x0xb0x Bulk parts order Reloaded. (to Digikey, Mouser, etc).
Updated - All Parts Arrived
It will probably come in more than one batch, due to  the usual stock problems, but I can now pad out the Digikey orders to get free postage for a reasonable number of orders.
Does anyone need programmed AVRs?
The attached text file is a list of the parts I am preparing to order. If you want to join in this order, download the text file attached, fill it in, and email to the adddress in the file As an Attachment. Put 'x0xb0x bulk parts order' in the subject line.
Once I've done the sorting, I'l order and PayPal you once it has arrived.
Remember that this is a contract to buy.
If you can't do paypal, contact me first with an alternative.
Update
Orders for:
Sasha
b-funk
MTE
kokiPsiho
Goblinz
asafnetzer
TheProf
Kartoshka
Julian Voirin
Status:
NKK switches arrived from Farnell
Mouser order #1 arrived
Digikey Order #1 arrived
Mouser Order #2 Arrived
Digikey Order #2 Arrived
Farnell Order #2 Arrived
All parts now in stock bar 1% resistors, (and only 2 people wanted them). I have a lot of accounting to do to match all the currencies, but I should be invoicing and dispatching from 22 of September.
OrderForm02.txt
OrderForm02.txt
  • Replies 103
  • Created
  • Last Reply
Top Posters In This Topic
the x0xb0x need 3 of the panasonic detent type pots. (list has 1 as standard)
from ladyada mods page:
Detent Tuning knob
When we designed the x0xb0x, we put in a non-detent tuning pot because that was what the original 303 had. However, this may drive you a little crazy. Panasonic part number P3I9503, an equivalent 50K linear potentiometer with a center detent, is available from DigiKey. Note that you may have to retune the synth once in a while to keep the center detent 'correct'
'Tuning' knob by default is coming without detent, but can be substituted by one with detent.
P3I9503  POT 50K OHM 9MM VERT PLA BUSHING
@mike:
then, my guess, the list is missing 2 (or 3 if tuning not substituted) of 50K D log pots:
P3L2503  POT 50K OHM 9MM VERT PLA BUSHING
and, USB B-type Jack is not in the list as well.
i also need some minor 2 resistors which i couldn't find on futurlec
You are right. I will update the file when I get home (I'm on a friends machine here). I will assume anyone that has ordered pots on the old form wants a full set.
Thanks for that, Two of us checked it and we still missed an item.
I'll put the USB jack on as an option too.
Please cancel my order, Ill reorder and send you the list updated again, I can get the caps, usb-jack and some other things at reichelt ;)
I hope this is OK for you and makes no trouble...
EDIT : Can I use the standard WIMA-capacitors for the x0x ?
EDIT 2 : Ok, I see now there isnt every cap available at Reichelt (no 18nf)  :-\
EDIT 3 : Order canceled and sent new one ;)
The 1% ones on the LadyAda BOM - not the ones for the LED's, which you will need to adjust for which type of LED you have, and how bright you want them.
I think everyone can get 5% basic resistors..
Mike, I really appreciate every help that you are offering here but i don`t believe it makes sense you bother with those resistors and common part like electrolytes. Everybody can find those locally and it is fairly inexpensive. It is not like we need 1000 of them for x0x. We need to shop some more common pars locally anyway so please dont complicate things for you very much. I really don`t expect you send us all the parts as we could expect from ladyada. Doing a Digikey and Mouser bulk and getting all rare parts is already almost as we are getting full kit. But suit yourself. I`m satisfied whatever you decide.
I wouldn't mind a pack of resistors/common bits. Componants seem to be very expensive in the UK so it would save a bit; I'm not sure if it would save people in other countries much though. Although it would be nice (and lazy!) to have a kit containing all(/most) of the componants arrive at my door, it would be a lot of work to make the kits up.
Basically I'd be in for a couple of resistor sets, but please don't commit too much time for it if you're busy.
        G
Lets not forget Mike offered to check 500pcs of 733`s for hfe so each of us gets even part of high gain trannies. I did it with 120pcs the other day and it wasn`t fun.  ::)
i have all the resistors and caps already, so i vote no.
it was really easy to go thru the list and order them all from local supplier or a webshop, took me only one evening rechecking every part about 5 times.
  • 4 weeks later...
You're right. Thanks folks. Funnily enough, in my master list here, it's 6MHz, (I was getting them from Rapid), but I misread the BOM spreadsheet, and thought it was an 8, when I typed out the parts list.
I'll update the text file now.
I've had a few things to sort out here, but I'll get this one 'back on the stove' properly, next week.
  • 3 weeks later...
not that i'm pushing...
not that i'm getting impatient too, anyway will not touch soldering iron before late summer.
just making sure we're not loosing interest in this thread.
Damn it. Last time I checked the pots and grayhill stock was pretty low too. So, we might be missing even more parts again.
It really is neverending story.
sure, and it always will be, that's the reason we need to place an order asap,
LET THEM solve the stocking questions.
note: i'm waiting for green light from Mike to send him my list.
i know he's not participating in the forum for some solid reason - so i wait silently, and not shouting loud.
I believe it is possible to hold the order until the all ordered parts be on stock and than ship it all together. Like this, we will never get those parts.
It is absurd that getting all those rare parts is easier than those still in production. OK Mike had luck to get it for us from same supplier but I managed to get all the rare parts from few sources myself without much hassle.
the reason is this, if you look at adafruit site, you see 1 day 30 stock pcb, the day after 10, than 0.  ;D
seems that a new acid era it's coming..
or it was never ended?  :)
