I'm anxious to start building this, however I would really like to put the 4 cores and 4 sids on to 1 board. I think I should be able to minimize redundant parts in this way, i.e.: Only 1 each of 5V and 12V regulator should be required, Should be able to take the 1 MHz clock from one core module and split it between all 4 SIDs, eliminating 4 x 1 MHz oscillators, Only 1 opto would be required for the MIDI in, Only 1 rectifier and one set of filter caps required for the entire power supply section, Chance to omit all of the SIP and ribbon connections, as well as to leave alone many of the unused PIC pins for this application, saving board space, Keep the audio mixing section for all of the SIDs on one circuit board. I'm hoping to be a little ambitious and create a PCB layout that will put all of this stuff together, and be easy to etch by not including tracks that run between IC pins (i.e. no less than 1/10 inch spacing). Thorsten, can you tell me if there are any unexpected "gotchas" I can expect to run into? What worries me most, I think, is whether I will be able to input MIDI to 4 PICs using just one opto, and whether I can split up the core's 1 MHz clock output without causing excess loading. Would there be any advantage to using the same clock on all the SIDs, like phase coherence or anything? Also do you have any other suggestions about stuff I could eliminate by putting this all together?
