.
  21. TK.
    Display options
    Finally!!! :turned: Here the appr. MIDIbox NG release with the modified driver: http://www.ucapps.de/mios32/midibox_ng_v1_029_pre2.zip I will prefer the duplicated SCLK output at J15B.E2 If somebody really plans to add more than 16 OLEDs, I will recommend to buffer SCLK and SDA with a 74HC541 Best Regards, Thorsten.
  22. Seems that the USB cable is problematic quite often! Great that it's working now! :) Best Regards, Thorsten.
  23. The button can't be found because it has an invalid fwd_id argument, and therefore was rejected: [79761.466] [MBNG_FILE_C:651] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.469] [MBNG_FILE_C:653] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.469] [MBNG_FILE_C:655] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.472] [MBNG_FILE_C:657] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.473] [MBNG_FILE_C:659] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.477] [MBNG_FILE_C:661] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.477] [MBNG_FILE_C:663] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.480] [MBNG_FILE_C:665] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.480] [MBNG_FILE_C:669] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.484] [MBNG_FILE_C:671] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.484] [MBNG_FILE_C:673] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.487] [MBNG_FILE_C:675] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.487] [MBNG_FILE_C:677] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.491] [MBNG_FILE_C:679] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.491] [MBNG_FILE_C:681] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.554] [MBNG_FILE_C:683] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.554] [MBNG_FILE_C:813] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.557] [MBNG_FILE_C:815] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.557] [MBNG_FILE_C:817] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.561] [MBNG_FILE_C:819] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.561] [MBNG_FILE_C:821] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.564] [MBNG_FILE_C:823] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.564] [MBNG_FILE_C:825] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.568] [MBNG_FILE_C:827] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.568] [MBNG_FILE_C:831] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.571] [MBNG_FILE_C:833] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.571] [MBNG_FILE_C:835] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.575] [MBNG_FILE_C:837] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.575] [MBNG_FILE_C:839] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.578] [MBNG_FILE_C:841] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.578] [MBNG_FILE_C:843] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED [79761.846] [MBNG_FILE_C:845] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED It seems that the displayed line numbers are not correct (I've to fix this) But if you search for "fwd_id=<", you will find the wrong definitions. After correcting the syntax, "run 2" is executed without error Best Regards, Thorsten.
  24. Yes, this can only be done with snapshots. Best Regards, Thorsten.
  25. TK.
    MIDIbox KB
    Thanks for the input! I added a note to the schematic, that the pinning is not 1:1 compatible. MIDI OUTs: very strange! Following configuration allows you to doublecheck, if the MIDI OUT port is working regardless of the keyboard configuration: just enter following command into the MIOS terminal: set router 1 USB1 all OUT1 all thereafter play some notes on the virtual keyboard of MIOS Studio. They should be forwarded to the OUT1 port. If not, you know that the problem is related to the hardware. Check the MIDI circuitry on the MBHP_CORE_LPC17 module, and also check your MIDI cable (maybe it's defective?) Best Regards, Thorsten.
