Stigmata
    178
Everything posted by Stigmata
  1. Wow!!! ;D Must have this beauty in my studio! All this leds shine up in the winter darkness ;D. Cant wait!!!! Christoffer
  2. Great!! ;D ;D Just a question:(again) Can someone please tell me how to use Logic and the JSynth at the same time?? Seems like the midi interface hangs up.... Thanks! Christoffer
  3. Just great!!! Just a question: how can I save the sound i Logic? Does the dump still working in the enviroment? Just found out that the wavetable seq is still there when I turn off and on the SIDs. Thorsten you are a true hero for us!!! ;D PS Just waiting for the memorystick for the SIDs.. ;D ;) Christoffer
  4. Cool! Damn It!! Now I have to build this too!!!!! ;D ;) Take Care Christoffer
  5. Working!! ;D I tried from the DOS shell. Take Care, and thanks! Christoffer
  6. Hmmm.. Same here. :( Take care Christoffer
  7. Hmmm! Since I downloaded the new version, I cant get anything to work.. :( How can I manually get the SID into the synth menu??? Think its an total error on my computer.... :( Christoffer
  8. Question to Thorsten: Do you ever sleep??? ;)(or work?) You are a hero!!! ;D Christoffer
  9. Question to Thorsten: Do you ever sleep??? ;)(or work?) You are a hero!!! ;D Christoffer
  10. Just an tip for everybody! I got 3 "samples" of the 18f452 for free from microchip, I also got 3 24lc256 just for free.. ;D ;D ;D. Just check the microchip web site for more info.... Take care Christoffer
  11. Just an tip for everybody! I got 3 "samples" of the 18f452 for free from microchip, I also got 3 24lc256 just for free.. ;D ;D ;D. Just check the microchip web site for more info.... Take care Christoffer
  12. Great!!!! Just what I wanted to hear! Christoffer
  13. Great!!!! Just what I wanted to hear! Christoffer
  14. Hi there! Just tried to change the device-number without any luck. With the SYS-EX :F0 00 00 7E 46 [DEVICE-NR](00) 0D 04 00 [NEW DEVICE](01) F7. And then I tried to change the MIDI channel and use the:F0 00 00 7E 46[DEVICE](01) 0D 02 00 [CHANNEL] (01) F7. Doesnt work!Hmmmm ??? Take care! Christoffer Its no problem to change the midi channel when the device is 00. (I use The MIDI-OX.)
  15. Hi there! Just tried to change the device-number without any luck. With the SYS-EX :F0 00 00 7E 46 [DEVICE-NR](00) 0D 04 00 [NEW DEVICE](01) F7. And then I tried to change the MIDI channel and use the:F0 00 00 7E 46[DEVICE](01) 0D 02 00 [CHANNEL] (01) F7. Doesnt work!Hmmmm ??? Take care! Christoffer Its no problem to change the midi channel when the device is 00. (I use The MIDI-OX.)
  16. Hi there! Does the SID editor only recive data through MIDI channel 1? Just tried on my SIDs with MIDI channel 14,15 and 16. When I change the synth to midi 14, I can play the sound but not edit it!? Christoffer
  17. Stigmata
    Samples
    Fick mina också!! Dom skickade fel första gången,men jag bara mailade dom så fick jag det på nytt!!! 3st 18f452 1st 16f877A 3st 24lc256 Hmmmmm!! Undrar vad dom kräver i gengäld Kan ju alltid ge dom ett tack på skivan!! ;D Christoffer
  18. Can I try to cange the C1/C2 to another cap or can I destroy the 6581 chip more??(If its broken). Just recognize that the filters is there (somewere), but I have to turn the volume up so my speakers just shake!! ;). Another question: Whats the device number for? Take care Christoffer
  19. Seems like an Windows 2000 problem. Works just fine with my W98. And its burn much faster. Take care! Christoffer
  20. Thanks! Just great!! ;D Christoffer
  21. Has anyone tried the JDM with the Pic18F?? Or any suggestion about a new good and cheap burner? Sincerely, Christoffer
  22. The SID clock input is supplied by the PIC on all 3. Christoffer
  23. Hi there! You need: 1 MBHP CORE 2 MBHP AIN(one card is 32 pots and two is 64) 1 MBHP DIN (depends how many buttons you needs, one din is 32 buttons, 2 MBHP is 64 buttons) 1 MBHP DOUT(depends how many leds you needs(see above)) 1 MBHP LTC (If you want MIDI active leds. I think that it is necessary ;D for the great design of the box) And its also an MIDI interface with the MAX chip... I dont have that) Good luck! Christoffer
  24. Ok! I Should test the heatsinking stuff.... Dont think i should test the different caps becuse i checked the C64 pcb an only find the 470 on both... :-/ Thanks for the help! Christoffer
  25. They are cool ;D Christoffer
