matoz
302 -
Everything posted by matoz
	Salut, je viens de lire ça sur Ucapps /seqV2 : "Le module AOUT ne proposant que deux sorties Gate, les autres signaux Gates sont disponibles aux pins RC0 (CORE::J6::RC) et RC1 (CORE::J6::SC) du PIC" A+
40x2 Green-on-Black Optrex Displays - ORDERING INSTRUCTIONS
matoz replied to fussylizard's topic in Bulk Orders
lcds received this day. Many thanks Chris regards -
	Hi LyleHaze, Have you got some news, have you made more tests?
	to make it clear: idiot question: i was thinking about putting SeqV3 patterns into SeqV4. Could it be possible to change seqV3 patterns into midifiles with a program? i imagine it is not only change .hex into .mid? i know pic and stm32 are not compatible but perhaps there is a possiblility to not lose seqV3 patterns? :-[
Connection directe sur core d'un clavier récupéré sur synthé cassé
matoz replied to dubstructor's topic in Français
t' es allé voir du côté du MIDIBOX KB? même si ce n' est pas exactement ça que tu cherches, ça pourrait te donner des idées. -
	I' ve found this relay http://fr.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMtSzCF3XBhmW742zARJz0TfGo32%252b1C22HY%3d , time operating and release is very small (330µs and 75µs for release for the quickest).
	thanks Seppoman, I will try like that, i will see if i have big latency or not with the relay. So, when i will have configured J5 in the appli, i will be able to choose port J5 in my sequencer, and all note on of the track will send +5v to the relay. regards
	I read in different topics that J5 can be used like Ain, Aout, Din, Dout and we have to configure it in the code. But Aout and Dout are delivering some voltage and i don' t want it. I just want to take the place of the tap tempo switch with a track sequence. I don' t know very good CV world, and i have difficulties to imagine what is "gate out "exactly. so i continue to read, read, and read...
	the man doesn't want to give me the dd7 schematic. What exactly gates in j5 core are made for? Would it be good for this job?
	i don' t have it yet, but i've found a person who have it, i hope he will send it to me. But i search an universal solution for all tap tempo switch. I "just" want to replace the manual switch by a track sequence.
	should i use one "gates" in J5 of the core (with the MbSeqV3)? What exactly gates in j5 are made for?
	Thanks for your answer Nils! so it is possible, awesome!!! yeah!! "A pic pin will do (possibly needs an opamp/transistor to buffer/adjust the signal)." Please, could you tell me more exactly about that? If i understand well, i can connect directly (with possibly needs an opamp/transistor to buffer/adjust the signal) the tap tempo switch to the Core of my MB SEQ? regards Loic
	Hello all midiboxers, I have a Boss DD7, it has "tap tempo" whith a momentary contact and i' d like to know if it is possible to midify it with a core and an Aout module? so, i could sequence delay with "note on"? But i don't know what i should use beetween Aout module and tap tempo switch. A relay? But i think relay should have latency and click... How can i transform analog control into momentary contact? This could be usefull for all "tap tempo effects"... if we could sequence it with a sequence track,i imagine results... regards
	Si tu veux construire un contrôleur midi, regardes du coté des MB64 ou MB64E ou MB16E ou Midio128. tu devrais trouver ton bonheur ;)
	salut, il faudrait que tu nous en dises plus sur le projet que tu veux faire...
	sinon, tu peux aussi en trouver là :http://www.awatronic.com/index.php?_a=viewProd&productId=2525
	i' m in for 100 pcs too.
	salut, j' ai eu le même soucis avec le rétro éclairage sur un LCD 2*20 , j' avais juste à inverser les fils 15 et 16. Vérifie sur le datasheet de ton écran les connexions "led power supply". bonne continuation
	oui, les 2 sont corrects, bien qu' ils ne soient pas d' une qualité extraordinaire (surtout ceux que tu utilises!), tu t' en rendras compte après quelques mois d' utilisation...
	les boutons que tu dois utiliser pour les projets midibox sont des boutons normalement ouverts à contact momentané. Exemples ici : http://www.midibox.org/forum/index.php/topic,12720.0.html Qu' as tu installé sur ta midibox?
	Perhaps we will have this options in MB64(e).2 with STM32 CORE soon...? Imagine a MB64 with 8 differents midi OUT... 8*16 channels!!!! I was thinking about that because i search a solution to control a 48 midi track MB Mixer, so 3*16 channels, that explain i need 3 differents midi out. And i haven't the programmer level to change applications codes correctly. I try something but i'm very far to catch my goal if i can say it like that in english... I have time, MB Mixer boards are not available yet and STM32Core too. It's time to dream and imagine the design. regards Loic
	ok, thanks, i was thinking about linking a second core but it is the same problem of software. I'm learning C language, but i' m at the beginning of the travel... So, if MB64(e) support two midi out maximum, i will thinking my project differently. regards Loic
	I ask the question in a better way: does IIc midi modules works with PIC18F452? I know it was for Eusart bug in PIC18F4620 or 4685 but does IIC midi modules works with PIC18F452 applications like MB64 or 64E?
