1,774 -
Everything posted by cimo
You want to replace keys with pots? Explain, this sounds weird.
Dance and video... uh there's music in it, it's kinda ontopic...
cimo replied to stryd_one's topic in Miscellaneous
no link but -infrared camera -high definition camera -infrared led array, probably you need around 10W or more -high definition projector -movement tracking patch (you can find one in the pure data s example), this will use the IR camera to track the movement of the bodies -with the gem object you can create shapes and manipulate them, as well as capture images from the camera and manipulate them -pretty danish dancers (optional, you can throw in your cat) -
What's the difference between MIDIO128 and MIDIbox64?
cimo replied to g.andreini's topic in MIDIbox HUIs
It takes a bit to grasp the basics of Midiboxing, you need to read more. MB64 has some better functions for pots handling while MIDIO128 is fully exploiting the i/o capabilities of the hardware/software.This is not enough. MBs can be connected in different ways depending on what you are trying to achieve, try to be more precise about this. Good luck and welcome Simone -
fuse? as long as you don t have a maxi MBLC with lots of LCDs and motorfader you may skip the fuse thing. Otherwise you just need to calcultate how much current you are drawing example: (some random numbers here) lcd= 200mA core=50mA i/o chain= 200mA tot= 450mA let s make it in power= 450mA x 5v =2250mW let s calculate current for 220volts (europe): 2250mW/220v = 10mA Take it double, you need a 20mA fuse! The fuse should go between switch and main
perche? e evidente che definisce un encoder per il pwm quindi la funzione c e.
aaah scusa, mi stavi chiedendo di cercarteli? http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fdoc%2Fmios%2Fmios_din_dout_pin_numbers.txt sai che c e una wiki?
win = notepad osx = textedit linux = gedit penso di si si
http://ucapps.de/mios/midibox_sid_v2_0_rc28.zip #if CS_MENU_USE_INCDEC_BUTTONS == 0 ENC_ENTRY 1, 6, MIOS_ENC_MODE_DETENTED2 ; menu encoder #endif ;; additional CS encoders ;; SR Pin Mode ENC_ENTRY 4, 4, MIOS_ENC_MODE_DETENTED2 ; Osc delay/transpose/assign #1 ENC_ENTRY 3, 0, MIOS_ENC_MODE_DETENTED2 ; Osc attack/finetune/assign #2 ENC_ENTRY 3, 4, MIOS_ENC_MODE_DETENTED2 ; Osc decay/portamento/assign #3 ENC_ENTRY 2, 0, MIOS_ENC_MODE_DETENTED2 ; Osc sustain/arpeggiator/assign #4 ENC_ENTRY 2, 4, MIOS_ENC_MODE_DETENTED2 ; Osc release/pulsewidth/assign #5 ENC_ENTRY 1, 0, MIOS_ENC_MODE_DETENTED2 ; LFO rate ENC_ENTRY 1, 4, MIOS_ENC_MODE_DETENTED2 ; LFO depth ENC_ENTRY 4, 2, MIOS_ENC_MODE_DETENTED2 ; Filter CutOff ENC_ENTRY 4, 6, MIOS_ENC_MODE_DETENTED2 ; Filter Resonance ENC_ENTRY 3, 2, MIOS_ENC_MODE_DETENTED2 ; Env depth/assign #1 ENC_ENTRY 3, 6, MIOS_ENC_MODE_DETENTED2 ; Env attack/assign #2 ENC_ENTRY 2, 2, MIOS_ENC_MODE_DETENTED2 ; Env decay/assign #3 ENC_ENTRY 2, 6, MIOS_ENC_MODE_DETENTED2 ; Env sustain/assign #4 ENC_ENTRY 1, 2, MIOS_ENC_MODE_DETENTED2 ; Env release/assign #5 sono solo degli esempi non sono sicuro che sia qui la risposta alla tua domanda
mmmm dig this: -
errr... yes you need are you expecting the .hex file to update magically by itself? Just have a look at the creating date of the file, you ll see it hasn t changed and it s probably older than the files you changed. Also if you are using mios studio, you ll be warned that the new hex file has changed since the last upload. There is plenty of info about how to compile and create new hex files. Simone
Broken link? -
how to...subtitute "osc delay" encorder with "osc pwm" encoder
cimo replied to iorobyy's topic in MIDIbox SID
AFAIK cross-posting over different languages is welcome, even advised as long as there is also a cross-link. Simone -
Ciao ignoranza nel campo programmazione (che tra l'altro condivido con te) non ti esime dal leggere attentamente e piu volte la documentazione, cosa che non hai fatto ovviamente visto la domanda. Immagino che sarai scappato gritando quando avresti dovuto leggere il codice sorgente della applicazione MBSID V2. Dentro del codice ci sono commenti (in inglese semplicissimo) che ti aiutano a capire le varie funzioni. Mentre creare del codice nuovo richiede una conoscenza approfondita, cambiare il codice presente richiede solo pazienza ed un minimo di EEC attivo. Avrai bisogno di installare la tool-chain di programmazione, guarda nella wiki. Io personalmente non so la risposta diretta alla tua domanda. Sei hai problemi con l'inglese scrivi qua e vedremo che si puo fare. Simone
No need for a midi merger, but don t forget that with this solution the envelope would be completely independent from the menu and MBSID V2 expects nrpn messages.
controling specific button type LEDS with midi events
cimo replied to analogue_mo's topic in MIDIbox HUIs
If you go C you can control the behavior of every single button, Stryd will help you ;) -
Di solito con questo tipo di switch il tasto non viene collegato meccanicamente, è solo appoggiato in cima allo switch e trattenuto dal buco nel pannello frontale. A volte i tasti vengono in una matrice fissata alla pcb sopra agli switch.
yep I know it is possible to add a few AINs but i still think that the best option to control envelopes would be an extra MB64
TheRainbow - Midibox and RGB Led Keyboard
cimo replied to julienvoirin's topic in MIDIbox User Projects
i would buy a security vault, hire a private guard, brick the entrance and electroshock myself to forget everything -
Another "easy" way out could be adding a MB64 to the box to send the proper messages to the MBSID, no need to change code/hardware and remember that a core can support up to 8 AINs without extra hardware.Consider also the nice features that MB64 has to offer with the soft-take over function and likesuchases. Simone
not 100%, i wanted to have the load between GND and EMITTER but it seems like i need a pnp transistor or some other kind of circuit. With this schem you have to isolate every single transistor cause the body (TO3) is COLLECTOR. Other little detail is that i have to connect the chassis to + and not to GND. Simone
ok here you go in case somebody will need it:
typo http://www.el-supply.dk err.. is that a compliment? ;)
http://www.el-supply.dk./
Good news, using a 2n2222 instead of bc547 is giving far better results
Ok we are kinda desperate and will offer 30 EURO for a working circuit if sent within 24 hours, it has to trigger around 70W of power from DOUT to a 2n3055. I am looking for help locally so consider that i may find an answer here before sending me any offer. Simone
