pilo
Frequent Writer
    1,093
    4
Everything posted by pilo
  1. pilo
    MIDIBOX LC
    heeeuuu pour les digit je pense que ca devrait marcher j'ai pas encore essayer ca... Pour les lcd de chez bgmicro, j'en ai 2 et ils marchent à merveilles :) le truc : il leur faut une tension negative, c'est pas très dur. Par contre il faut donc faire soit meme l'alimentation, on travail la dessus avec Dan (d2k) et je pense que d'ici peut on aura un truc qui marche :) (du moins testé, car c'est pas très compliqué) regroupant le 5V, l'alim pour le module MF, 4.7V pour le backlight des lcd de chez BGmicro et -5V pour ces meme LCD. Tout ca sur un CI, donc pratique!
  2. I'm going to use 4 of them for 8 channels :) let me check the aout schematic!! hehe Thanks!!! ;)
  3. so what I want to do is use the Pga2310 audio volume control with MIOS. It's maybe a Mios programming question, as I think I don't need extra hardware to interface this chip with the core module. http://focus.ti.com/docs/prod/folders/print/pga2310.html for those who wants to control some volume with their box... should be interesting ;) I want to use just a lcd, some switch and an encoder...
  4. tommy lee hehehe (yes it's easy!!! ;))
  5. try a transformer :) (I never seen AC power here...)
  6. try a transformer :) (I never seen AC power here...)
  7. hehe we don't give up :) I'm not "working" on sblive anymore, as I'm going to make an adat AD converter. But I use it to test some pcm1804 pcb, and it works great! but it's hard to solder the pcm1804... if you need balanced input you can use it with some caps and it will work :) for the sound quality I can't say much as I only test them quickly, with the audio out of my cd rom drive... I wait for gilles' tests ;)
  8. mmm I'm using a switching psu since one week now, it's one from farnell, but very old I think (it belonged to my grand father!!!) and works without any problem
  9. I was too lazy to buy a lm317.... :-[ But I thought 8V should be ok for alps, I'm going to try with a lm317 ;)
  10. mmm I use a 7806 + a 4V zener diode to make the 10V psu for the MF... I only have 2 MF, so it will not be enough if I have mor MF?
  11. www.albs.de ;D
  12. pilo
    MIDIBOX LC
    ben je pense que le touch sensor c'est vraiment bien! mais plus chère... donc en fait ca dépend de tn compte en banque :) de toute facon, rien ne t'empèche de commencer avec des panasonic sans touch sensor, et puis plus tard metre des alps avec touch sensor (c'est peut etre ce ke je ferai plus tard). mais tu peux "émulter" le touch sensor avec des switchs, mais c bcp moins pratique je pense!
  13. Identity Card
  14. pilo
    MIDIBOX LC
    alors pour les alps, chez albs.de si un jour il veut bien répondre (lol j'ai des problèmes avec lui), ben les alps motorisé avec touch sensor sont à 30euro, et 20euros si on en commande 40... c pas trop chère. Moi j'ai des alps mais sans touch sensor, et j'ai pas encore essayé plus ke ca car ma LC n'est pas encore finis. je les ai eu chez alltroncs aux USA, mais c t une quantitié limité à $5. mais sinon les panasonic peuvent faire l'affaire ils ne sontpas très chère. ;)
  15. If I have time and enough skill I would like to try using the TI PGA chip!! seems to be very good for volume control (120dB, step : 0.5dB)
  16. le JDM est une horreur !!!!! je serai un c***ard de pas proposer le service :) nan mais bon c pas long à faire alors si ca peut dépanner des gens... (et j'ai eu la chance de trouver quelqu'un pour programmer des eproms il y a quelques temps, des eproms TRES importante, je me doti dnc de faire pareil dans la limite de mes moyens)
  17. oui je peux programmer les PICS (16f et 18f) avec ce que vous voulez et pour pas 1 euros, il faut juste m'envoyer un pic et les frais de port pour le retour et hop! au pire je peux en commander chez microchip et vous les envoyer après mais j'ai peur k'ils se doute ke je n'utilise pas 350 pic! lol ;) voilou!
  18. Bienvenue! :) bon, il semble que les encodeurs te soit destiner ;) alors avec un potentiomètre, si tu le bouge, ben la valeur à l'écran aura la position du potard, mais si tu le bouge sur l'écran le potentiomètre lui ne tournera pas... par contre avec un encodeur il n'y a pas se problème : le mouvement est relatif, donc tu tourne à droite ou a gauche, mais il ne marque pas de position physique, tu peut utiliser des led rings pour ca. tu peux trouver des encodeur non cranté (j'en ais 8 et ca a le felling de potards!!!), ou alors des cranté que tu décrente (je l'ai fait sur des cranté). et oui un encodeur sera parfait pour scratcher. et enfin, pour la précision c'est pas telement un problème, parceke c géré au niveau logiciel (suivant la vitesse de rotation de l'encodeur ca incrément plus ou moins vite). voila ;) /edit j'oubliais de dire : REMORK c'est un excellent nom!!!!! ;) j'adore! et j'ai hate de voir des photos!!!
  19. mmm are you sure ;) latency has nothing to do with midi's bandwidth (as long at it's not too low, because very low bandwith made big latency), it's on transmiter and receiver side. By the way usb, parallel, serial(which is about 25% faster, but if you can use this one with all midi machine) or what ever you want is not going to improve or not latency. Midi In and Out with a joystick soundcard connector is very easy to do (and you can have led if you want), but as pay_c and js said only one input and one output.... you can use 2 of this interface on 2 joystic connector (soundcard + mother board sound card maybe?)
  20. Joyeux Noël à tous ;)
  21. why don't you post your mod here or on the portal??
  22. of course!!! ;)
  23. hehe as long as I didn't click on the remove to a message option by mistake this is ok ;)
  24. oué j'èspère que albs va me répondre à un moment... et c clair que le touch sensor ca semble quasi indispensable... arf enfin
  25. Zidane ;D
