456 -
Everything posted by Phattline
thanx for the help-and for the answers :D
:'( :'( :'( :'( :'( I am crying, whats happend to this world :'( :'( :'( The Votis encoders are cheap but not so cheap like from smash and without switch :'( :'( :'( But nothing helps - voti is my only and cheapest reason.
positiv 20! Das ist ein aber ein Ding (its positiv) - hea bei der nächsten order Pflicht!!
"Non-U.S. Members. Users in Germany, Norway, the Netherlands, Sweden, and Switzerland may add funds to their PayPal account by initiating a bank transfer from their banking institution to their PayPal account. " That means I must Transfair the money to payball- Then Payball have the money- Then I order by smash Then I hope the money go from payball to smash Or whatt????????? Is this in function-Has everone tried this? I´m not from Germany-I am from Austria- german speaking
Its not so easy-evertime when i want to pm him i get the message"..username....ignoerlist..." so i cant pm him- and I wrote him the last times to email- but the problem is not solved.... :-/
Hi everbody I have one big problem: ??? ??? ??? ??? I want to have thecheapestdealeveryfromsmashtv the1d$Encodersincludingswitches (I hope that hold of the dirt) Ok I surf to his site and want to order this babys and when it goes to the moment - where to pay - I only findthewordsCreditCard, so I havent a Card- Ok I regestry my selfbypayball-and they also want from me this F********in Card. Has anybodypayedsomethingbyhimwithoutcreditcard-then please help me out-
:D :D ;D :D :D Das mit den 2 cm und der belichtungszeit ist spitze - somit konnte ich auch volgendes beweisen Billiger ist besser und teuerer ist schlechter: Jetzt is mir am Freitag die UV Hochdrucklampe eingegangen- 160 Watt hatte das ding und brauchte fürs Entwickeln 5 -7 Minuten----- und Kostete 40 Mücken Jezt bin ich schnell zum Elektronikladen in die Stadt und hab mir kurzer Hand eine 250 Watt 230 Volt Nitrad Lampe besorgt- und einen Baustellenstrahler (500Watt) da hab ich das Leuchtmittle rausgetann und auf der Seite ein Loch gebohrt damit eine normale Lampenfassung reinpasst- Siehe da: Bilchtungszeit: 90 Sekunden um 8 Mücken- und viel weniger verschleismaterial an Platinen- Mfg Phattline
I only knwo where you get The Bass drum snare hithat switches - from an very old (not foil keyboard) PC keyboard- and the backlight switches- (red ones steppa-1-16start stop and so on) forget them- cheep sh...t , 4 switches from my xbase are deff (destroyed) The Knobs what Screaming Rabbit write-are not the same like from jomox I know not good help now-
Ok ich hab jetzt das riesen Teil primär seitig fertig- und sekundär laut docs Ratschlag - größere Elkos reingetan- 2 Stück 22000 uF und 63 V paralell Mal ne ganz andere Idee (hab ich bei meiner 2xLC verwendet): Mann kann relativ höhe Ausgangsströme stabil erhalten, wenn man einen Spannungsregel IC (uA 723) mit "Nachbrenner" (Fetter Transistor) betreibt. Kannst Du mir eine Angabe machen, wieviel Strom Du für welche Spannung insgesamt benötigst ? Ich kann Dir dann mal einen Vorschlag posten, wie Du Dein Netzteil einfach und Sicher gestalten kannst. " Du sparst Dir dann die aktive Kühlung für die Spannungsregler. Die Ausgangstransistoren sitzen auf normalen Kühlkörpern, müssen aber voneinander isoliert montiert werden. So jetzt muss ich weiter schaffen. Bis später Grüße Doc " Für die 5 V spannungen wäre so eine Schaltung optimal- DOC - BIST DU NOCH DA - Wäre echt fein so ne Schaltung zu verwenden leider hab ich keinen schimmer wie die schaltung aussehen soll Für 5V und je höher desto besser ampere (< 6A)
Danke Chriss-du hast mir das leben gerettet-zumindest aber mein Geldtascherl- Schon probiert-funktioniert-
Smash TV ---AHHHHHHHHHHHHH JEAH GOOD DEAL OK I go with 100 Peaces - the switched one for 1 Doller- in no time anyone will find cheaper things in the web - switzched ones ar not so popular IM LUCKY I am from Austria (Europe Union) whats the cost for shipping Now another Qestion how to give you money-bank transfer-credit card or what
Ok ich hab jetzt 6 kleinerer und eine DINA4 PLATINE VErätzt d.H.: da ist nur die Leere Platine über geblieben keine Kupfer nix----ahhh urgl exkrement Ich habe von Reichelt elektronik das ätzgerät 2 ´Viel Größer als Vorgestellt- eher gigantisch Da passsen glaub ich wenn ic mich nicht verzehlt hab 4 Liter rein oder 5 Liter oder 3Liter Na auf jedenfall gibts dazu gleich das Passende Natriumpersulfat -zum Ätzen wo drauf steht 600 g für eine Küvette oder deutsch eine füllung oder so In der Ätzgerät anleitung steht aber 250 gramm Ich hab türlich 600 reingeschüttet ICh bin wie volgt vorgegangen: Zuerst hab ich aus einer alten 30 cm Subwoofer röhre einen scheinwerfer gebaut-ausgekleidet mit Alufolie Herzstück eine 160 W UV-HOCHDRUCKLAMPE von TUngsram (sieht wo so ein 4.5 KW Kamera Licht aus) Das Ganze hab ich so hingestellt das das Teil Himmelwerts scheint also nach oben Die PCB Daten hab ich vorher mit Eagle bearbeitet - und bin dabei laaaange Zeit gesessen- Ausgedruckt auf einer Folie wo eine Seite Rau ist damit sie ein Tintenstrahldrucker bedrucken kann Ausgedruckt mit einen Fototintenstrahldrucker TAKE 1: ICh habe oben drüber (büber der Leuchte) eine Plexiglasplatte gelegt darauf die Folie dann die PCB )wobei ich die Schutzfolie natürlich entfernt habe Die PCB ist von BUNGRAD TAKE 1a: 5 Minuten belichtung TAKE 1b: 10 Minuten belichtung Dann in Entwicklerflüssigkeit ISEL 150002 davon hab ich 1.,2 Kilogramm gekauft- der Händler in meiner Nähe hat mir gesat dass man 10 gramm auf 1 Liter wasser gibt-ok meine wanne - Lasagne form - passt 1 Liter wasser rein- nachdem ich meine Freundin gefragt hab wieviel in eine Esslöffel reinpassen - sagt sie 30 gramm- ich sag ok und schütt erstmal 90 gramm rein War wahrscheinlich überdosiert-gibts das :o Naja dann ins Ätzbad hab haargenau 45 Grad celcius gehabt- das ist laut firma die beste Temperatur zum ätzen-ja und wie es geätzt hatt alles weg- nicht das ihr jetzt glaubt das ich da eingeschaltet hab und dann eine Rauchen gegangen bin-ich bin nicht raucher-ich hab da genau zugesdchaut -und das Exkrement dreck Stück hat alles bis aufs letzte flankerl aufgelöst-da hab ich nicht im Leben eine Leiterbahn gesehjn urgl arg---- TAKE 2: Das ganze ohne Plexiglas weil ich der Meinung war das es das nicht gibt und das es an der UV durchlässigkeit von Plexiglas liegt- keine AHnung TAKE 2a: 5 Minuten TAKE 2b: 10 Minuten Gut jetzt hab ich beim Entwicklen wenigstes schon mal was gesehen- und hab nach den Schwänken leicht farbunterschiede gehabt, hab ja auch nur 20 gramm entwickler auf 1 Liter wasser gemacht-haha Gut alles geätzt und was passiert - ahh urgl geld weg urgl alle Platten sind wiedermal schön durchsichtig Also wer hat erfahrung wo liegt der Fehler-welche Dosierung nehmt ihr- Währe super wenn mir jemand helfen würde-das zeug war ja nicht billig--- :'(
UUPSSS ERROR ERROR CPU TO HOT NOW TURNING OF THE SYSTEM EIN LCD SAUGT 5V 450 mA x 16 4 SIDS 65 12V SAUGEN =? z mA x 4 4 SIDS 85 9V SAUGEN= ? y mA x 4 über 20 CORES 5 V > 20 SAUGT= x mA x 20 Drummachine 9V 700 mA x 1 Sampler 10 V 1000 mA x 1 Midiinterface big one 12 V 1000 mA x 1 Midinterface small one 9 V 450 mA x 1 DIY Syhnts 12 V 1500 ma x 3 Jomox Wechselstrom 12 V 1500 mA x 1 Und zukunftsorintiert von allen was 5V 7.5V 9V 12V 15 V Ich glaub das ist zu aufwendig da ne Tranisistor schaltung zu baun - oder Wenn ich da die L78 nehme ist weniger umstand Kann mich auch irren
Danke für Antwort DOC TORR MIDIBOX AUF den Traffo steht schon alles Drauf- NUR da steht nicht drauf das alle Kabel doppelt ausgeführt sind Meine Idee war ja nicht die Die L78 er parallel zu schalten das hab ich mal gemacht zusammen wurden die heißer als ein einzelner-is mir klar-das geht nicht SO WARS GEPLANTE-BESTELLT NE zuerst der Einschaltstrombegrenzer Ringkerntraffo Gleichrichter Siebelkos Andere Elkos So und jetzt 20 und mehr eigenständige L78er wovon jeder einzelener einen eigen Job hat- also schalt ich sie nicht parallel ALSO ZUR BERECHNUNG EIN LCD SAUGT 450 mA x 16 4 SIDS 65 12V SAUGEN =? mA x 4 4 SIDS 85 9V SAUGEN= ? Dementsprechendviele CORES > 20 SAUGT=? mA x 20 Drummachine
1$ is one Dollar - is it - anybody knows how to translate it in Euro 1$ = xx€ or cents "The ones with switch are PEC11-4225F-S0024, the only differences between these and the ones I stock are the switch and a 25mm long shaft instead of 20mm." That means 1$ for this babys - it is? Im very interestet
"PCB data, can be viewed, modified and converted with Eagle Light" Where is this sentense, DIY IS WAITING---- :o
1000 x Dank hehe ;D Das stimmt mich froh!!! THEMA 2 ist somit beantwortet- für Thema 1 ist 3,2 MIO DANK ausgesetzt ;D
Wy dont take 8 - ;D 2x4 thats coolnes real 4 x 65er 4 x 85er I love the 85 more, but 8 Sids together is the coolest thing i ever heard - more -more - more- :D :D :D :D
SERVAS MIDIBOXER Ich hab da jetzt zwei Themen und die Fragen jeweils dazu, vieleicht kann mir jemand dabei rat geben - würd mich freun! 1.)Viele lustige kleine Netzteile: OK in meinen Zimmer schauts aus-hätt ich ne eigene Website ich würd ja ein Foto uploadn- verdammt exkrement ahhh urgll- Netzteil über Netzteile für stromfressende LCDS und haufen Cores Leds - (8SIDS 2SEQ-MIDIFILTER?-MIDIMON?-MIDIDELAY?-MIDIMERGER? - etliches Producer zeugs mit Walladaptern......) Sprich ich rauche-keine Zigaretten-sonderen ElektroSmoog- und ich heitze nicht mit Gas sondern mit schlechten Wirkungsgrad Die Stromrechnung gleicht einer von einer Großfirma Die Sids bekommen eine schöne 50 Hz streuung üba Und die ganzen Wandadapter und Verteiler sind ja nicht nur schirch (Übel aussehend) sondern oft auch Schuld an Kabelbränden....oh Mann bewahre Meine Lösung: Man nehme 19 er Rack 2 HE Baue dort einen Rinkerntraffo (2+x15Volt 2x 11Ampere) mit hohen Wirkungsgrad ein - natürlich mit Einschaltstrombegrenzer- OK FRAGE EINS: GUT jetzt hab ich da 8 sekundär Kabel 2 gelbe 2 rote -die gehörn zusamm vermutlich (parallell?????) 2 grüne und 2 Blaue -//- (parallell?????????) und alle miteinander auch Parallel ??????? Ergibt dann 15 V und 22 Ampere ????????? jetzt ein dicker Metallbrückengleichrichter (oder eben zwei wenn man es nicht paralell schalten kann ) OK welche Elkos sollt ich jetzt nehmen zur Siebung???? Würden da 2 x 22000 µF aka 25 VOLT reichen (parallell geschaltet möglich????) Ja was kommen jetzt für Ceramic CAPS ......... .. Jetzt kommen die 20 L78S05, die 10 L78s09 , und andere für Studio übliche Süannungsregler Was jetzt welche ELKos und Kerkos danach- oder reicht die Siebung vor den L78 S--- das würd kosten ersparern Ja - jetzt der Kühlkörper Lüfter Das Ganze mit Aluminium (oder?) auskleiden und erden um den Smogg möglichst schnell ins erdreich zu verbannen. 2.) Was ist mit dem Midifilter: Gibts da auch eine PIC18 Version- oder is da eh nur die PDF unter Midifilter->Design vealtet Wenn veraltet - IST das Pinning noch gleich Keine Ahnung? Wurst Vieleicht das:läuft das programm auch unter einen Fullstufften Core - Gibts da was damit ich den Filter nicht jedesmal brennen-compilen?-umprogramieren!! muss Sowas wie Taster LCD - und nicht stänidg MPlab-das muss doch einfacher gehen-live tauglich sein- ICH hoffe denn so ein Filter wär eine Echte bereicherung denn die Jomox verträgt sich nicht mit überfüllten Datenleitungen-it stocks Tausend Dank für eine Antwort
Ich war heute im altstoffsammelzentrum und hab volgendes endeckt Commodore CBM Model 8050 dual drive floppy disk Die Chips im inneren: 2x MOS 6532 A 4882 2x MOS 901482-07 4682 1x MOS 901467-0 unlesbar 4681 1x MOS 901483-03 5082 2x S 8239 SY6502 A 1x S 8248 SY6522 Ist das so eine Art Externes Laufwerk für ne C64 oder sowas? - nur ein Anschluss! Kann ich das Teil getrost wieder entsorgen oder, kann mann da ihrgendwas noch brauchen, oder wird mann da ihrgendwas davon brauchen können (Ucapps zukunft?). Ist da ein Grafikchip dabei, oder Soundchip, oder sind das alles nur controller chips zur ansteuerung der floppys???
I know one of the guys are member of ucapps-they saled the last pics of this project (there was a topic some time ago) ...The question: what is the status (V5), where i can get a eagle, targed, word, bmp, jpg, pdf, file for the pcb boards? Can I burn the PIC 18f425 with jdm programmer and can i take a bigger lcd 2x40 or 2 * 2x40 Thankx for answers
".....grünen LEDs runterlöte und dafür ebenfalls blaue drauf? Hab ich dann ein blaues? oder ein blau-grau-grün-nicht mehr ablesbares? " Das is ja mal eine Iddeee, Lcd´s umrüsten. :) Aber... :-/ Bei meinen Lcds sind keine Leds drinnen, sondern so leucht folien, wie die die´s bei reichelt gibt(keine Ahnung damit´s halt gleichmäßig leuchtet) Grün und blau ...hhm das wird cyan (unter google bilder cyan suchen und da sieste wies aussieht) Ein bißchen schwerer lesbar wird schon. Deshalb haben die guten -teueren blauen Lcds meist eine Weiße schrift auf blauen hintergrund
wenn ich die teile habe schreib ich,obs funktioniert hat
