Schrabikus
Programmer
    270
    4
Everything posted by Schrabikus
  1. Тим наконец ответил: Ñказал, что отправлÑет, ÑпроÑил Ð°Ð´Ñ€ÐµÑ Ñ‡Ñ‚Ð¾Ð±Ñ‹ поÑчитать ÑтоимоÑть.
  2. I can't exactly figure out where to post this, so let it be here. I have a very strange bug: When i connect my LPC17 MBSEQ to MBFM it seemed like there's no midi data received by MBFM. BUT! When i connect it via midi thru enabled device (like Midipal or Shruthi) - all ok. When i connect midi keyboard directly to MBFM - all fine. And connection to midi port of PC also gives me good result. The MBSEQ works fine, being directly connected with Shruti, Midipal and PC. When i connect midi cable (with other end in the air) to MIDI OUT of MBFM - some midi data appears, but with a lot of dropped out notes. Non working config: [MBSEQ]--->[MBFM] Working config: [Keyboard]--->[MBFM] [MBSEQ]--->[MIDIPAL]--->[MBFM] [MBSEQ]--->[MIDIPAL]--->[sHRUTHI]---->[MBFM] [MBSEQ]--->[sHRUTHI]--->[MBFM] [PC]--->[MBFM] Half working config: [MBSEQ]--->[MBFM]----> Scratching my head.... :unsure:
  3. New UV lamp to replace broken at NY party old one. It's time to make some PCB's =)
    1. jojjelito
      jojjelito
      Go for it! Cooking PCBs is nice, it keeps others out of the kitchen!
    2. Schrabikus
      Schrabikus
      switched from ferric chloride to ammonium persulfate to the great joy of my wife =)
    3. Hawkeye
      Hawkeye
      but its also good for cleaning the kitchen sink :)
  4. Can you confirm, that AZTECH have OPL and DAC?
  5. it's V-USB/Atmega8 based midi-controller with one encoder and up to 48 knobs/buttons and optional LCD. http://avargesnano.narod.ru/3/MIDI-DJ-CJ-CONTROLLER-3.0.html
  6. International shipping?
  7. ÐžÑ‚Ð»Ð¸Ñ‡Ð½Ð°Ñ Ñ€Ð°Ð·Ñ€Ð°Ð±Ð¾Ñ‚ÐºÐ°, ÑпаÑибо! ЕÑть ли возможноÑть добавить MIDI-out к третьей верÑии?
  8. Thumbs up, beautiful tune!
  9. I've removed additional caps from OPL3 board and voila!!! No noise at all! So increasing capacity of PSU output caps + adding 10 ohm resistors totally eliminates the noise.
  10. Have no words to thank you, Thorsten!!! With 100 uf caps at OPL3 board the noise decreased by half (MBFM_noise_capacitors.mp3) Than i've changed 47 uf PSU caps with 200 uf and added 2x10 ohm resistor Aaaand the noise disappeared completely!!!!! (MBFM_noise_capacitors_resistors.mp3) :sorcerer: conclusion: switching PSU from dvd player can be used in audio apps! MBFM_noise_capacitors.mp3 MBFM_noise_capacitors_resistors.mp3
  11. Hello, friends! Can you please listen to attached mp3 and tell, is it normal, or something wrong? Noise remains when i disconnect LCD and CS from the core. So far i can not exclude PSU (it's one from dvd player +12v/-12v/+5v) but noise lasts about half a second after switching PSU off. Cable from core to OPL3 board is about 12cm, soldered directly to core. Thanks in advance. And the OPL3 +5v led lights with only J2 connected. MBFM_noise.mp3
  12. Sorry, Occam's razor is on my mind =)
  13. I have a similar problem. Permanent backgound noise, even with LCD and control surface disconnected. MBFM_noise.mp3
  14. Joris, you're so lazy! I've made my SEQv4 without any questions at forums and with only one factory PCB (LPC Xpresso) This forum has comprehensive information about it. The main thing is your desire and respect to community members :ahappy:
  15. Will it work with single polarity supply?
  16. Thanks! I tried to make a few more simple circuits but was not satisfied with the result. This is what i need! =)
  17. Beware of soviet diodes! :nuke:
  18. Very nice! Which design of germanium distortion did you use? Can you share schematic?
  19. rosch, it`s acrylic laser cut, inspired by Shruthi`s case.
  20. No, TK`s MBFM. Waiting for Wilba`s package to make it 4-channel.
  21. From the album: Schrabikus Midibox progress
    Some of presets turned to this glitch Rhodes :whistle:
  22. Cool! Black/Orange combination is good. And it looks very professional!
