NorthernLightX
    891
Everything posted by NorthernLightX
  1. Thanks, i will try that tonight, first i'll use some spiritus, and if that doesn't work i'll go for sanding. That will be a bit tricky, because i already have al the parts stuffed... What happens if some oxidation remains under the Lotlack? Will it spread, or is it no problem to have a little oxidation? I think it can not spread if I spray it, because there's no more oxygen reacting with the copper right?
  2. Hi, I've done almost all the boards now (3xCore, 3xSID, and others), and want to put them to work. Only thing is, when I started soldering them, I equipped each one with the needed power regulating stuff. Now that the C64 PSU with some mods will take care of the entire power distribution, will some parts need to be removed from the Core & SID boards? Also, the oxidation on Mikes boards does not go away when rubbing it with a soft eraser, can I just spray Reichelts Lotlack over it to stop spreading or do i need to remove the oxidation first? Can I put the boards in an acidious solution, to let that react with the oxidation, or will it eat the pertinax? Thanks for your advice. NLX.
  3. Hi, you can count me in for 2 pieces then :) Perhaps if you order them from germany you can give them my address, so they can be delivered directly to me? Saves them 2 trips overseas...
  4. Where are you from, D2K? I'd like 2 of them, but only if shipping won't be as much as the cost of the chips. (I require insured mail, here in Holland mail dissapears for no obvious reason if your package is not insured...)
  5. Voor mensen die nog stuff nodig hebben van Conrad: http://www.inkoopacties.net/ia/6mr75b8b @Twin-X : weer samen bestellen en zo verzendkosten drukken? of heb je je Conrad spul al? ;)
  6. Zodra ze bij Reichelt door hebben dat het geld op hun rekening staat. Ik heb tegelijkertijd met de betaling aan Reichelt nog een betaling naar Duitsland de deur uit gedaan, en daar heb ik vorige week al een bevestiging over gekregen. Bij Reichelt zeggen ze nog steeds niets te hebben ontvangen. Ik vermoed dat het aan hun bank ligt, die is misschien iets trager dan de bank van dat andere bedrijf. Zodra er nieuws is mail ik jullie wel.
  7. If this ever goes live i'm in for a few 8580 and all those R6 chips ::)
  8. Orderbevstiging is binnen, we hebben op bijna alle produkten toch een leuke korting gekregen! Ik PB de over te maken bedragen nu. Mijn mailserver is wederom gecrashed, maar vanavond mail ik jullie ook het excel bestand met mijn exacte berekeningen.
  9. Vrienden, de bestelling is de deur uit! ;D Helaas heb ik niets meer gehoord van Che, ik heb dus alleen voor Twin-X, Nomical en mijzelf besteld. Ik moet nog een definitieve orderbevestiging via mail krijgen, daarna kan ik de bedragen doorgeven en dan zou ik toch graag willen dat jullie zsm het geld overmaken.
  10. Mijn JDM is al af, maar nog niet getest of wat. Ik heb zelf ok nog geen cores af. Als je mijn JDM wilt gebruiken is dat geen probleem. Dan mag Twin-X wat mij betreft die SIDs hebben, dat regelen we onderling wel. ik ben overigens nog wel op zoek naar een 8580 ;)
  11. Maar als je er ook nog ongeveer 200 ronde van 3mm bij moet maken op precieze afstanden dan is het toch wel een k*twerk... toch maar laten doen dan denk ik ;)
  12. Ik werk inmiddels voor een ander bedrijf, vorige toko is nogal failliet gegaan (lang verhaal). Maar ik woon in velserbroek, moet toch te berijden zijn voor een noord-hollander als jij. Ik ben vanavond nog niet toegekomen aan het narekenen van de bestellingen, heb ook nog geen bericht van Che gekregen, en mijn server (waar ook exchange op draaide) is gisteren gecrashed :( dus ik kan even geen mail lezen >:(
  13. Ik heb van Twin-X en van Nomical definitieve bestellingen doorgekregen. Van Che verwacht ik ook nog een mailtje/PBtje, maar hij had niet zo'n grote bestellijst. Ik ga morgen uitzoeken wat we kwijt zijn aan kosten, dan ga ik iedereen op de hoogte brengen en kan het geld overgemaakt worden. hebben jullie al bedacht of je wilt dat ik het verzend of dat jullie het komen ophalen?
  14. Goeie optie! Zo te zien is de frontplate ook los te halen zodat je er een Schaefer plaat op kunt zetten... ik ga hem zeer waarschijnlijk bestellen!
  15. Beste mensen, tot nu toe heb ik 3 inschrijvingen. Ik zou dat graag naar een stuk of 5 brengen, maar ik heb ook geen zin om daar weken op te wachten. Ik wil de inschrijfperiode nog een ruime week openhouden, tot laten we zeggen 7 december, wanneer ik tot bestellen wil overgaan. Mochten de ingeschrevenen het met de periode om wat voor reden dan ook niet eens zijn, pb of mail mij dan even aub.
  16. With "a different board" i meant different components, not the actual layout. So we're saying the same, practically. Damn shame the guy kept all those SIDs for himself though :-[
  17. Die lijst is gewoon een combi van alle orderlists van ucapps.de, dus handg als je vanaf scratch begint, als je onderdelen vergeten bent weet je zelf al precies wat je mist toch? (Als je hem toch nodig denkt te hebben laat het maar weten). Ik hoorde ooit eens een verhaal van iemand, ik meen dat het Traizor was, die bijna 50 euro aan verzendkosten moest ophoesten voor een zending (was geloof ik inderdaad remburs). Dat wil ik voorkomen. ik wil voor ongeveer 5 personen wel een inkoopactie starten. Korting hoeven we niet te verwachten. Er komen natuurlijk ook verzendkosten van mij naar iedereen bij, tenzij mensen het op komen halen.
  18. Hi, i might be interested in 1 or 2 8580's. Where are you located, opiumx? BTW, keep in mind that the 8580 series needs a different SID board than the 6581, if you do try them on the 6581 board you will kill them, and that would be a shame now, wouldn't it ;)
  19. Wat raar, ik krijg nooit klachten over mijn mail. PB is gestuurd. Nog andere mensen die iets willen bij Reichelt? Hoe meer zielen hoe meer vreugd (of hoe minder cash, net hoe je het bekijkt natuurlijk ;D )
  20. De lijst van mij is gewoon een opsomming van alle onderdelen. Als je het per board wilt heeft Thorsten losse orderlists voor reichelt online staan. Weet je al waar je je PCB's vandaan gaat halen? Mike maakt ze echt perfect, scheelt je een boel gekl***.
  21. This is possible with MIOS, I have discussed this with Thorsten in the past (I too am going to create LED-rings with my CS), but I don't know if this feature is already supported by the firmware. If it's supported you would need an extra DOUTX4 though.
  22. Lijst is gemailed. Deze thread is nog slechts een animocheck, ik ga pas bestellen als er 100% zekerheid is van de deelnemers. Ik kan nog overwegen om de actie via inkoopacties.net (voormalig laupro.nl) te doen, maar ik ben bang dat dat me nogal wat meer bestellingen oplevert, en op zoveel werk zit ik niet te wachten... Suggesties zijn altijd welkom!
  23. Volgens mij passen deze kapjes van conrad: 707899 - 8B op deze knopjes van reichelt: 3301D. (0,5mm ruimte, wellicht een beetje lijm ertussen als dat nodig mocht zijn). Dat is een leuke combi, en slechts 0,40 euro per knopje met kapje! nu nog een IA bij conrad erbij doen :P
  24. Bij conrad hebben ze deze: 705250 - 8B Doen die hetzelfde als jouw knopjes, maar met een langere steel? (ik heb niet zoveel verstand van electronica zoals je ziet  ;) Die zijn wel 10 keer zo duur zeg!  >:( Deze zijn al iets prettiger geprijsd: 707724 - 8B
  25. Weet je al wat je nodig hebt? Ik heb een lijst met alles wat je nodig hebt voor een Midibox SID met 3 SIDs, als je die wilt hebben kan ik hem evt mailen? /edit die lijst moet je wel zelf nalopen op volledigheid en dingen die jij niet nodig hebt. Ik heb bijvoorbeeld extra weerstanden e.d. besteld vanwege mijn blauwe leds die ik moet knijpen, anders zijn ze veel te fel.
