        mattias
                Posts89
Everything posted by mattias
	I am having trouble to read the SD card on Mac OSX... reports 2 TB and unreadable?? Any ideas??
	An A/B seq. select for fills maybe.. hmm.. it is probab doable now??!! And how about if internal loopback routing was on the recive channel (not the sending), that way one loopback could control more than one track.. just thinking here. Maybe alredy doable!!?
	I think this is evolving just fine TK.. But I think every track should have a dedicated loopback track... were every loopback parameter is displaed in name not CC.
	A Gate time Trigger or Layer to vary the time intervals between the steps. The steps can be set within the range from 1/384 to 16 1/1 notes. Like on the Scritty... or even higher resolution.. Midi processors for internal routing... with midi fx... LFOs and midi filters.... maybe the arp. should go there More random stuff... rotate....skip closed gates ... random move active gates selected and or random chance by percent... There is alot of crazy stuff that can be done here... Maybe 16 tracks for internal loopback so funktions can be muted / toggled on off. This would be like dynamic editing... the seq programning itself. So we can have tracks triggering Track directions, Track direction progressive parameters, clock divider for each track, normal and tripled, groove quantiasion start and stop of sequnces and loop points. I think all my ideas can be done with 16 internal loopback tracks like the 16 new drumtracks!! YES lan midi please.. wifi?? Possible?? I don´t mind features like 128 steps... but please keep it a stepseq... 64 steps is fine even 32 as it is now.. A memory place holder for timebase and groove... using gp buttons to change the tempo and groove quickly... Drummaps.. yes please!! Nameable!! More CC layers in the mixer map... Maybe a daw mackie/LC controller... maybe not keep it a seq... Midi sync. delay calibration.. Clock sync delay in ms... from say -30 ms to +30 ms Maybe my ideas are to crazy but think about it.
	Ok TK.. get the picture now I thougt it was ment to stay in edit mode.... sorry.... still some weird things going on if you use the GP buttons/encoders in layer display! And I do use the edit button... ;) ...it´s a nice feature now that I got it explained.
	I think i have noticed something that has changed! Maybe a bugg!! Goto layer asingment! Press Layer A Turn a GP encoder or push a GP button... Now you are back in layer asignments.... Think all menues work the same way... Think it would be nicer if you could jump to the track with Trigger and Layer!! Hope you gys understand what I ment!!
	How about a drummode event 3 individual gates (notes) per layer!! I know this can be done but it is not straigtforward... And mybe a simple chord event mode wher you trigger chords insted of notes... Maybe a LFO event mode where you can trigger an LFO restart, sending CC, and LFO speed back to the LFO!! Just some ideaes!!
	:-X Ok... I see it was in main.h...sorry! I am not at really a programer.
	So I have to change things in the sourcecode? main.c? How do I set it up for MB seq. Mackie emu?? And change lc_dio_table_mbseq.inc to my needs. Make the hex file. But main.c is were I need help!
	It works! Now all i have to do is map up buttons and encoders for ableton live and my workflow! :D Things were a litle wierd... what is mapped to what? :-\
	Is it for PIC18F452 only? or can I use mb seq 3 as is?
	Gould we get Gp butons to send CC in the midi map? It would be nice to have!! ;) And nrps so we could control MB sid 2!!
	MBLC! Can I use encoders insted of motorfaders? ::)
	Could it be done??
	Any chance of getting some?
	That´s sorted. Now sholud i rename the group? :-X
	Ok. Setting the group to invites only asap. :-X It is just ment to for midiboxers who is on trig. So we can find each other there. If the community thinks i have done somthing wrong then I will remove the group!!
	Ok. It is the basic MBseq firmware or whatever. Just added the Groupselect and Triggerlayer buttons whit led. The toggle 16/32 with led is also there. I went for encoders with GP button integrated. I think it works just great. It´s not recomended by TK or others, but i can´t see why. Not just now anyway! :D The 4x40 has a second enble line so it works just like having two 2x40 stacked. The design was inspired by the "schrittmacher", I was planing another design first but this idea grew more and more on me. So I ended up making the "knappspel". "Knappspelet" is the Swedish word for "The button accordian". Maybe more pictures?? ../Mattias
	There is no point.... other than people on trig with an will know who is a midiboxer. Just trying to get the word out. So are you on trig? Do you know what it is? I did not create the trig group to compete with this forum. Just simply so midiboxers on trig can join... so try trig.com... It´s better if there is a group so you can find other midiboxers.
	BUMB. No trig users ??? !? ???
	Got my sequencer "Knappspelet" up and running!!!! ;D More info on http://trig.com/sid_64
	Now there is a Midi box group! http://trig.com/group/midibox And my trig page is http://trig.com/sid_64 This is fun! Lots of potential for you! ...//Mattias
	Anybody here who usese trig.com? http://trig.com I am about to set up a midibox group! Look in to it!
	Solved.. Had to use bit 4 and not bit 7 as default for SR 5 in asm file! ;D ;D
	I think I found a bug! ??? Turn on the MBsid and go to Core 2, Drum engine. Select SEQ and COPY PASTE = No MBnet response! Turn off. Turn on! This time first go to Drum engine on Core 1! Do not turn off!! Now go to Core 2 and repete Drum engine - SEQ - COPY - PASTE, now all is fine...
