Dimitris_FX_freak
66 -
Everything posted by Dimitris_FX_freak
Ã�åñé áÃôáëëáêôéêþà (Ã�èÞÃá)
Dimitris_FX_freak replied to Dimitris_FX_freak's topic in Greek
Ãåéá óïõ uclaros ÅåðéäÞ äåà áÃáöÃñåéò áà åßóáé ÃèÞÃá Þ êáðïõ áëëïõ ïé ðëçñïöïñßåò ðïõ èá óïõ äþóù äåà îåñù áà èá óïõ åßÃáé ÷ñÞóçìåò. Ëïéðüà óôçà êáÃÃéããïò (ïäüò) ëßãï ðïéï ìÃóá áðü ôï ÅÌà õðÜñ÷åé ÃÃá ìéêñü ìáãáæáêé ìå çëåêôñïÃéêÜ ï áÃèñùðïò ðïõ ôï Ã÷åé ìðïñåß Ãá óïõ öÃñåé ôá ðÜÃôá (áëëá ëßãï áêñéâüò) áëëßùò Ñáäéï ÊÃÔÃÕÌÃÓ óôï óõÃôáãìá Ôï ìåãáëýôåñï ðñüâëçìá åßÃáé ïé PIC ïé ïðïéïé óôá 40 ÌÇÆ äåà ðáéæïõà óôçà Åëëáäá. Èá óïõ ðñüôåéÃá ùóôüóï Ãá êáôáóêåâÜóåéò êáôé ìå ôï ÃÃï ÌÉÃS ìéáò êáé ïé äõÃáôüôçôåò ôïõ åßÃáé ðáñá ðïëëåò Ôé ÷ñçóçìïðïéåßò Cubase h Logic? ÕÓ. Ãà äåà âñåéò PIC å÷ù ÃÃá 16F877 ðïõ äåà ôï ÷ñçóçìïðïéþ -
Amazing news Thorsten :) I will be testing MIOS on my upcoming LC the only think is there are going to be a lot of questions. ;) But for the time I have to deside the layout of the box >:( And of course I need those 18F from Microchip (for free ;D) (stryd_one <-you are very lucky in the timming, I have to work on that) Take care man Dimitris
Hello T I found a very nice display on the net and I will like to find out if it is compatible with the current driver in MIOS. The link is: http://www.hantronix.com/down/64gs242p.pdf or http://www.hantronix.com/2_1.html and look for the HDM64GS24-2 It just looks nice on blue color Regards
Hi T As I see you want to use it for the icons on the LCD of the MIOS so I only suggesting using an icon editor http://www.iconcool.com/ Otherwise (if i got it wrong ) the photosop or the photopaint or the paint shop pro will be the best Regards
This is the text Αυτό είναι το κείμενο
I guess thats how everybody see Greek language ;D ;D ;D -
Σε αυτό το Forum μπορείς να βρείς πληροφορίες για το πως θα κατασκευάσεις Midi Controller για εφαρμογές DAW επαγγελματικές και μή. Σε περίπτωση που τα αγγλικά σου ή οι γνώσεις σου σε ηλεκτρονικές κατασκευές σε περιορίζουν μπορείς να επικοινωνήσεις μαζί μου το Ηλ. ταχυδρομείο μου είναι κάτο από το εικονίδιο μου. Αν είσαι εντός Αθηνών θα μπορέσω να προγραμματίσω το PIC και να αποφύγεις κάποια έξοδα. Δημήτρης
Here is a tip for all the ppl using Logic in Windows XP: Create a text file Copy paste the following using notepad or any editor: [tt]<?xml version="1.0" encoding="UTF-8" standalone="yes"?><assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0"><assemblyIdentity version="1.0.0.0" processorArchitecture="X86" name="CompanyName.ProductName.YourApp" type="win32"/><description>Your application description here.</description><dependency> <dependentAssembly> <assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls" version="6.0.0.0" processorArchitecture="X86" publicKeyToken="6595b64144ccf1df" language="*" /> </dependentAssembly></dependency></assembly>[/tt] Save the file. Copy the file to Logic directory Rename as the filename suggests eg for logic 5.5 Logic Platinum 5.5.0.exe.manifest Run logic and observe the differencies on the dialog more XP styled. This tip is useles with the steinberg products cubase, wavelab ( I thing they using Borland libraries and not the standard MS API). Happy sequencing ;D ;D ;D PS. Thorsten bring the MIOS even undocumented (at least to me as I am alpha and beta tester) :) :) :)
Hi Thorsten Regarding the implementation of normal 10k linear faders instead of motorfaders not mainly for cost reasons but i havent yet found a source to get them in greece (and i already had a bad experience with internet shopping) So the point is: using the 18F processor how many DINX, DOUT, AINX will be needed to have the LC emu. Another point is using linear pots there is no limitation for only 8 pots as in motorfader extention so the master can be implemented as well. Some rough thoughts are for 96 buttons needed 3 DOUT Also another DOUT for led rings 1 DINX for the 9 encoders 8 for channels 1 for scrub wheel 1 AINX for the 9 faders8 for channels 1 for master. Are those thoughts right or I got it all wrong. Any inputs are welcome Thx
First of all welcome to forum The midibox 64 supports up to 16 bamks to be saved in an eprom. In each bank you can assing deferent cc for one or more channels so the answer is yes . Best Regards and good luck to your first midibox
Another fine idea from Serum Question By adding 16 encoders for volume and 16 for the usuall parameters is it possible to have the code so the final midibox will be recognised from Logic as Logic contron + extention (meaning 16 channels in one box no master volume)? (i assume I need 2 cores for this project)
Thorsten thats a fine panel one silly question the 12X4 led holes at the right upper side where are those usefull to? keep them comming... :)
Merry Xmas and a happy New Year to you too Thorsten and everyone in this forum. All the best to all the mibibox maniacs :) And may the new year bring an exciting new project. Dimitris
These words are from Axel's reply to the same question Hi Dimitris, I bought the transparent disks on top of the LEDs together with the knobs at Bürklin (www.buerklin.com), but similar ones are available at Reichelt (www.reichelt.de ) or Farnell (www.farnell.com ). Farnell is quite expensive for most parts, but delivering is very fast and easy
Or instead you can use the BB firmware with 2 buttons instead of 4 as Thorsten suggest and get the best compatibillity with logic and cubase. If you search  in the troubleshouting you will find a post from me on that matter Mind you that I bought an hex coding dial but the 2 buttons are far better in terms of usabillity here is the link http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1036351381
Good news for PIC18F migration
Dimitris_FX_freak replied to TK.'s topic in MIOS programming (Assembler)
Hi, Since all the hardware is compatibe and the price difference is very low the only considaration is availability. :( It may sound silly but I have problems getting even the 16F in Greece but since internet shopping is easy inside europe thats a minor. :) Lets upgrade the processors then.... Best -
Hi there Since you got the mackie in phisical dimmention may be you want to help me (and the forum) by getting the dimmentions of the spaces between faders buttons etc... I know its kind hard to get a ruler and start mesuring but in that way (having all the spacing diameters) I can make a autocad drawing and a pcb so all the buttons, leds, faders are in position and will require even less effort for the ones with less electronick knowlege to build an emulator. If you have 15-20 mins spare I will appreciate the inputs. PS if you have the pdf from emagic there is a draw in there so writting the values in aprinted copy and then scan it will be easier. The dimentions have to be center to center for buttons, leds for faders the screws above and below. Best...
I think Thorsten is suggesting a cut down version that standard faders emulate the motorfaders and this is possible with all the different pot modes already available in the midibox range
Thats good thinking for bothof you I would like to ask if is possible to connect only 9 encoders instead of 16? the reduntant signals just go to earth? For my self i have a plan with 2 cores 1 mf & 1 16e 96 buttons 8 motorfaders 9 encoders ( or if possible to assign master to encoder 10) and all the leds Basically an exactly copy of the lc. Best...
