sprintf
    32
Everything posted by sprintf
  1. hello , after a few problems my LPC_ NG is running again. im wondering if there is a way to offset the display ( shift to the right ) by 1 or 2 pixels . since my 1.3" SSD1306 are shifted 1 (or 2?) pixels to the left . if im doing the offset via ngc ( which would be a workaround ) im losing a couple more pixels . ( since shifting the letters one position to the right , id loose a letter ) in mios32_lcd.h the offset is "forbidden" ( it says : // fixed format, dont change! ) is there a way to do this , other than via ngc ? ps : im happy to be back working on this after many years :)
  2. Thank you , im measuring something similar . so this seems normal . i can replicate the behaviour now and i hope this will help to track down my problem . when i connect my core with NG 1.036 to a external psu ( no usb data connection ) the app / core is always starting properly . when i connect the core to usb ( as long as there is no data handshake with mios , ableton or any software ) it will boot fine . when the core is connected to usb (power) and i start mios or any other app on the mac (e.g. ableton , logic etc ) the core is crashing. the hard fault adress is always 0x000189ce . i can workaround this crash if i boot with "Bootloader HOLD Mode jumper" and remove the jumper afterwards. how can i find out about the hard fault adress ? ps . you are right about "disable UART.." from config file . this is preventing the hard fault (as well) . but then i loose the midi in / out ( 5 pole DIN ) :( actually after reactivating UART and reducing encoders ( from 125 to 33 ) as well as reducing aout channels (from 32 to 8) , the hard fault seems to have vanished. i still would like to know how to find and identify the hard fault adress
  3. hello again . i also have hard faults with 1.036 now . but only every 2nd or third time i reconnect the usb cabel . im wondering if maybe something got seriously damaged . how warm will the lpc get usually ? the mcu is getting warm . i can still touch it but im wondering why it is warm at all with such small duties . this is the normal official release from the download page . is there a way to identify the hard fault adress ?
  4. Looks very nice and neat .I didnt know you are so busy with things . (Thank you for your support). I was working a lot with max/msp and m4l too. Its a lot of fun , but it takes a lot of time as well :) . Enjoy and keep up this amazing work.
  5. It is confirmed the actual NG-Firmware was not tested for a LPC-Core (maybe someone made changes, but tested it only on STM32? The actual NG Release (1.037) in the github trunk does not work on LPC-Core ! see this thread :
  6. Thank you for all your effort . I was really getting frustrated . _ this is really sad news , since i was actually working with this release . now i cant compile any more. UART here , has either something to do with Ethernet / RS-232 Interface or a Serial Connection ? i will check if i can use the release properly without UART .
  7. vielen dank , dann habe ich das richtig gedacht. so werde ich es auch machen .
  8. so this means , its better to edit the mios-config , before i compile ,right ?
  9. could you ,please try to compile the ng from the github trunk and see if its working ?
  10. this version is what comes out when you compile ng from the actual github trunk . i successfully used it for maybe 2 weeks now. then suddenly it broke . and i cant even use it after i compiled it again from src . ??
  11. i used the ngc to deactivate srios . i only use 4 at the moment. the display says HARD FAULT and (meanwhile) changing hex codes.
  12. sorry , i forgot to write its LPC. strange. how its possible that suddenly it happened . even with a freshly compiled one ?
  13. project.hex
  14. mios32_config.h
  15. it wont let me upload the file .
  16. i thought it was a loose solder joint . actually its not
  17. I suddenly have a Hard Fault 0x00018fc2 when powercycling and booting NG via USB Power / USB Data Connection. If the bootloader jumper is connected i can use the USB Connection to upload the bootloader . but after uploading NG again and rebooting , it wont boot back up after power cycling the USB Connection. The App will boot properly with external power and detached USB cabel. this suddenly occured i use a self powered usb hub . i tried disconnecting all attachments ( sdcard , scs ,etc .. ) but that does not change the behaviour. I also recompiled the hex and tried again , but no luck. does someone have a guess ?
  18. ich hätte da noch eine andere Frage . Bisher habe ich mit einem LPC Core gearbeitet. Es soll aber demnächst auch ein STM32F4 Core her . Muss ich die Toolchain um die apps zu compilen dann jedesmal umstellen . e.g export MIOS32_FAMILY=LPC17xx export MIOS32_PROCESSOR=LPC1769 export MIOS32_BOARD=MBHP_CORE_LPC17 .. export MIOS32_FAMILY=STM32F4xx export MIOS32_PROCESSOR=STM32F407VG export MIOS32_BOARD=MBHP_CORE_STM32F4 oder kann ich 2 Toolchain profile haben (mit verschiedenen Pfaden ) ? lg , jascha
  19. it works now !!! YAY. YOU MADE MY WEEKEND !!! you seriously made my understanding of things much better !!!!! THANK YOU SO MUCH. i owe you some nice food and beer ( if you drink some )
  20. im checking your folder and file structure and reading the .c , .h and make files. ..and comparing things with how i did. im beginning to see the light . i was not aware of the folder structure . in fact i have very little knowledge of programming . i just downloaded the complete trunk from github and went to : mios32/modules/glcd_font ( to add my xpm and .c files and change the files : glcd_font.mk & glcd_font.h accordingly ) and mios32/apps/controllers/midibox_ng_v1/src ( to change mbng_lcd.c ) then i cd into /midibox_ng_v1 and "make" then i got the error from mbng_lcd.c ( which is referring to <glcd_font> ) - as i see you have everything in one folder but you dont use glcd_font.mk (because you adressed the fonts directly in your folder / from your "makefile" ?) ----!!!! i think i understand now what the problem is . my building environment is always referring to my old /svn directory . ( since i just started again after many years to work with all that things ) i will move the new github trunk to the /svn folder and get rid of the old trunk. lets see , i think this should fix it . ( you are helping me a lot to understand the whole "c compiling / folder structure)
  21. thank you very much for your reply . the high and low letters didnt change the problem. i named everything exactly like in the originals. i now tried to just exchange one of the originals with my font files und renaming them . the strange thing is , it compiled properly but the font did not change after the upload . seems im stuck . THIS NOTE makes me wonder . does it mean they are precompiled ? Some prepared Fonts/Icons are located under $MIOS32_PATH/modules/glcd_font They are already compiled into the project if a GLCD driver has been selected (no need to extend the Makefile) o GLCD_FONT_NORMAL (6x8 character set) o GLCD_FONT_SMALL (4x8 character set) o GLCD_FONT_BIG (16x24 character set) o GLCD_FONT_KNOB_ICONS (28x24 round knobs, 12 different icons) o GLCD_FONT_METER_ICONS_H (8x28 horizontal meter bars, 28 icons, 14 with/14 without overload marker) o GLCD_FONT_METER_ICONS_V (32x8 vertical meter bars, 28 icons, 14 with/14 without overload marker) i took a fresh trunk , put my own lcd files , renamed everything according to the present .c and .h files and compiled . still the big font ( the one i exchanged ) is the same as in the original . how is this possible ? are the font files cashed somewhere ? i also went to the bootloader and initialized the glcd . i dont understand where its getting the font from if the glcd_font files have been changed ( they have the same names to be able to compile ) .
  22. hey , while i was following this tutorial . http://www.midibox.org/dokuwiki/doku.php?id=how_to_create_custom_glcd_fonts_icons_bars_for_midibox_ng it seems its not allowing me to add a new font . is this because the trunk is precompiled ? midibox_ng_v1 username$ make rm -f project.hex Creating object file for app.c Creating object file for mbng_sysex.c Creating object file for mbng_patch.c Creating object file for mbng_event.c Creating object file for mbng_din.c Creating object file for mbng_dout.c Creating object file for mbng_dio.c Creating object file for mbng_rgbled.c Creating object file for mbng_enc.c Creating object file for mbng_ain.c Creating object file for mbng_ainser.c Creating object file for mbng_kb.c Creating object file for mbng_matrix.c Creating object file for mbng_cv.c Creating object file for mbng_mf.c Creating object file for mbng_lcd.c src/mbng_lcd.c: In function 'MBNG_LCD_FontInit': src/mbng_lcd.c:193:31: error: 'GLCD_FONT_JBIG' undeclared (first use in this function) src/mbng_lcd.c:193:31: note: each undeclared identifier is reported only once for each function it appears in make: *** [project_build/src/mbng_lcd.o] Error 1 ---- > the declaration is made according to the tutorial : s32 MBNG_LCD_FontInit(char font_name) { switch( font_name ) { case 'n': glcd_font = (u8 *)GLCD_FONT_NORMAL; break; case 'i': glcd_font = (u8 *)GLCD_FONT_NORMAL_INV; break; case 'b': glcd_font = (u8 *)GLCD_FONT_BIG; break; case 's': glcd_font = (u8 *)GLCD_FONT_SMALL; break; case 't': glcd_font = (u8 *)GLCD_FONT_TINY; break; case 'k': glcd_font = (u8 *)GLCD_FONT_KNOB_ICONS; break; case 'h': glcd_font = (u8 *)GLCD_FONT_METER_ICONS_H; break; case 'v': glcd_font = (u8 *)GLCD_FONT_METER_ICONS_V; break; case 'j': glcd_font = (u8 *)GLCD_FONT_JBIG; break; // <------ HERE ! default: return -1; // unsupported font } ----> the other files have been changed and added as well Could someone please point me in the right direction . What am i missing ? do i have to precompile everything to make this work ? thanks a lot for time and effort in advance. glcd_font.mk glcd_font.h glcd_font_jbig.c glcd_font_jbig.xpm
  23. Is it possible to configure din sync clock outs in ng ? greetings .
  24. what is the psu on this photo ? specs ? where to get it ? it has +12 -12 gnd and 5v ?
  25. is there any date to get new seq cs boards ?
