![](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
rbv2
105 -
5
rbv2 last won the day on February 8 2023
rbv2 had the most liked content!
About rbv2
- Birthday January 1
Gender
Not Telling
Location
Germany
Recent Profile Visitors
rbv2's Achievements
![Rank: MIDIbox Addict (2/4) MIDIbox Addict](http://midibox.org/forums/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_default_rank.png)
12
Hello all Selling my midibox sequencer including breakout box. The sequencer is fully functional, from a non-smoking household. Has never been used for live performances, only studio use. The breakout box is a bit obvious DIY but fully functional. You need a free slot in the modular system for the +-12V power supply. Selling price 1350,-€. best regards rbv2 https://www.ebay-kleinanzeigen.de/s-anzeige/midiphy-sequencer-v4-midibox-stepsequencer/2241157248-74-4257
Hi all, would it be possible to implement saving mutes of the individual drum instruments (drum Tracks) when using s&top function in phrase mode? Have a nice weekend rbv2
thanks for your reply. the m16 looks promising but I'm afraid i not fully understand the capabilities or how to set it up. would it be possible to make a standalone midi-router from it? probably have to wait until it's more prepared for soldering by numbers :) thanks
hello, is it possible to get boards for this project or is it planned to offer it in midiphy-shop? I am very interested... would like to be able to route 32inputs to 16outputs (ports). thanks rbv2
have found something.. https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=477
i pulled them by hand. is there a special tool? the picture does not match the actual impression. one can clearly distinguish which steps are selected.
pulling off the caps from the matias switches is quite tough. a lot of force is needed. The new caps looking great and help with the light diffusion. thanks
:D yesss, can't wait. after a while of usage i find it a little bright too.
i like the keycaps a lot :D
when sending out triggers from AOUT Ch16 and then select in the parameter layer "lenght" i can change the lenght of the trigger/gate from 1% to Glide at 1% - no trigger at 2% - sporadic trigger from - 3-20% steady trigger from - 21-100 % double trigger with increasing distance (21% narrow / 100% wide) glide - only the first trigger before we fixed the grounding issue i got double triggers starting at 5% and other problems but now i'm pretty shure those are gates and not triggers making some modules being triggered at the beginning and the end of that rectangular pulse.
thanks a lot, it's working much better now also the random triggers when inserting cables are gone now :) only get double triggers on very long "lenght" settings wich i assume is normal behavior. are those real triggers or very short gates? thanks @Hawkeye and @latigid on for your support and patience you deserve a beer btw. where is the "buy hawkeye a beer" button?
no, its 5V didn't know how write it correctly. yes, isn't so well drawn but that's what I meant. thanks. i try it and report
@latigid on thanks! to be on the safe side, I made a drawing. it shows my current wiring. the black line with the question mark shows how I understand it. would that be okay? thank you! rbv2
