993 -
Everything posted by moxi
hi , thank ,great explanation! The AOUT is needed to send Control Voltage , you're right , but when i said "just a core and an AIN " , i want to know if i can "catch" the value of the pots and , using the "AIN" module , convert them to MIDI (and then output it through the midi out). i think the use of a Voltage Controlled Resistor is possible ,but such a thing won't help me in "catching" the position of the pot and i think it must be a way to do this without modification on the audio signal patch (without replacing parts of the original design. what i'm thinking : just replacing the pot i want to "midify" by a two pole one ,and so using one pole as planned in the original design ,and the second pole to drive the ain module ,using an additionnal circuit to get the voltage range that the ain can handle. it would be easier , no ? In this way , i don't have any matter even if the pot are "log" ,the midi data will represent the physical position of the pot ,not its "electric value" ,and i can simply use a table in the mios to match incoming and displayed midi value to "outputed" cv . (what i mean : if the pot is half of its "run" ,so the second pole send a value that mios display -and send out - as "63") ,and so if the same value is received @ the midi IN , the AOUT must send a cv that drive the pot to half of its "run". it's the purpose of the "tables" ,i'm wrong ?)
non ,il dit qu'il ne vend que le pcb (le circuit) ,du module MF ,à toi de commander les autres pièces ailleurs. SANS LE PIC ,c'est pour le core ,tu peux l'avoir avec ou sans le PIC ,ou tu peux commander le PIC seul. prends ton temps avant de passer la commande ...
salut ,effectivement les pcb de smash sont de meilleur qualité ,et avantage notoire sont "signalé" (on sait de suite oû mettre quoi). pour le pic header ,t'as juste :000000000000 ,si t'as qu'une midibox ,un lcd non graphique et que tu utilise pas l'interface midi to com (si tu te sert des prises midi et non du connecteur "to com"( pour ordi ).n'oublie pas d'enlever le "MAX232 " sur ton module LTC dans ce cas là !
si tu fait exactement la midibox decrite par les fichiers téléchargeable ,pas de probleme ,mais l'intêret des midibox ,c'est vraiment de pouvoir te faire une boite personnalisé .Quand je dit "programmation" ,il s'agit dans la plupart des cas de petites modifs que tu fait en mode texte avant de compiler l'apps , comme par exemple lorsque tu veux mettre un module "din" en moins : dans mon post précédent ,je te fait remarquer que tu est limité pour la LC à 16 "shift register" (ce sont les chips présents sur le mdule DIN) ,et que tu dois spécifié dans un des fichiers de l'app combien de ces chips sont connecté au core : t'as juste à modifier le chiffre ""16"" ,si tu mets moins de 4 DIN. D'oû l'intêret de parcourir ces fichiers ,aprés ,le programme "vmidibox" simplifie beaucoup de chose : http://serge.midibox.org/ . mais il vaut vraiment mieux commencer par faire une box "standard" ,ça permet de comprendre vraiment comment tout ça fonctionne ,et il est toujours possible de les améliorer plus tard.. Enfin ,te décourages surtout pas ,tout à était fait pour etre accessible à tous .
il y a tellement de config possible pour tellement d'applications que ça ne servirais pas à grand chose de faire ça , en plus ,ça dépend aussi de tes compétences en termes de programmations! attendez la traduction en français du site ,je mis mets dès que mon séquenceur est fini..
ohmstudiste: envoie moi un pm pour voir comment je peux faire pour t'envoyer ça.
Salut , les boutons de clavier sont tout à fait utilisable pour les midibox ,et à priori ,des boutons de c64 ,tu dois en avoir si t'en a récupéré un (c'est pas compliqué à déssouder),les boutons que j'ai sont plus récent (il viennent d'un vieux vieux pc portable) et sont un peu moins "massifs".Sinon va voir à quoi ressemble les touches d'amiga 500 ,j'en ai aussi .(si le look "gros carré te plait pas ,tu peux enlever juste le cache ,et le remplacer par un autre bout de plastique qui te plait plus...) pour le bancstick ,je peux te filer un connecteur sub 15 male et un femelle , Pour le chassis ,celui que j'ai n'est pas adapté pour un boitier desktop (c'est un peu dommage de le découper alors qu'il convient parfaitement en l'état pour un rack).
La jog-wheel ,c'est un encodeur ,tu mets juste un "capuchon" plat et plus large pour l'ergonomie. pour ce qui est de remplacer les buttons par des encodeurs ,c'est possible ,mais tu est de toute façon limiter à 16 shift register ,(dans le fichier main: """#define NUMBER_SHIFTREGISTERS 16 ; length of shift register chain (max value: 16 == 128 DIN/DOUT pins)"""" donc jusqu'à 64 encoders si tu mets aucun bouton. après ,dans "mios tables.inc" ,tu "dis" à l'application sur quels pins ils sont connectés . par contre ,je sais vraiment pas si il peuvent etre utilisés lorsque tu es en mode "LC" ,j'ai l'impression que cette possibilité est plutot destiné au mode "GPC" (general purpose controler). charge donc l'application et parcourt les different fichiers ,ça te permettra de voir mieux ce que tu peux faire ou ne pas faire. sinon penche toi sur la midiboxE ,a mon avis plus souple et logic se pilote trés bien avec un controleur "général".
comme je t'ai dit ,l'utilisation simultanée de fader (ou de potars ,c'est en fait la meme chose :des résistances "ajustables " ,seul la forme change) et de fader motorisés n'est pas possible sur un seul core (ou ça demande vraiment de grosse modification sur la programmation ,et je pense que si il est spécifié dans le fichier de config qu'il faut choisir l'un ou l'autre ,c'est que le probleme est difficilement surmontable (en général ,les applications sont vraiment le plus souple possible ,et ça devient vite hazardeux de se lancer dans des trucs trop compliqués pour des "détails".) pour ma part ,je te dirais de te concentrer sur d'une part une midibox LC ,et d'ajouter ,dans le méme boitier si tu veux ,juste un core et un module AIN ,et en choisissant un alimentation appropriée ,tu pourras la partager entre les deux core ,pour limiter le coût.De plus la fonction "midilink" te permet de brancher tes deux core l'un aprés l'autre et ainsi de n'utiliser qu'un port midi sur ton pc. lit bien les réponses qu'on te donne :les fader(et les potars) ,c'est analogique ,donc ça va sur les modules "AIN"(Analog INput).
en fait ,tu doit avoir raison ,dans le fichier "main.asm" de la midibox MF tu trouves ça: you could enable the multiplexers here to test this application ; with a MIDIbox64 based hardware ; if 0: no multiplexers (a *must* when MF module connected) ; if 1: use multiplexers #define DEFAULT_ENABLE_AIN_MUX 0 donc l'utilisation des motorfaders exclue l'usage des multiplexers. Et pour la midibox LC ,le fichier "main.asm" ne contient aucune réference aux modules AIN ,donc il doit etre très difficile de rajouter des entrées analogiques sans un bon paquet de programmation.D'un autre coté ,tu peux y choisir d'utiliser le fader 1 en tant que master fader : #define MOTORFADER0_IS_MASTERFADER 0 ; if set, the first motorfader acts as master fader sinon deux cores ,c'est le plus simple (pas le moins cher) et ça te permettrais en plus de séparer la partie "contrôle de la table mixage" /" contrôle des vst".
c'est à dire des consoles vraiment fumée ,ce qui arrive fréquement avec les petites mixettes type disco ,mais j'ai aussi vu des consoles plus grosse qui avait pris feu ,et comme la feraille ,ça brûle en dernier ,un coup de ponceuse et t'as un chassis 8 ou 12 voix pour le prix du timbre ou de l'essence pour venir le chercher ...c'est ça que je veux dire. je bosse entre autres pour une boite qui fait pas mal de sav ,donc qui a pas mal de stock cassé ,ça c'est bien ,le probleme c'est qu'il essait de tout recycler ,donc il faut attendre qu'il jettent sans regret . je vais tacher de trouver d'autres point d'approvisionement ,nottament pour des plaques de metals ,ça doit etre assez simple à trouver des chutes chez les industriels ,et aprés c'est trés simple de plier des plaques pour en faire des boitiers (faut pas demander des origami!).ça me rend un peu malade de voir les gens foutrent 70 euros dans une boite en fer! de toute façon ,je pense que je vais d'abord me lancer dans une traduction en français d'UCCAPS ,quitte à la mettre en ligne en format texte (je suis pas webmestre) ,en attendant que les demandes que j'ai faites deci delà pour le matos aboutissent.
salut ,pîlo ,est-tu sûr qu'il ne peut pas rajouter un fader classic ? à priori ,rien ne l'empeche d'ajouter un AIN Module (AINX4 J5:A -> CORE J6:RC et MF module se connecte en J7 sur le core) ,si ce n'est de modifier l'app.En tout cas ,je n'est pas trouver sur UCAPPS de contre indication ou de mention d'une incompatibilité entre les deux modules. piergynt: tu semble vouloir utiliser un Module DIN pour tes douzes potars :c'est un module AIN qu'il te faut pour ça (mais quel est l'interet de mettre des potars "classic" là ou tu peux mettre des encodeurs ?) si ils sont destiné à controler toujours le même paramètre et que tu veux savoir à quel "niveau" ils sont ,utilise juste des caps avec une marque sur des encodeurs(ou des led rings) ,ça te laisseras plus de liberté pour d'éventuel changement de config plus tard. En même temps si tu veux absolument un fader (un potar rectiligne) ,effectivement il te restera des entrées sur ton module AIN. et c'est très bien d'ailleurs d'avoir un fader non motorisé pour le master ,ça évite de bousiller ta sono ou tes oreilles en cas de mauvaise manip ou de mauvaise config midi (genre le fader qui part tout seul à +6db quand toutes tes pistes sont à fond ,ou quand tu viens de quitter la pièce pour répondre au coup de tel de ton boss...)
apres verif ,les alim de commodore que j'ai (pas 64) fournissent un +5v et un +12 ,elle semble tout à fait convenir au projet "sid". vu le nombre de réaction positive à ce post ,je vais pas trop m'affoler ,mais je devrais d'ici un ou deux mois etre en mesure de proposer gratuitement notament des berceaux et des dessus de consoles ,en plus de petites parts qui peuvent toujours servir.
if i all understand ,the 2 bankstick is a limitation of the app. see "http://www.subfrequenz.net/techlog/mbox64b.htm" and you will see how to put more bankstick. puis va voir sur la partie française,j'ai mis un post pour me débarrasser de pièces inutile ,dont un rotary switch deux poles ,six positions.si tu le veux ,mail moi.
et un berceau 19" 4U mais sans les equerres pour le montage en rack (c'est en fait la partie coulissante d'un tiroir pour rack)
salut ,siçà peut vous aider ,je me débarasse de quelque pièces qui ne me serviront pas dans mes projets à venir. aprés les avoir triées ,je me rend compte que peu peuvent etre utile pour les midibox ,mais on ne sait jamais: un soixantaine de buttons alps extraits d'un clavier de portable ,et j'ai 4 ou 5 clavier type commodore qui attende d'etre déssoudé (je le fais si quelqu'un en a besoin). -2 ou 3 bloc d'alimentation de commodore 500 (allez voir sii ça peut correspondre ,nottament pour les projets "sid") -3 transformateurs: 9v \1a 12.6v\1.2a 12.6 \0.3a -2 ou 3 connecteur d-sub 15 broches (pour les banstick) -1 "rotary switch" 2 poles \6 positions (pour switcher entre 6 bankstick ,cf : """http://www.subfrequenz.net/techlog/mbox64b.htm""" ,pour faire la même chose mais sans les leds ) -2 "14 pin wire wrapping socket" ,c'est comme les supports pour C.I. mais plutot destiné à recevoir des cables étamés(enfin je crois). -et "25 litres" de switches en tout genre ,2 positions ,3 positions ,à levier ,à bascule , types slide ,dpdt,spdt,dpst,spst...(ce sont des interrupteurs utiles pour la mise sous tension par example ,pas des "push buttons", (dites ce que vous cherchez ,je vous dirai si j'ai) -2 potars 5k ohms -5 ou 6 adaptateurs passifs xlr femelle sym basse imp \jack asym haute impedance . -une dizaine d'embases RCA -5 leds vertes rectangulaires (1*3mm) tout ça vient d'un vieux stock d'electronique ,la plupart des pièces sont toujours dans leur emballages d'origine . tout est gratuit ,mais vous payez les frais d'envoies ,donc je suis pas sur que ce soit forcement rentable ,notament pour les transfos. Je fais ça pour amorcer l'idée d'un stock de pièces pour midibox gratuites ,et je vais dans les jours qui viennent tacher de récuperer des pièces plus spécifiques au projet ,pour faire en sorte que le prix de revient des box soit le plus bas possible (une façon de transposer le concept d'open source au materiel aussi). Si vous avez plein de pognon ,ne vous jetez pas dessus ,penser à ceux qui sont " à 10 balles près" ,et si vous avez des trucs en trop ,pensez à faire pareil ,peut-etre l'idée d'une page commune pourrait etre bien ,quitte à ce que chacun se débrouille de chez lui à envoyer ces surplus.... A plus.
hi ,maybe i will be interrested by your notes .I'm a beginner ,and after i've read the datasheet of the ym 2149f ,i think it could be a better start than the sid to understand realy how are working this sort of sound ship. you say your project is ambitious , but what i need is rather something very simple ,a project that can grow later ,following my knowledge ,so can i extract a "simple" structure from what you often do? thanks and sorry T.K. ,one more time i've send a topic before searching in other posts ...
et y' en a plus... faites des achats groupés!
Hi , waiting for the panel of my first seq ,i want to start my second box , a midibox64E in wich i want to be able to load a second seq. but there is some thing i want to know before ,cause i'm really interesting in having the led ring of the 64E ,and what will happen with the leds the SEQ don't use ,and on the other side with the led of steps 12-16 the mb64E don't use? can i re-alocate the led rings on a second DOUT module ,so i keep the basic config of the SEQ ,adding a line of 16 leds under my gp buttons ,even if they aren't used by the mb64E app (and if it's necessary adding a multi-layer switch to disconnect the second DOUT before i load the SEQ app and doing that when the box is not powered)?
hi , can i do something with the yamaha "ym 2149f" ship? ,maybe a "mini" MIDIBOX FM? i tell you that cause i got 4 or 5 of this ships ,and as much " commodore A500" ,where I find them. Maybe someone have a link for info about functions of this ships?
i think the matter is the code of other ship are often not in open source. if you have facilities in programming ,let see what analog device propose ,but the price for the devellopment kit is very expansive ,and if there is a lot of "atom" in free access ,you really need to have good knowledge.
one time again i feel me stupid : yes is the filtrex-1 i plan to build but i didn't see that there is cv input on it ,and what i want is just to have midi in/out on the unit .So i think it will be not too much difficult to use simply a core module and an AIN one as midi/cv interface? i'm wrong? on the filtrex there is only the cutoff freq that you can control ,but as soon as i will receive the kit ,i will try to analyse how it work and if it's possible to replicate it for other function (the Rezo mainly ,others are not very usefull as they can stay "fixed") what's the better midibox appz to use? maybe it's possible to use the midimon appz ,so i will be abble to display the value of incoming midi data and why not ,using a DIN module to display directly value of pots? i think it will be not too much difficult to do it ,adding some resistance to get the 10k ohms the DIN need?
hi, after my seq will be finished ,i plan to build an analog filter of "oakley sound" web page ,and before starting this project i would know if it would be difficult to add midi for the main parameters. If i know how midi work ,my knowledge of analog control is very limited ,maybe someone can give some links to page where i could learn about midification (what i need is very similar to midification that some shop propose for vintage synth) ,because if i understand how you can convert midi to analog signal for triggering or how you can transpose the value of the resistance of a pot into digital data ,i don't see how you do to change the value of the resistance of a pot without using motorized pots (i suppose that on vintage synth ,they don't replace all the pots by motorized ones!). thanks
and i you take 100 pieces through albs ,it will cost you probably less than order 60 in other shops..
see with albs.com ,but they don't sell less than 100 pieces ,but if you ask them 100 parts of somethings ,and you need only one or two pieces of another parts ,they will give you them as samples. if it's for pots or fader ,i think you will easily find other peoples who want the same ,in order to do collective order.I've bought 100 knobs and i as only need 60 ,i've found other people to take what i don't need in the 3 next three days...!
