25 -
Everything posted by MikePig
Hi sneakthief thank you very much for the hex it is working as far as I could try it ! Moreover ilmenator's SCS (connected to j8/j9) is modifying some values on the lcd ... Vielen dank Grusse aus Frankreich
Ok thank you for your answers And sorry for my poor english Best Michel
I didn't missed it but as this particular "SCS" is connecting to J8/J9 . I was just wondering if it could cause a conflict with two LRE8x2. Best Michel
MIOS Terminal seems to report everything is OK (apart from the SD Card issue). Yes I tried J15A and J15B without any differences. Also I was expecting to use ilmenator's SCS but it connects to J8/9. Is it possible to get it work with two LRE8X2 ( TK ? ) Best Michel
Hi I just tried Sneakthief's hex but the lcd displays a first line full of blocks nothing else. Here is the MIOS Studio outpout : SD Card not found I tried the Seq V4 on my core and everything worked as it should... any ideas ? Michel
sneakthief Thank you very much for the hex file !! I'll try it By the way how many LRE8X2 are supported ? One (website) or Two (as stated in the config file) Best
Hi Could somebody be nice enough to compile an uploadable hex or bin file for my newly built stm32f4 core ? I would like to do some UI testing with SCS and 24X2 LCD TIA
Salut, Un peu tard comme réponse ... branche le 5V sur J2, supprime et shunte le 7805. A plus Michel
Hi Please check connection between sc on j19 and the IC pin pb6. On my core IC pin pb6 is connected to the SIL resistor network as it should but there is no connection between the resistor network and J19 ... Could someone confirm the missing track or do I have a faulty board ?
[S] TPD (Track Position Display) 5 semi kits for sale
MikePig replied to ilmenator's topic in Fleamarket
Hi I'm in for one semi kit Regards- 14 replies
[S] x0xb0x, MBFM built modules, PIC & SID boards, Waldorf Knobs
MikePig replied to rosch's topic in Fleamarket
Hi Rosch ! I'm interested in all the tr9090 if they are still available ... Regards -
Hi, Is it possible to set the note duration (gate length) in step recording mode ? Regards
Hi all, Some few questions : Is it possible to wire the encoder directly to J10 in order to save a DIN module ? Does it make sense to use 3 leds digits for the step display as the v4l has 64 steps ? Regards
Hi, Just to confirm the ASX only needs power and a MIDI In socket to work . optocoupler is on-board . I tried today it's working like a charm . Regards
Hi, Sorry I think I misexplained myself : I was thinking about digital potentiometer (IC) that are controlled by the software. The IC replaces the mechanical potentiometer and is controlled by rotary encoder. So the feedback value would be stored into the patch structure. Regards MikePig
Hi, I'm about to start the frontpanel design for a 19 inches rack version of MB6582 and was wondering the following : Is it any space left in patch structure and DOUT left to use digital potentiometers so that feedback could be driven by the frontpanel encoders and their values could be saved in the patch structure ? MikePig
Hi all Could the following link be helpful ? http://www.smspower.org/maxim/docs/ym2612/index.html IMHO I think this chip can output amazing sounds and with a midiboxsid this could be an ass kickin' team. Bye
Salut ! Pour des materiaux sympas style résines, silicones vous pouvez essayer les magasins de materiel dentaire. Ya vraiment tout ce qu'il faut : silicone de couleur pour faire des boutons style soft touch , des resines translucides ou opaques, materiaux de moulage, .... En plus généralement ca durcit en moins de dix minutes Voila c tout ! A+
Hi Thank you for your help ! I thought I just have to burn the pic with the.hex files to get it working ( just like the old non-Mios apps). My SID is now playing notes ! Now you can vote for THE LAMER OF THE YEAR !!!! (MikePig without a doubt) Thanks
Hi I have a core module with a 16x4 lcd on it. I have tried to program the 18F452 with various firmwares (midimon, midisid, midi box64) but the PIC don't boot and the lcd stay with 2 black lines. I have checked the voltages of my jdm programmer, all seems to be ok... I can even burn my old 16F877 (with the last mb64 firmware) and they worked with my core module and my lcd (even underclocked since I have a 10 Mhz crystal on the core). ICProg report the 18F452 as succesfully verified and I can read the firmware and compare it with the source firmware all is OK but when I plug the PIC and the core, the display stay black. What is this strange behaviour have anyone an idea ? P.S.: I have put the resistor between pin31 and Pin 38, I have tried with external power supply on the jdm, it doesn't change anything. I have tried with WinXP, Win98 with two different computers.
