woozy
    8
Everything posted by woozy
  1. Can anybody tell me what's so bad about IRC? I'm already in several IRC channels and adding just another channel would be easier for me than running a separate chat thingie. I know IRC isn't perfect but it works and there are several clients out there so at least you can choose the one you like best.
  2. The Jazzmutant Lemur http://www.jazzmutant.com/lemur_overview.php is a very cool sequencer. It's also in the offensive amount of money pricerange though.
  3. But using a specialised tool is almost like cheating :P. Actually I knew about chip-pullers but it never occurred to me that they're cheap and easily available ::) (I put one on my shopping list now).
  4. Put a small flathead screwdriver under one of the short edges of the chip and lift it just a millimeter or so. Do the same thing from the other side. Keep slightly lifting each side until the chip is out of the socket. At least that's how I usually remove DIP packaged chips from sockets. Just be careful and you'll be OK. Slightly bent legs can usually just be bent back without any problems (just in case you're a bit heavy handed with the screwdriver).
  5. Wow, using the monome keypad in an midibox is an awesome idea. Yet another idea to add to my "to steal" list ;D. Just lurking in these forums is really inspirational. Just you wait, in ten years time I will build the greatest MB SID ever ;).
  6. OK, found the blog (and read it too). This JB-weld looks like interesting stuff. Personally I was toying with the idea of having something threaded welded to the back of the front panel but I have some serious doubts whether that'd actually work (you'd have to use the same metals, it mustn't show on the front side, I don't know jack about welding, ...). This seems like a much easier solution.
  7. Hey Wilba, very nicely done indeed. How did you attach the CS PCB to the CS? I can see the screws on the PCB side but I don't see any screws poking through the CS :P. So what did you screw them into?
  8. I'd like one base PCB if I'm not too late, that is.
