MikePig
    25
About MikePig
  • Birthday 01/01/1
  • Gender
    Not Telling
Recent Profile Visitors
MikePig's Achievements
MIDIbox Newbie
  1. Hi sneakthief thank you very much for the hex it is working as far as I could try it ! Moreover ilmenator's SCS (connected to j8/j9) is modifying some values on the lcd ... Vielen dank Grusse aus Frankreich
  2. Ok thank you for your answers And sorry for my poor english Best Michel
  3. I didn't missed it but as this particular "SCS" is connecting to J8/J9 . I was just wondering if it could cause a conflict with two LRE8x2. Best Michel
  4. MIOS Terminal seems to report everything is OK (apart from the SD Card issue). Yes I tried J15A and J15B without any differences. Also I was expecting to use ilmenator's SCS but it connects to J8/9. Is it possible to get it work with two LRE8X2 ( TK ? ) Best Michel
  5. Hi I just tried Sneakthief's hex but the lcd displays a first line full of blocks nothing else. Here is the MIOS Studio outpout : SD Card not found I tried the Seq V4 on my core and everything worked as it should... any ideas ? Michel
  6. sneakthief Thank you very much for the hex file !! I'll try it By the way how many LRE8X2 are supported ? One (website) or Two (as stated in the config file) Best
  7. Hi Could somebody be nice enough to compile an uploadable hex or bin file for my newly built stm32f4 core ? I would like to do some UI testing with SCS and 24X2 LCD TIA
  8. Salut, Un peu tard comme réponse ... branche le 5V sur J2, supprime et shunte le 7805. A plus Michel
  9. Hi Please check connection between sc on j19 and the IC pin pb6. On my core IC pin pb6 is connected to the SIL resistor network as it should but there is no connection between the resistor network and J19 ... Could someone confirm the missing track or do I have a faulty board ?
  10. Hi I'm in for one semi kit Regards
  11. Hi Rosch ! I'm interested in all the tr9090 if they are still available ... Regards
  12. Hi, Is it possible to set the note duration (gate length) in step recording mode ? Regards
  13. MikePig
    SEQ V4 CS
    Hi ! Nice work . Where did you get the pcb ? From the bulk order ?
  14. Hi all, Some few questions : Is it possible to wire the encoder directly to J10 in order to save a DIN module ? Does it make sense to use 3 leds digits for the step display as the v4l has 64 steps ? Regards
  15. Rosch, this is the stock firmware from the old midibox plus . Jojjelito the programmer is only working with shruthi-1 i think . This a shruti-1 .
