pilo
Frequent Writer
    1,093
    4
Everything posted by pilo
  1. mmm I love slackware ;) (I've got a 9.1 too). Well, you can use a lot of gui stuff now with linux, but the command line can be a very fast and powerful tool too!
  2. pilo
    LCD 402A
    mmm il semblerai que oui ;)
  3. I think it's doable if you "don't care about" latency. Maybe you can add external RAM (as far as I remember the pic18f452 as got 1.5Kb of ram).
  4. hey Synapsys can you tell us mre about your fx processor project? I'm working on a linux embedded fx processor too... does this schematic works great for guitar? thanks!
  5. mm I think you have to purchase them serperatly, at http://www.albs.de for example.
  6. than you Smash!! ;)
  7. oh sure I can give the eagle file for the pcb, and the code to se inot MIOS. Actually those pga (I use the 4311, 4 channels, but you can chain them to control more channels ;)) are very easy to use! only a SPI (4 wire) interface with the core module. And yes you can line level ;) here's the link http://avishowtech.com/midibox/photos/pga.sch http://avishowtech.com/midibox/photos/pga.brd
  8. lol you're right, it's 120dB :) sorry... I just woke up when I wrote this post!
  9. yes! I saw this article and tey said that the pga2311 sound really good. I use the pga4311 and they seems to be good (but I didn't make a lot of test until now), it's quite easy to use it with mios. Maybe a cheaper solution. But it has "only" 95db, I mean the you can change the gain betwee +31.5 and -60db or something like that (and mute of course).
  10. pour le transfo, il te faut au minimum 8V (car il faut 3V de plus que la tension de sortie du régulateur), 500mA ca devrait largement suffir :) Pour le cablage, pas besoin de blinder, ca devrait etre ok tant que tes cables ne sont pas trop long (moins de 1m ou un truc comme ca). voilou ;)
  11. oki I see what you mean ;) I can help you with coding if you want
  12. mm a maxim DAC? I though about a pcm or I2S dac, maybe better for audio, with his own memory and clock system, to keep a good sync (hard to do with one pic). Making a hardware ring buffer shouldn't be hard. When the half of the buffer has been outputed, it make an interupt, handle by the pic which fill it with the new samples. So we have a lot of "time" to handle a user interface with the pic and why not some mixing? For example with the 18f452 (10Mips), we can make about 200 instruction for each data @ 48Khz. yeah, seems doable :) designing it shouldn't be a real problem too.
  13. mmm shouldn't be hard to do, but where to store the sample? I though about a beatbox with mios, but the pic18f452 isn't fast enough for sound mixing. But if you just it to play sound, it can be easy :) the DAC side can be "stand alone", always reading the same adress in the memory, the pic just have to handle mem copy, not too hard to do.
  14. essais chez albs alors : http://www.albs.de c'est des revendeurs alps officiel :) mais bon j'ai eu du mal avec eux... d'ailleur je doit leur envoyer ma commande... Je pense que 40/50euros ca doit etre le prix d'un fader avec piste servo + audio alps (bien moins chère que les P&G ;) ).
  15. mmm a ma connaissance seul P&G propose de tel fader... minimum 150euros pièces je pense... peut etre qu'un fader type servo couplé à un VCA, ou alors un des tout dernier PGA (Programmable Gain Control ou un truc comme ca) de chez TI serait moins couteux? Les pga sont réputé pour etre de très très bonne qualité (cf elektor de ce mois-ci), je vais les utiliser pour un convertisseur AD/DA ADAT, et en utilisant MIOS. J'ai déja tester et c'est vrai que ca sonne bien, mais je ferai des tests plus poussé kan meme. Ah sinon regarde sur ebay j'ai deja vu des fader motorisé, assez vioeux, un peu chère, mais avec pistes audio (et servo donc je pense).
  16. pilo
    Module Core
    ben oui c'est le quartz :)
  17. ben oui ca semble etre des cavaliers... mais avec les modules DIN et DOUT? faudrai lui demander... Mais la dernière fois ke je lui ais parler il me disait que les commandes de kit au exploser, alors peut etre il fait quelque erreurs (car les cavalier sont nécéssaire pour le module core)
  18. je pense que c'est OK car le N de la fin determine le type de package, Ã savoir un DIL la je pense donc ca devrait etre OK. mais sinon commande des samples chez TI :)
  19. pilo
    Pcb printing
    try light box ;)
  20. chipforbrains_at_technologytransplant.com voilou le mail :) il te faut aussi des diodes! ;D sinon pour l'alim, ben regarde sur le pdf du module MF il te faut du 12V AC ou un truc du genre... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3711030938&category=15199 vla un liens vers une enchere ebay du vendeurs... ils sont plus chère que prévu mais un pote en a commander 8 pour $80, et en a recu 16 de plus car ils n'ont pas le touch sensor contrairement a ce k'il lu iavait été dit!! donc vas-y betement, mail les et demandent leur si y'a le touch sensor...
  21. oouuaawww!!! really nice! how much for a big panel like that???
  22. pilo
    LCD 2 fois 40 EBAY
    mm deja vu l'avis très positif du vendeur, c'est bon signe. Ensuite il semble que ca soit les meme que ceux proposé par NG micro (à $5 pièces). donc si la les 5 c'est 10 euros, regarde avec les frais de ports mais je pense que ca vaut le coup! demande le datasheet au vendeur, mais au vu des specs qu'il donne ca semble etre tout OK. ;)
  23. ouaw! big design ;) Well, I think you can use one LCD per channel (the nokia one! you can out, if I'm right, 8 of theses on one core!!). I think the midi protocol can handle more data I think...??? And yes you can link 2 or 3 or 4 core to have more in and out ;) so yes you project is doable! :D
  24. 3 ou 4 euros pièces frais de port compris.... je me renseigne au plus vite!
  25. mmm j'ai peut etre un plan pour des alps motorisé pas chère... (oui encore un!! lol je sais mais cette fois ci les prix peuvent etre tres tres bas!)
