281 -
About xarolium
- Birthday 01/01/1
Gender
Not Telling
Recent Profile Visitors
xarolium's Achievements
MIDIbox Tweaker (3/4)
USB host doesn't work but i follow the TK topic
xarolium replied to xarolium's topic in Testing/Troubleshooting
Thank you for your reply. I will try a other cable and let you know -
Thank you for your reply, PA9 is the VBUS_FS line on the discovery board. As i power my Keyboard with a external power it does not change anything. I tried to connect PA9 to +5V but still no midi message from my Oxygen49 Any other advice ? -
Hi there,"USB MIDI 2x2 i 'm trying to build a very simple USB host to Midi converter with the USB_Midi_2x2 app. I have a Discover board MB997D, i uploaded the bootloader and the board respond correctly in MIOS studio, then i uploaded the USB_MIDI_2x2 hex file and the Discovery board is well recognize as "USB MIDI 2x2" in MIOS studio. Then i disconnect the micro usb cable and connect my keyboard (a Oxygen 49), i reset the Discovery board, then i tried top play some note on the keyboard but nothing happens, no data in MIDI OUT1 and the green led DOES NOT blink on the Discovery board. The oxygen 49 is powered by a external PSU. I made a custom USB cable that allows me to connect the +5V rail to a external PSU. Any idea what i'm doing wrong ? Do i have to compile the app with #undef MIOS32_DONT_USE_USB_HOST ? Any help will be much appreciated
Hello everybody, like marcos asked two years ago, i also want to add MIOS32 to STM32IDE. I follow the steps on th great tutorial made by BEBDigitalAudio but when i tried to compile a apps i got the following error. I also think i didn't understand how to access to file with Tortoise SVN. Can somebody help me please. make all Makefile:73: c:\mios32\trunk/programming_models/traditional/programming_model.mk: No such file or directory Makefile:76: c:\mios32\trunk/modules/app_lcd/Universal/app_lcd.mk: No such file or directory Makefile:79: c:\mios32\trunk/modules/midi_router/midi_router.mk: No such file or directory Makefile:82: c:\mios32\trunk/modules/midimon/midimon.mk: No such file or directory Makefile:85: c:\mios32\trunk/modules/uip/uip.mk: No such file or directory Makefile:88: c:\mios32\trunk/modules/uip_task_standard/uip_task_standard.mk: No such file or directory Makefile:91: c:\mios32\trunk/modules/freertos_utils/freertos_utils.mk: No such file or directory Makefile:94: c:\mios32\trunk/modules/keyboard/keyboard.mk: No such file or directory Makefile:97: c:\mios32\trunk/modules/ainser/ainser.mk: No such file or directory Makefile:100: c:\mios32\trunk/modules/aout/aout.mk: No such file or directory Makefile:103: c:\mios32\trunk/modules/max72xx/max72xx.mk: No such file or directory Makefile:106: c:\mios32\trunk/modules/ws2812/ws2812.mk: No such file or directory Makefile:109: c:\mios32\trunk/modules/notestack/notestack.mk: No such file or directory Makefile:112: c:\mios32\trunk/modules/fatfs/fatfs.mk: No such file or directory Makefile:115: c:\mios32\trunk/modules/file/file.mk: No such file or directory Makefile:118: c:\mios32\trunk/modules/md5/md5.mk: No such file or directory Makefile:121: c:\mios32\trunk/modules/sequencer/sequencer.mk: No such file or directory Makefile:124: c:\mios32\trunk/modules/msd/msd.mk: No such file or directory Makefile:127: c:\mios32\trunk/modules/scs/scs.mk: No such file or directory Makefile:131: c:\mios32\trunk/include/makefile/common.mk: No such file or directory make: *** No rule to make target `c:\mios32\trunk/include/makefile/common.mk'. Stop. "make all" terminated with exit code 2. Build might be incomplete.
Yes it is a Wilba based design but with my own button (cherry and standard illuminated 6mm squared button)
Zam, Thank you for your reply The P&G motor is a Escap 22S28 210E and seems to work with 12V and draw 0.3A I'm thinking of using Analog signal to driver motors instead of PWM. I 'm inspired by the SSL Ultimation schematic 82E353 to design my own PCBs. SSL use opto isolator to isolate power Motor and DC control/audio. I also looked at PID control like this one Now i still have to prototype and make some test. Maybe you can share your experience with your 89Motion project ? What do you advice to get the best result (less noisy fader and smooth movment) ?
Any help here !
Hi Diyers, Since @Zam built his wonderful moving fader console i 'm thinking of doing same thing on my Amek Galileo, the problem was to get the right fader to work with GAL10 channel. I finally get some of Penny and Gile PGFM3220/D fader to start this project. I tried to control the PGFM3220 with the MF_NG module but it was impossible to get the fader moving smooth and the motor is huge noisy by setting MIOS Calibration App. So i'm considering using a other driver like the ST L6201. Do you think it will solve the smooth movement and noise issue ? Your help is pretty much appreciate to put me on the right way to get it working Thank you
Hi There, I'm cleaning my workshop and i found lot of oldies i don't want, so maybe you will be happy to get it Here is the list: -Dual SSM2044 VCF PCBS x5pcs 5€/pcs -IIC Midi Module populate 10€ both -Midibox SEQ V4 custom PCB x 4pcs 25€/pcs -Midibox CV all in one PCB Pcb 10€ -Midibox Ultracore 10€ -Digisound 80-2 VCO x3pcs 10€/pcs -Thomas Henry VCO 555 10€ -Lot of Roland system 700 PCBs replica 8x PCBs (3x VCA Model 704, 1x S/H Model 709, 1x Noise/ring Model 708, 1x Dual ADSR Model 705, 1x VCF 703E, 1x VCF 703B) 95€ all -Ryk Sequencer Kit V2.3 polpulate with switches (cf picture) 50€ -X0xb0x Main PCB + case 70€ Paypal prefered, price ex shipping (worldwide) Thank you ;)
Any news ?
By the way do you need help to design a new pcb, I m prototype designer and can provide some service to help day community ;)
Is it true ? can't wait
Hi there, i would be very happy to buy a pcb for this project,any left? And what about the case? thank you
Zam, Thank you for your answer The problem is not how to interface the console with the DAW cause it already works pretty well. The issue is that actually protools allow me to set only four HUI interface so it's 32 channels and i would like to control 48 channels. My question is how to modify this 8 channels per HUI limit or is there an other protocol that allow me to control 48 channels.
Yes but it allow me to control only 32 channels (4 x 8 channels) and i need 48 How can i do it ?
