Schrabikus
Programmer
    270
    4
Everything posted by Schrabikus
  1. I had a similar problem. I've replaced 24LC512 with 24LC256. Formatting was passed with few reboots. When i try to batch upload patches it cause reboot, so i've uploaded patches one by one. Now it works.
  2. Schrabikus
    SMD boards
    Eagle files if someone wants to modify it.
  3. Schrabikus
    SMD boards
    Confirm that DIN module is working, DOUT seems to work too.
  4. Schrabikus
    SMD boards
    DIN PCB positive i have forgot that not everyone has the Illustrator :rolleyes:
  5. Schrabikus
    DOUT smd
    DOUT PCB. Positive and negative versions, but not tested yet.
  6. From the album: Schrabikus Midibox progress
    SMD DIN PCB<br />54 holes :whistle:
  7. DRN110 006/26 BLK looks good for encoders. I need about 150 with 6mm D-shaft
  8. Schrabikus
    MBFM YFM262
    You can use Wood's metal (50% bismuth, 25–28% lead and 22–25% tin) instead. Its melting point is lower than Rose`s I`ve bought it at local radio store.
  9. Schrabikus
    MBFM YFM262
    And video showing the cleaning process.
  10. Schrabikus
    MBFM YFM262
    Boiling in water with citric acid and Rose's metal :sorcerer: is the video showing the process (unfortunately in russian, but it`s quite descriptive) All you need is citric acid (works with acetic too), Rose`s metal and cotton swab or wiping blade for cleaning redundant tin from plate.
  11. Schrabikus
    MBFM
    PSU taken from broken DVD player (bipolar 12v + 5v)
  12. Schrabikus
    mbseq assembled
    The final touches is to calibrate AOUT_LC (which strongly does not want to calibrate) for controlling MS-10, replace microSD adapter with real SD slot and faster SD card, and the main dilemma: matrix wiring (which i have to deal with and resolder all the wires) or etching and soldering additional DOUTS/DINS. :getlost:
  13. Schrabikus
    mbseq assembled
    Yeah, the software is pure magic! I have just calculated hardware parts total - it`s slightly less than $150 :sorcerer:
  14. Schrabikus
    mbseq assembled
    The final step is to make matrix wiring like in Wilba`s MBSEQ for control surface and leds. Now the bottom line of buttons not used.<br />Vacant DOUT and DIN modules will be used in MBFM, which is next.
