matoz
302 -
Everything posted by matoz
	Quand j' ai un soucis comme ça, je deconnecte tout et je repart depuis le début: 1: allumer le core avec le lcd sans aucun autre module. 2: ajouter les modules un à un et vérifier à chaque fois si ça marche. il y a forcément un moment ou tu vas te rendre compte de quel module est en problème. Vérifie les branchements. Que dit le lcd?
	hi, if you want, i have one spare chip, i can send it to you for 5€ PM me if you are intersted. Loic
	Hello all, I'd like to know if IIc Midi modules are supported by MB64 or MB64e application? It would be for adding some Midi Out to my project. I have a LTC module, but i need one more Midi Out. Is it possible to use LTC out, IIC midi module(s) Out and Core midi Out at the same time? Thanks Loic
	i was thinking about a thing like a sort of sub menu when we have selected a track, a sub menu in event menu and buttons ABCDEFGH could be selection of different midi out and buttons 12345678 the selection of Aout. regards Loic
	Hello, I'd like to know if it will be possible to select several midi Out per track? It could be interesting to control several devices with one track. Perhaps it is stupid, but what about the possibility to select several midi channel out per track too? And the same thing for Aout... and mix of them (Aout+midi) (Lot of combinations!!!) And the same idea for inputs: possibility of routing several midi in and/or analogue in into one track. thanks , very good work! Loic
	"I'll shut up now.." you have said too much to excite my curiosity! "Maybe tone controls too. That would add an extra 4311 for each channel board, but you'd get a 4 band EQ for that channel." that is very a good idea!! do you prepare another board that could be connected to the other boards? That board must be more expensive with an extra 4311 but I think it worth the cost easily and, of course, it would complete your concept seriously.
	"Once the boards are available I hope we'll get a few more builders interested." Hi Lylehaze, don' t worry, i think these concept will make some noise in internet when boards will be available!! It is the first DIY midi controlled mixer and it has a lot of possibilities!! I envisaged to build a 52 tracks mixer (6 mixers of 8 mono boards into one mixer of 8 stereo boards) , controlled by MB 64 (3* 16 midi tracks). I think there will be more posts on this thread when we will have boards... best regards
[B] Searching Core Board or Core Kit and LC Parts, Germany
matoz replied to Intermedi8's topic in Fleamarket
Hi, you will find all you want here : http://www.mikes-elektronikseite.de/midiseite.htm (germany) and here : http://www.avishowtech.com/mbhp/ (USA) Best regards -
Bulk Order #3 of SoundWell rotary encoders **SPARE BOX OF 96**
matoz replied to Wilba's topic in Bulk Orders
encoders received this morning. Thanks Wilba Best regards Loic -
	I already asked him at the beginning of year, I don't want to badger him… I think Smash knows that a lot of people are interested by this project and they are waiting for boards availability. Thanks best regards
	Hi Lylehaze, in the Wiki at MB Mixer description, you say "Circuit boards are available". Where are they available?
Anyone designed a PCB for a midi controller / mixer channel strip?
matoz replied to intellijel's topic in Design Concepts
Hello, A friend of me have done this soft to draw PCB: http://www.midibox.org/forum/index.php/topic,13099.msg111857.html#msg111857 regards -
	Hi Fururman, That is a good new. If you have shematics and block diagram, i' d like to see it! thanks Loic
	Le core redémarre t il après le chargement? L' affichage est il réglé? (je pensais avoir un problème aussi puis j' ai réglé la luminosité et le contraste, et "ready" est apparu.
	Hi all!! WTPA kits are available : http://www.narrat1ve.com regards
	Hi Bosone, i' d like to buy you your GM5 , i live in France thanks, Loic
	youhou!!! Ok for me !!! Do you know where this chips come from? (History) Is there some 6583 in a C64 serie? Awesome! ...or is it an awfull april fish?
	Salut, tu devrais peut être chercher du coté des wireless midi? Il y a différentes solutions qui ont plus ou moins de portée...
Hi Wilba, i' m interested for 96 pcs. Thanks. -
	Hi Prof, I received Jb Weld and Knobs this morning. Thanks Best regards. Loic
	yes, with a 24/0/24 transfo, i have +15/+15/0/0/-15/-15 at the output PCB, it seems be good. The power led is OK, the LFO led is OK with LFO speed. But no sound. When noise generator is "on" ,whith a lot of volume, i can hear a little the LFO. regards Loic
	Hi, i have the real story of this synth: when my friend have found it, he went at his home to test it, and he didn' t saw that the power is 110V... and he plug it in 220 Volt... the synth made a little sound and... pwwwof, no sound... He asked another friend of me about the power supply et he took of the transfo. I have it now. All fuses are clean. I tryed a 15/0/15 transfo, there is no synth sound but i can hear LFO and the LED supply is OK. I search now a 22/0/22 transfo... PS: excuse my "frog english"... Best regards LOIC
	Yes, many thanks Futureman. The result is curious but i will try it. "just send me some Black Truffles or Some good french red wine as payment.. ;]" :) Add a beer icon to your profile, or PM me your postal adress.. ;) Thanks, regards Loic
	thanks, i ever saw cs-10 schematics but i think it is a little different. the PSU is different according countrys. in CS-10 there is -15/0/+15 and +10, so 4 wires. Here, there must be only 3 wires. i' m afraid to grill something if i try -15/0/+15 or -15/+10/-15 ... i have sent a mail to Yamaha, i' m waiting for the answer to be sure. or if you want it would be cool if you test it. regards Loic
