matoz
302 -
Everything posted by matoz
interresting!.. Yes, if the timetretching code is here, it could needs very minimal hardware, with of course correct AD/DA converters. There is software witch plays in 432 a music tuned in 440 hz. But for a recorded music. I'm thinking about a box for live-playing with instruments tuned to 440. So the latency should be minimal...
Hello all! A question for programmers: Could it be possible to create a box witch tune a music tuned in 440hz to 432hz, in real time? It could be a nice challenge for DIY world.. ;-) Best regards, Loic
Refund has been asked several times in 2013 at the midiboxaddict adress, and in several forums. No answer, no refund... I retried one week ago, when i saw this message. No answer yet.
OOOOOOOHHHH YEAHHHHHHHHH IT WORKS!!!!!! I love you Thorsten!!! many thanks! wonderfull!!! I'm silly, i realize how it was simple and behind my eyes!!! ahahaha I tried with GM5, in midi, impossible to query the core, (see photo). Core receive reset command, but no answer received in mios studio. After that, Mios studio didn't want to close. I had to use window to close mios studio that was totally blocked. I've repeat that several times. In midi in, i receive strange parameters modification like program change, some notes, note off, on channels i never use. Last year, it was inverse, seqV4 application was loaded with GM5 because it didn't work with USB. Now, USB work (not totally, impossible to edit with file browser) and GM5 midi is problematic. I was thinking about appli like ADW cleaner and Adblock (block adds from internet). A friend installed them in my PC last week. Is it possible they block midi in flux?
i haven't AOUT interface, i just want to send a trigger from DOUT (second DOUT module Vs;D0, first shift register., so the 5th shift register of the chain.) Should i select one Aout interface in CV config page to have AOUT chan 16 availlable? If yes, witch? i can't understand in HW file why allowed values 1-16 if each shift register provide 8 gates. why 1-16? witch value should i select for SR5? (trigger is connected to VS-D0 of the first shift register of the secound Dout.) Regards, Loic
Hello, so i've got time on this project, i would like to send a trigger to TR808 kick from the first shift register (D0-Vs) of the secound DOUT module i've installed. i'loaded last version V4.078, with last MIOS. When i try to edit MBSEQ_HW.V4 with mios filebrowser, mios studio says "invalid response from MIOS32 core during read operation" after that, when i Query the Core it seems Core doesn't response in midi IN. In my text editor photo, do i select the right choice? When i disconnect and reconnect SD card MBSEQ respond like on photo 5. HW - is it correct? When i put invalid parametters such as XXX on HW file, nothing happen. On photo 6, we see asterix after AOUT * does SEQ says AOUT 16 isn't availlable? There is a problem somewhere, but where?
Sold!
Yes, it is still for sale
Salut tout le monde, En besoin urgent d'argent, j'ai décidé de me séparer d'un sammichSID équipé de 2 SID 6582. La dernière version est installée (V2.043) et les banques de sons et arpèges disponibles sont chargés dans la mémoire. Une alim 12V est fournie avec. J'en voudrais 400€, frais de port compris (envoi sécurisé avec tracking et assurance). J'ai aussi 4 puces 8580, testées ok, que je vends à 25€ pièce, port compris. Possibilité de remise en main propre sur la franche comté.
The Sammich is still for sale, 400€ shipping included, all around the world!
i'm in France
Hello all! I'm in urgent need of money, and i sell this sammichSID :sad: , i ask 400€ for it, i've search in the forum a correct price and it is the price i saw the most. 2 6582 inside ,last update V0.43, banks an arpeggio loaded, and a 12V PSU. Paypal payment. Pm me.
Ok thanks, pm sent on electro music forum.
Doug, 3 pm sent since 3/04 to ask you to refund my deposit. Please answer me. Waiting for it.. Thanks, regards
At the start of the seq (after power on), after he has found the SD card, there is these indication: HW:* How can i be sure the hardwareconfig file i copied into the SD card is running? I've copy it in the sd card and reloaded the seqV4.070 into the LPC1769 core.
i tried "DOUT_GATE_SR5 16" without results too. In fact, i'm not sure that the hardwareconfig file is active in the sd card.
So i chained a second Dout module to the first used for leds (it is seqV3 control surface). I connected Vs of the first shift register of the second dout (so i inderstand it is SR5) to 808 ground and D0 to 808 trig. I've change hardwconfig like that: (i've save it and copy it into Sd card) # Allowed values: 1-16, 0 disables the function, all other values invalid and not allowed (why allowed values 1-16?) DOUT_GATE_SR1 0 DOUT_GATE_SR2 0 DOUT_GATE_SR3 0 DOUT_GATE_SR4 0 DOUT_GATE_SR5 1 DOUT_GATE_SR6 0 DOUT_GATE_SR7 0 DOUT_GATE_SR8 0 # if set to 1, the DOUT "gates" will send 1mS pulses # useful for analog drums DOUT_1MS_TRIGGER 1 In event menu i selected Aout port chan 16 and played note C1 to C4 without result. could you explain "allowed values 1-16"?
Ok, thanks for your answer Thorsten. I will try like that. Regards
thanks for the answer, yes, the relay could be a solution, but in the seq, how can i send the trigger of a track to J5AO? In Event menu, with seqV4.070 i couldn't find "gate1" . Where in this monster should we route the track signal to "gate1"??
If someone have an idea how to route a track to Gate1, please tell it to me, i tested a lot of solutions and i'm really blocked..
I still have my probrem with triggering it from MBSEQV4.070 I tried to connect a led beetween J5AA0 and J2Vs to try to find how i can have a 3,3v gate from the MBSEQ, but no results. Someone can help me please? How can i be sure i send a gate trigger to J5A0? I tried a lot of possibilities into ENENT MENU and CV configuration, but no results. from Eric Archer: "If you are planning on triggering the circuit from a logic signal, the easiest way is to tie ACCENT to +12V (+15V), and connect the logic signal to TRIGGER. This schematic includes my diode-cap-resistor network. This makes trigger behavior independent of pulse width (unless the pulse is super short of course)" " If you’d like to trigger these drum modules manually, it is easy. All you do is get an SPST momentary pushbutton and wire it between +15V and the Trigger input terminal. You need to use the diode-cap-resistor trigger circuit here. Otherwise you will get a weird sound at the moment you release the button.You can also trigger them with piezo discs and make a drum pad. get some medium or large plain piezo discs (20mm diameter for example). Wire the piezo between the Trigger terminal and GND. When you tap the piezo, it will sound the drum.Remember, the Accent terminal has to be high (+2 to +15V) for the drum to make sound. " I've connected Accent to +12V , trigger to LPC17CORE J5AO and 808 ground to J2Vs Is it correct?
Some people asked me documentation and part list for the TR808BD from Eric Archer. Here is the links i used : http://ericarcher.net/wp-content/uploads/2009/07/tr-808-bass-drum-diy-project.pdf http://electro-music.com/forum/viewtopic.php?p=273645#273645
I've found at Hardware options/CV out : "Tracks can be assigned to the outputs in the MIDI event menu. It's also possible to route incoming MIDI events to the AOUT/gate triggers in addition (this replaces a CV interface completely). The AOUT channel and trigger routing is described in the "Special Pages" chapter of the User Manual. " But the link is empty. It is in work i think. And in event menu i haven't found a parameter to route the track to gate1. There is port AOUT but it doesn't seem to work. I tried to select BUS1, and in the Midi Menu, i routed it into Aout chan1, and it doesn't seem to work.
Hello, i need a little help.. I've built TR808 BD from Eric Archer ( http://ericarcher.net/wp-content/uploads/2009/07/tr-808-bass-drum-diy-project.pdf ) It works good when i trig it manualy with a switch connected beetween +12v and Trig. (accent connected to 12V) I'd like to trig it from MbSeqV4 from J5A (LPC17core). I've connected J5Aao to 808 trig and J5Avs to 808 ground. Is it correct? In MbSEQ menus, i didn't found how to route a track or a layer to gate1. How can i have access to gate1? If i understand well, if 808 accent is connected to +12, i could trig with 3,3v pulse without Aout or amplifier circuit.
