183 -
5
Everything posted by tashikoma
it's not a bit weird it's totaly crazy!!!!! :thumbsup: it's a joke it's cool very logic and the wiki is great but cause i'm french some details are sometimes not easy to understand....... the cut out is with some hole and a jigsaw hmm what is the word in english "power saw"? and a few hours of file down with a "lime"!!!!!!!!!!!!! the secret is to keep 2mm before file down next time i will choose wood or plastic !!!!! ;) stainless steel is unsane!!!
Hi everybody, finished an hybrid pedal box hybrid because it can use midibox 64 or pedal board aplications it's for controlling line 6 delay pro midibox 64 for editing facilities and pedal board when static config. 4 miniswitch for editing menu in mb64 4 footswitchs 4 expressions pedals and a subD connector for a future footswitchs leds and relays box expansion (for big config gear) thanks to you durisian... I've used a lot of concentration to understand the logic of the pdx config!!!!! and inox is a ######## thing to drill!!!!.... and now it's great!!!!!!!!(roots box but great) sorry my english is awfull!!!!!!!!!!!!
Salut tu ne peut pas retirer les ressorts qui maintiennent en position centrale?
donc essayé sur 3 config : windows 7 > sdcc mingw msys gputils ........edition des variables............. rien http://www.midibox.org/dokuwiki/windows_toolchain_quickstart sa ne marche pas.............. faut il configurer makefile et makefile orig? et comment? je ne trouve aucune info a ce sujet......... ubuntu 8.04 > sdcc gputils mais je ne sait pas definir les variables ...... comment inscrit t'on les variables dans etc/environment? je ne trouve rien sur le sujet................................ http://www.midibox.org/dokuwiki/doku.php?id=installing_gputils_and_sdcc_on_ubuntu_8.04 windauz xp > mplab ........... erreurs ne trouve pas les fichiers.......inc et h (alors qu'il sonts mis a la racine du lecteur) en fait la meme methode decrite plus haut que j'ai reussi a faire marcher grace a MOXI il y a 3 ans bruler des pics et mios studio c'est ultra cool creer un .hex je passe.................. je rend mon tablier!!!!!!!! la solution la plus simple et qui prendra moin de temp est de virer l' encodeur et le remplacer par des boutons et de changer mon module AOUT LC par un AOUT normal comme sa je pourrais utiliser le .hex standard!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Resencement des Midibox, SID et autres projets ...
tashikoma replied to gillesdeshays's topic in Français
yeah!!!!!! c vré que c'est tres joli..................................ultra classe -
http://www.midibox.org/forum/index.php/topic,11705.0.html
tien je regarde le sujet et je remarque que je ne t'ait jamais assez dit merci mr moxi.................. je viens de finir une midibox cv probleme je doit changer l'aplication (1 encodeur et 1 module aout lc) je n'arrive pas a faire un .hex j'ai dabord essayer avec la nouvelle methode ucapps "make" msys gputils mingw tout bien installé tout bien configuré meme les variables sa ne marche pas j'ai donc oeuvré a l'ancienne comme decrit par moxi plus haut la methode mplab marche pas snif gpasm marche pas........... il y a un truc qui m'echappe!!!!! vu le nombre de jours passés a essayer d'assembler ce fichu hex je me permet a demander un fichier .hex a la communauté.......j'assemble une midibox tout les 3 ans!!!!!!!!!!! pitié envoyer le moi!!!!!!!! midibox CV: encodeur ; aout lc ; j5 enabled ma midibox CV me regarde sans son ame...... (.hex) :( ???
oui sa correspond a un patchbay midi tu en aura pour moin cher a acheter un vieux patchbay roland........
a tu une bonne tension d'alimentation?????????????? le retroeclairage demande 4.2v et il faut un regulateur adequate voir avec un radiateur......... le ST7066U est compatible niveau pin avec le HD44780 mais il lui faut peut etre un driver adequate??????? quelqu'un sait??????
l'interet aussi serai de pouvoir programmer des patchs pour les elements d'un synthé analogique........................ j'ai vu le cd4066 a pas cher et rependu mais je sait pas si il faut pas d'autre composants pour le controler et je ne sais pas si il est clickless!!!
salut jigui moi sa m'interesse bien un kit sid!!!!!!!! a+
par contre ils sont dificillement trouvable et cher!!!!!!! :P
merci Moxi!!!!!!! (comment va tu depuis le temps!!!! ;)) c'est exactement ce que je cherchais!!!!!!!!!!!!!!!!! une bonne petite option...... youpi!!!!!
bonjour tout le monde! voila je partirai bien d'une midibox cv ou seq pour controler un genre de patch de routing d'effet genre effet vst glitch mais en hardware donc un module aout 8 sortie analo qui permetrait d'activer desactiver 8 effets audio....... un genre de multi a/b box electronique... et c'est la que je me pose des questions: 1 soit j'utilise des relays mais j'ai peur d'avoir des claps!!! et sa va jouer des castagnettes... mais sa peut etre sympa avec un micro contact......... 2 soit je trouve un schema d'un circuit qui ouvre et ferme une porte (comme un interrupteur)grace a la tension des sorties cv mais la je suis larguer..... quelqu'un aurai t'il une idée??? merci
avec la midibox cv c'est quand meme bien cool le lcd tape dans google "midi cv diy" ou des truc dans le genre t'as pas mal de projet dans le style.... apres je sait pas lequel est le mieux.......
oui c'est mieux dans les premieres lignes du main.asm: #define DEFAULT_NUMBER_POTS 64 ; number of connected pots pour assembler ton apli:http://www.midibox.org/forum/index.php?PHPSESSID=9b04510cdeab977013cbb05393e8faaf&topic=7587.0 pour ton essai tu peut te passer du module ain et brancher 8 pots directement sur le module core...... pareil il faut editer l'apli si tu veux savoir quel fonctions sont controlables dans reason tu regarde dedans celles qui ont un lien midi il me semble dans reason que lorsque tu fait clik droit sur une fonction (bouton potards) tu a edit events ou midi connection ou quelque chose dans le genre.... je n'est pas reason mais je l'ai utilisé ya quelques années.... la majorité des fonctions sont controlable par midi........
c'est vrai que quand il marchait au demarrage il n'y avait pas de buzz et des que l'apli se lancais il y avait un buzz!!! elektrovizo, quand tu dit gate c'est un noise gate??? si tu as un bon buzz et qu'il est assez consequent une noise gate va pas etre efficace elle ne va pas calculer la difference entre le signal et le buzz ou sa va pas etre tip top voir te bouffer de l'attaque... apres faut essayer... ton alim est de quel type et est branchée comment??? (sa m'interesse a titre comparatif) en fait la meilleure solution serai de metre un transformateur d'isolation audio..... ya un truc aussi il faut peut etre desactiver l'entrée externe ou relier le pin de l'entrée a la masse si elle n'est pas utiliser .... car sa doit jouer ??? j'y pensais mais je peut pas testez....
juste par curiosité!!!!!!! le cv du sh-2 marche de 5.6 a 13v??? du coup avec le montage amplificateur tu sort quelles tensions...??? de 5.6 a combien???
oui je l'ai brancher en midi rien j'ai tenter de charger l'apli et mios via midi avec mios studio et rien il n'y a pas d'activité midi ...... voila.....
merci pour tes conseils pilo ;) bon j'ai tester le 5v et la masse de j2 du sid ainsi que sur les 74H595 sa part de 0 sa grimpe progressivement a 30 M ohm et sa s'arrete et mon multimetre indique OL se qui veux dire qu' il n'y a pas de court circuit a ce moment la......ou que mon multimetre ne va pas au dessus de 30 M... j'en conclu qu'il y a un condo qui fausse la mesure et qui se charge?????? car sinon j'aurai une valeur fixe???? est ce grave docteur???? celui de 2200uf est un 25v ptete qu'il a du mal??? tous les autres sont des 35v 63v j'ai inspecter tout le module sid passer le cutter entre toutes les pistes aucun signe de court circuit.......; et pour le core je pense que mon pic est moisi car quand j'alimente il y a la premiere ligne du lcd qui reste noire comme au boot et plus moyen de charger de mios ou d'apli............. :'( j'espere que le 6581 n'a rien!!!!! j'ai tellement galerer pour le trouver..... d'ailleur si quelqu'un a une source immuable de sid il me fait signe j'en veux 4.......!!!!!!!! ;) j'echange ma belle mere contre un 8580!!!!!!!!!! (c'est pas un cadeau!!!) voila les news du frond.... nico
bon j'ai changer le regulateur aucun changement snif :'(
bon mon 7805 chauffe enormement et a une tension de 4.85v une fois le module sid branchée sur j2(quand tout s'eteint) j'ai 2v!!! pourtant je lui avait mis un radiateur........ les soudures sont nickel pas de faux contacts tout bien cablé le mios et l'apli ne se lance plus je crois que je vais changer le regulateur ecran + les puces sa doit consommé trop!!!!! pourtant sur la midibox 64 le 7805 ne chauffe pas alors qu'il alimente un ecran et 12 ic......... c'est peut etre pour sa que sa coupe :le regulateur doit etre abimé et ne suis plus l'amperage?????? chose etrange quand j'alimente le sid en 12v et que j'eteint le 5v ya le retroeclairage de l'ecran qui s'allume un tout petit peu.......
bon la l'heure est grave ??? ??? :'( :'( donc pour le probleme de masse j'ai chercher sur le forum (anglais!!!) et donc ya un sujet ou kelkun a le meme probleme que moi... on lui conseillait de debrancher la masse audio pour voir le resultat c'est ce que j'ai fait et en fait apres avoir debrancher la masse de la sortie j'ai aussi debrancher la masse de l'entrée car elle sont relié ensemble par le chassis du boitier et donc je l'est debrancher mais avec la midi box sid allumée et en la debranchant le fil a tiré sur un autre....(eh oui) sur le + de j2 (qui allimente en 5v le module sid) et la pas de court circuit mais l'ecran c'est eteint .... et depuis mon mb sid bug en fait j'ai juste debranché le 5v allimentant le module sid mais ya pas de courant dedans une fois debranchée!!!! et chose bizarre quand je le rebranche sa ne marche plus (l'ecran s'eteint ) quand je le debranche l'ecran s'allume l'apli se lance (mais le sid ne recois plus de 5V donc plus de son car les 74HC595 et le sid ne sont plus alimenté........(mais le sid est resté alimenté en 12V) etrange non....???? je trouve pas sa logique sa a du provoquer un desequilibre electrique????? donc testage de j2 j'ai bien 5V donc le 7805 doit fonctionner..... ptete qu'il est fatigué et qu'il n'aime pas les 74HC595???? pourtant un 74HC595 sa ne consomme rien???? voila le sid a marcher 1 mois sans souci (a part le buzz) et ya cette panne illogique......... jva demonter un peux plus profondement et analyser sa.... ptete changer le 7805!!!! tester au multi les tensions...... quelqu'un a une idée du probleme????? :'( ??? :'( ??? :'( ??? :'( ??? :'( ??? :'( ??? :'( ??? :'( ??? :'( ??? :'(
bon pour les photos de la bete jvé ptete ozer mais il faut que je recupere mon appareil photo que j'ai oublier chez des amis en belgique et j'ai une copine qui me le redescend......;) patience bon il faut savoir que la "bete" n'est pas jolie le principe etant de s'en tiré pour pas trop cher le boitier a ete fait avec les moyens du bord.... la facade (ou sont logé les boutons et les pots) est en metal trop fin en fait c'est le dessus d'un chassis de pc....... du coup c'est un peu trop souple et le metal c'est bien deformé a l'usinage ..... le reste c'est du contreplaqué les boutons et les potards c'est les moins cher (20c le bouton) les cabochons de potards on été recuperer........ d'ailleur il m'en manque 8!!!!!! je balancerai des photo du mono sid aussi..... meme esprit , fait dans un boitier cd rom..... et l'ecran est decalé de 2cm en arriere pour laisser la place au bouton !!!!!!!! (faut le voir pour le croire!!!) bon pour revenir a nos moutons (beeeehhh) j'ai rajouter les resistance de 2k entre le +5v et le potard du joystick sa ma reduit encore mes valeurs............. avant: 28 - 98 maintenant 25-65 une idée????
oh oh j'ai bien 3 boutons permanent dans mon lot crrrrr celui que j'ai changer et aussi le bouton edit!!!!!! donc moxi tu as tres bien diagnostiquer!!!! ;)
