reboot
    308
Everything posted by reboot
  1. doug's MB-808 sequencer is the best choice ...with a A/B button too (maybe thre's a way to do it by the menu)
  2. t'as essayé de connecter les dout sans les 74HC595 ? ensuite verifie toutes les tensions sur les supports de chip (pattes 8 et 16 ) meme si tout déconne si ça marche,essaye avec 1 puis 2 etc et tu verras celui que tu jetes si le cas tous les jumpers sont montés ? verifie toutes tes lignes de masse le pic n'a surement rien a voir sauf si une patte est pliée... sinon ton alim est vraiment ok ? bon courage
  3. maybe he's on holliday.... do you know that project ? http://www.msc175.de/geraete.htm same but modular !
  4. guess who's nILS ....
  5. "MIOS boots up, and then starts formatting Patch 'A'. (even when I have no bankstick connected!)" does your wires from core to bankstick are disconnected ?
  6. nILS where is Lucy ?
  7. very very well done !!!
  8. cool....100...depand on price thank you
  9. Doug is trainning for "le tour de france"....
  10. in fact i don't need to use the day of the week do i have to change the main code and a bit of hardware ? or do i have to use 1 or 2 max 7221 for exemple without change code ? thank you again
  11. nobody ?
  12. bonjour j'ai eu un probleme (le mios n'arretait pas de rebooter)...c'etait l'alim... quelle est la tienne ?
  13. hello the project is a clock i built this one : http://pagesperso-orange.fr/fabrice.sincere/cm_electronique/projet_pic/RTC/RTC_I2C.htm my problem : i need to use 12 x 7 segments digits , not the lcd sorry to ask some help but i'm stuck thank you
  14. thank you ... the thing i like with lexan is you can make transparent or opaque windows ..so if you have some leds they can be visible under the lexan . the same material as the xpander .. do anybody knows a "cheap" company ?
  15. why don't you build the PIC Burner ?
  16. dirty man
  17. hello my new stereo sid .. button from Mte (please tell me when you'll have more !!) D9 under panel ...that's a good solution but a bit hard to calibrate ..i don't fell the "click"so it's perfect for me. lexan panel,i had to buy some as just 1 was too expensive thank you
  18. did you have sex ?
  19. rotary encoders are so expensive.. voti is cheaper even if u live in canada
  20. c'est quoi ton alim ?....elle s'ecroule pas par hasard?
  21. reboot
    Debug AIN
    merçi pour ton post ...ça peut servir tu as raison de ne pas mettre de leds bleues ou blanches j'en ai fait les frais. ou as-tu fais faire les panneaux ?...felicitations
  22. amazing work !!! thank you
  23. rectification : i made the design and mount the parts, my friend Nico the wood (the most difficult), and Julien the keyboard interface (the brain).. Nico sells superb custom furniture and the synth was a challenge for us . when i ordered 1 month later the back plate ...the bronze color was different from cs..next time i'll do with lexan . by the way all the furnitures and the synth were made of wood ..sand...sand...sand the corners...and 6 or more coat of lacquer...never again buton encoder from mte...thank you
  24. the button is just a jack with tact switch from voti for sustain Julien Voirin implemented the keyboard ...i'm sure he posted something about it . IMG_2042.JPG IMG_2042.JPG
