Hi guys, I just almost finished building an mb-6582. I've got a couple of problems:
1) The sync LED doesn't turn on when I hit sync. Is it supposed to turn on? All the other LEDs seem to work, and when I hit the button, the LCD goes from the default screen to "Ens. Clock" so the button seems to work. EDIT: I tested the LED directly and it did turn on.
2) Some of the LEDs that are not supposed to be on are just barely on. I'm planning on reducing the brightness, so maybe this won't be a problem, but is that supposed to happen? I'm using some ultrabright LEDs with 1K resistors, planning on going to 3K because the lights are pretty bright. EDIT: I ended up with 68K resistors, which is nice and not bright, but also some of the LEDs don't seem to have even brightness, so I guess I'll have to keep it lower and brighter, unless there's some way to PWM the LEDs?
3) Well this isn't a question yet. My 4th pair of SIDs (from right to left) has a problem where the box doesn't turn on if I have the SIDs in there. Sounds like a short, but I haven't investigated where yet (I did notice 1V on the 5V/GND jumper, slowly increasing, none of the SIDs felt abnormally hot), and since I'm not sure if the socket somehow killed my SIDs, I want to be fairly certain before I put my only two spare SIDs in there. EDIT: I've now found this problem without the SIDs in, so it must be somewhere else on the board. I removed all the supporting chips (no SIDs or PICs) until the problem went away, then put them back, the problem did not return. I think it may be an intermittent issue with some of the supporting chips.
Thanks,
Chris
